Slip on advice. 82 650 Maxim
Discussion in 'XJ Modifications' started by Coldpaw, Dec 30, 2015.
  1. Coldpaw
    Coldpaw Member
    Central IL
    Okay, so I really have one question and one request for advice. Long story short I got a set of slip on mufflers for my 82 650 maxim, Got it fairly cheap on ebay without any mounting hardware. Came in three parts, left side two into 1, right side two into 1, and a crossover pipe. My question is: do I need to go out and find gaskets for these parts? As for the advice, the head pipes on my bike now are in pretty good shape except that the two right side pipes seem to have the clamps rusted in place and the PO just cut off the original mufflers leaving those clamps on. Does anyone know a good way to get them loose so I can install the slip ons? Thanks in advance.
  2. k-moe
    Pics of the setup would help. If it's anything like stock, then you do need gaskets.
  3. Coldpaw
    Coldpaw Member
    Central IL
  4. Coldpaw
    Coldpaw Member
    Central IL
    Those seemed to be the most relevant angles.
  5. Coty
    Coty Member
    Frisco city, Alabama
    Where did you get them and do they have anymore lol?
  6. k-moe
    There does not appear to be any relief cut into the pipes for clamps, nor are there any loops for springs. I can only assume that they are meant to be reatined entirely by the mounting points at the mufflers, which IMO is a problem. I also don't see any relief for gaskets. My thought is that you should dry fit them and see how well they meet up with the headers. I'm fairly certan that you'll want to use high-temp RTV, or muffler paste to seal the joints, but I am concerned that without any clamping force the exhaust will tend to want to move around and place undue stress on the headers (particularly at the header studs). I might just be worrying too much though.
    Coldpaw likes this.
  7. Coldpaw
    Coldpaw Member
    Central IL
    Ebay, the actual store was Stevens' Sports Center out of Midlands Michigan. http://www.stevenscycle.com/
  8. Coldpaw
    Coldpaw Member
    Central IL
    Thanks, I will be checking the fit soon. I had completely forgotten about the liquid gasket route. I'll post some pictures of the dry fit just in case.
  9. Coty
    Coty Member
    What kinda price did it set you back for that setup? It looks nice!
  10. Coldpaw
    Coldpaw Member
    Central IL
    The ending bid was 105 plus like 13 for shipping. Thanks, I'm happy with the look but I'll feel better about it after it's installed.
  11. hogfiddles
    That's an awful wide spread there--
  12. Coldpaw
    Coldpaw Member
    Central IL
    Do you mean between the header connections or between the the mufflers in general?
  13. hogfiddles
    Both...... But you'll figure it out as you install it, I guess
  14. Coldpaw
    Coldpaw Member
    Central IL
    Hope so. Getting a bit nervous now.
  15. hogfiddles
  16. jayrodoh
    jayrodoh YimYam
    Cleveland
    What a small world. I grew up in Saginaw and frequented Stevens many many times back when I rode a RM250.
  17. Coty
    Coty Member
    I'm going to attempt to make my own anyways. I can exhaust pipe pretty cheap and I have access to a bender so I will see how it goes.
  18. Coldpaw
    Coldpaw Member
    Central IL
    Small world indeed, my ex was born and raised in Saginaw. Visited a few times.
  19. jayrodoh
    jayrodoh YimYam
    Cleveland
    I'm still married to my Saginaw lady :) Not much in the way of work up there.
  20. Coldpaw
    Coldpaw Member
    Central IL
    They should start hiring people to put out all the abandoned house fires!
  21. Coldpaw
    Coldpaw Member
    Central IL
    After some fiddling and research I understand why the springs would be a good idea But as I have no mounting points for those I was thinking a set of rubber bushings at the mountings points on the mufflers might be a good idea. Any thoughts?
  22. Coldpaw
    Coldpaw Member
    Central IL
    So I did some test fitting today and it looks like the mufflers will be angled much higher than I originally thought but I can't do a proper mock up until the new rear foot peg brackets come in. Also it turns out that the things I thought were rusted on clamps were actually the old muffler gaskets which will (hopefully) be easy to cut off.
  23. Coldpaw
    Coldpaw Member
    Central IL
    I finally got a response from Jardine. It seems this model was produced before the ownership changed hands in 2012 but they were able to send me the simple instruction sheet. I figured I would share it here in case anyone else gets a 1370_001-page-001.jpg hold of an old set like these.
