Solo seat hinge help
Discussion in 'XJ Modifications' started by Jason Orzel, Dec 18, 2015.
  1. Jason Orzel
    Jason Orzel New Member
    Cleveland
    looks like it was for welding to a tube. run a flat bar or plate across the frame with the proper dia half round welded to it
  3. Jason Orzel
    Cleveland
    Yeah that was kinda where my head was at or I was going to remove the curved piece and run a dowel side to side with it ran through the hinge holes
  4. willmarmnxj650
    willmarmnxj650 Member
    Willmar mn
    What did you end up doing?
  5. Jason Orzel
    Cleveland
    Ha still nothing... I'm brainstorming the idea now I've got a few ideas on the table I've done quite a bit to the bike since this post but it's getting down to where I need to make up my mind and make a move so I can move on to finishing her up and start tossing her back together... I'm running into an electrical issue now with my blinkers
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Cleveland Ohio? Me too. Post up some pics of your project!
  7. Jason Orzel
    Cleveland
    image.jpeg Tore down image.jpeg wrapped pipes image.jpeg front shock covers image.jpeg rear shock to strut conversion image.jpeg rear blinkers and finished handlebar setup
  8. jayrodoh
    jayrodoh YimYam
    Cleveland
    Looks like its coming together! You have some springs on that seat with the hardtail? What are you doing with the old turn signals, shocks etc?
    Maybe I'll see ya on the road next year, shouldn't be hard to miss you with those colors.
  9. Jason Orzel
    Cleveland
    idk yet, I plan on keeping the shocks just in case the ride is too rough but yea their will be springs under the seat.
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    Good to see you tried struts first. I know a few guys have welded it up and regretted it. The guys running shorter shocks looks good. I can't recall the bike they came off of though.
  11. Jason Orzel
    Cleveland
    ha yea its just turning into a Frankenstein of bikes right now but I'm having a blast doing it.
  12. mnrider
    mnrider Member
    Minnesota
    I have the same seat mount. Its a great seat mount but kind of tricky with these bikes. I just put a piece of flat stock across the two flatish tubes and made a fake tube come out of it and welded the mount to that. Not sure if you are using the original tank or not but I started there for length and went right at the bottom of where the tank ends and mounted it there. Hope that helps. bike looks cool though. Keep up the work and continue to have fun.
  13. Jason Orzel
    Cleveland
    yeah doesn't that cover up your fuse box and restrict access?
  14. Jason Orzel
    Cleveland
    ooohh i just re-read your post and now i think i got it! you ran a tube under the tank?
  15. mnrider
    mnrider Member
    Minnesota
    Here is kind of a rough picture of my mock up seat mount and tank mount. I removed the flat piece from the bracket for the seat to paint.
    willmarmnxj650 likes this.
  16. Jason Orzel
    Cleveland
    oh you went legit hard tail, yeah that makes a better angle for a springer seat... I am using stock tank and i am leaving the stock fuse boxon top of the air filter area and putting anything over that will get in the way... I have looked at your build before i like it, turned out great I still need to order bungs and springs then ill b able to mock up with cardboard and crap to figure out exactly what i can and need to do
    mnrider likes this.
  17. willmarmnxj650
    Willmar mn
    Very nice I likes it!
  18. RiceBiker
    RiceBiker Member
    San Leandro, CA
    I left enough of the frame to weld the mounts to. Made a bracket for the front mount.
  19. Jason Orzel
    Cleveland
    1) can i see your bracket
    2) what size springs are you rockin? 3" 4" 5"?
  20. RiceBiker
    RiceBiker Member
    San Leandro, CA
  21. RiceBiker
    RiceBiker Member
    San Leandro, CA
  22. Jason Orzel
    Cleveland
    Do you get enough comfort? I'm worried about the hard tail conversion don't want an unbearable ride I'm not small guy haha gonna need some cushion under me
  23. Jason Orzel
    Cleveland
    i think i ordered the same kickstand as you as well... I'm really at a stand still till i get my welder (and learn how to weld!)
