Tractor fender
Discussion in 'XJ Modifications' started by Coldpaw, Jan 12, 2016.
Tags:
  1. Coldpaw
    Coldpaw Member
    Central IL
    its for a 12 inch wheel arch may not be correct diameter to follow wheel
  3. Busted Knuckles
    Busted Knuckles Member
    North
    I have a fender off an 82XJ650 Seca if you're interested.
  4. XJ550H
    read this link from www.xj4ever.com you have plenty of choices
    http://www.xjbikes.com/forums/threads/xj-parts-catalog-section-n-body-and-frame.44632/
    Except for the XJ700, XJ750-X, and XJ900 models, the bolt hole size and mounting dimensions (where the fender bolts to the tubes) is the same between all models. The differences in the width of the fenders, at the mounting hole locations, is negligible. However, the "height" of the fender itself, relative to where it bolts onto the fork tubes, varies between different models by up to an 1" or so. Thus different model fenders may leave more or less "air space" between the fender and the tire when swapped between bikes with the factory original wheels and forks on them.
    All that being said, here is what we've found:
    XJ550 Maxim and XJ650 Maxim use the exact same (chrome-plated) fender. XJ650 Midnight Maxim fenders are the same fender as these, but are painted black rather than being chrome plated.
    XJ550 Maxim and XJ650 Maxim/Midnight Maxim and XJ750 Maxim/Midnight Maxim fenders will interchange, but are a bit "taller" (away from the fender mounting holes) than the XJ650 Seca style fender (about 1/2 - 3/4" taller).
  5. Coldpaw
    Coldpaw Member
    Central IL
    The problem here is that the frame has already been cut (badly and I'll have to clean it up, cutting it even shorter) by the previous owner. Also I should have mentioned that this is the rear fender I'm working on. I've seen a few members here who have cut down the original rear fender but I'm not looking to go that short. I'll look for some other fenders. I still have the original fender here but it was moved and mounted directly to the seat when I got it. I want to change that. I plan on using rivnuts to attach whatever fender I do end up getting back to the frame.
  6. Coldpaw
    Coldpaw Member
    Central IL
    I appreciate the offer but I still have the stock fender from my bike.
  7. XJ550H
    do you still have the plastic part of the fender?
    you might do better with the double fender for a trailer the straight portion may fit under the seat better
    Coldpaw likes this.
  8. Coldpaw
    Coldpaw Member
    Central IL
    I do have the plastic mud guard yes. I see what you mean about a tandem fender That may be just what I need.
    Something like this that I can cut down. https://imageserv3.team-logic.com/mediaLibrary/159/FENDER_EXAMPLES_3.jpg
