brake calliper not ligning up
Discussion in 'XJ Technical Chat' started by ant797, Jan 25, 2016.
  1. ant797
    ant797 Member
    western australia
    i tried installing my callipers onto rotors and noticed the frame with the rubber booton either side wasnt lighning up so i used a c clamp to push back in. i got the caliper on after that but it moves when pressing brakes and wont clamp all the way down. hence lever goes all the way in i took it offf and it clamps all the way down that way but not installed onto the rotor. any ideas ?
  2. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Sounds like air in the brake line for the squeezing lever issue. Pictures may be helpful for the alignment problem.
    Stumplifter likes this.
  3. k-moe
    Which model XJ do you have?
    +1 on pics.
  4. ant797
    ant797 Member
    western australia
    note the rubber boot squished right in. slide pins is what looking at i learnt. anyone know how to disasemble and service these idealy with no new parts
  5. XJ550H
    if you tell us what type XJ motorcycle you have we could post a photo like this that may help
  6. XJ550H
  7. ant797
    ant797 Member
    western australia
    its this assembly here where number 12-20 and also the pistons above i need to lubricate im just not sure if there pressed in
  8. ant797
    ant797 Member
    western australia
    its a 1986 xj750 p but its got mostly 83 seca gear on it so i think its just an older bike flogged off with a later year compliance plate from the factory
  9. chacal
    Calipers are XJ650 Turbo / XJ750 Maxim style.
  10. XJ550H
    link to manuals threads
    XJ750 manuals
    with detailed instructions for calipers
    go with the link I posted
  11. k-moe
    You might have a Mutt.
    Measure the inner fork tube diameter. I'm curious which forks you have.
  12. ant797
    ant797 Member
    western australia
    never mind i noticed some fluid and gunk leaking passed the seals of the cylinder musnt be enough pressure to push them in
  13. chacal
    It is a mutt, but it's a Deliberate Mutt(tm):
    XJ750 Police (24L, 33V, and 39Y models) used the XJ650 Turbo master cylinder with XJ750 Seca calipers and rotors, and XJ650 Turbo style forks without anti-dive.
    XJ750 Police (37H models) used the XJ650 Turbo master cylinder with XJ650 Turbo/XJ750 Maxim/Midnight Maxim calipers, XJ650 Turbo rotors, and XJ900 style forks with anti-dive.
  14. ant797
    ant797 Member
    western australia
    yeah a guy said it wa ex police that i got it off proberly y its still around
  15. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    . . . . like finding teeth on a hen.
  16. XJ550H
    does it have a digital speedo as well as an regular one?
  17. ant797
    ant797 Member
    western australia
    nah it just has the atari dash but also has a seperate switch for headlight
  18. ant797
    ant797 Member
    western australia
    realy just a slapped together cheap fleet veichle then the goverment wanted cheap bulk veichles so yamaha slapped together a bike with parts they had lying around there warehouse
  19. ant797
    ant797 Member
    western australia
    do you sell seal kits for the calliper i posted a pic of
  20. chacal
    Yes, please send us a message and we'll get you all the info on the parts and ordering info.
