howto check float level of carb
Discussion in 'XJ Technical Chat' started by Ramon, Aug 16, 2007.
  1. Ramon
    Ramon Member
    Germany, Frankfurt
    Well I like pics. They are easier to understand worldwide :D
    Was interested to check the float level. Put a piece of an antenna into the drain hole of the carb. Took it from an old radio. That fits pretty good. On that I put a flexible tube. Then you're done.
    Open the drain bolt and see what happens. Your float level will be visible. You need to check it for each carb. You even can leave the antenna on the carb. We are thinking about making a nicer solution on a lathe. Guess that's for the harley ones. :lol:
    I will make another pic which shows the whole setup live later.
  2. Sbmaxim
    Sbmaxim Member
    Never done this before, might check it out over the weekend.
  3. Ramon
    Ramon Member
    Germany, Frankfurt
    Just went through the manual for the details.
    The fuel level should be 5mm below from the carb mixing chamber body edge. You need to check each carb.
    Before you start make sure the engine is of well temperature. So let it run for a while. This is to obtain the correct fuel level. And place your bike on a level surface. Make sure the pet cock is "ON" or "RES".
    In case the fuel level is incorrect you have a minor problem. You have to remove the carb. You need to check the fuel valves and the float assemblys for damage. If no damage can be found you may correct the fuel level by slightly bend the float arm tang. I hope you don't run into a loop!
  4. TTF_DD
    TTF_DD New Member
    Nebraska
    great descriptive explanation ... thanks.
  5. kontiki
    kontiki Member
    Columbia, SC
    great photos ! Thanks!
  6. RickCoMatic
    My length of Vinyl Hose goes right into the Hole and stuffs in there nice.
    Although the antenna piece was good thinking!
  7. MiCarl
    That loop shown in the picture and implied in the diagram will cause problems if it traps an air bubble up at the drain (Trust me, I've done it).
    Solution is to get the hose filled and then lower it to take the reading on the side of the carb.
  8. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Right on Ramon!! Good Illistrations and ideas.
  9. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    I must say I am absolutly horrified of carbs.
    Worse than a horror flick to me.
    But this sounds like a job for me.
    I assume the bike is on the center stand for this procedure
    My haynes manual should prob show this as well?
    Got to find that book one of these days
    Thanks for the help ramon
  10. chacal
    Although it's fun to be adventurous, creative, and daring at times, wrenching on the bike is not one of those times......
    The ever-popular Haynes Workshop line of "enhanced" factory service manuals cover all major service, repair, rebuild, and maintenance procedures (sometimes in excruciating detail, and usually with many more pictures and illustrations than the factory service manual does), and also includes wiring diagrams and other useful specifications.
    HCP1093 Haynes Service-Repair-Maintenance Workshop Manual, for all 1980-84 XJ650 (except Turbo) and XJ750 models, softcover, over 275 action-packed pages, a must-have manual if you own one of these machines. Each:
    $ 25.00
    HCP1092 Haynes Service-Repair-Maintenance Workshop Manual, for all 1983-94 XJ900 models, hardcover, over 210 pages, even has a nice color-coded wiring schematic, bless you guys at Haynes! Cover itself is pretty enough to be a coffee-table book. Each:
    $ 33.00
    Plus reasonable shipping:
    USA:
    Media mail (cheap but can be very slow): $ 4.90
    Parcel Post (7-14 days): $ 6.90
    Priority Mail (3-5 days): $ 8.95
    Canada:
    Priority Mail International (3-5 days): $ 9.90
    Overseas:
    Inquire by country. Ranges from affordable to outrageous........!
  11. kerstingm
    kerstingm Member
    Columbus Oh
    You are showing putting a tube into the bowl I thought the hose went on the stub sticking out of the center next to the screw. or does this depend
    on what type of carbs you have?
  12. RickCoMatic
    There are No "Stubs" on some Float Bowls. Their is a small diameter cylinder that the hose inserts in to ... the fit is fluid tight.
    Depends if you are adjusting Mikuni or Hitachi.
  13. thefox
    thefox Member
    Central NY (@ college in W. PA)
    Does it have to be running? If so does it matter how well (as in no air box boots attached)? I adjusted my height last week with the engine off, my bike will run ok with the boots off and there is no way I will put those boots on unless the cars are staying on the bike (not like I can get them on anyways…).
  14. RickCoMatic
    No.
    Not running.
    Just stationary and level.
    If you have a Float Level Ruler ... you can measure the Tang on any one that is correct and bring the others to the same height in one fell swoop.
  15. schmuckaholic
    California
    They're actually not that difficult to disassemble and reassemble, once you've done it a time or three. I bought a spare set to practice on before I tore into mine. It's getting them set up again afterwards that can be a real PITA. On my machine, as of late, I've synced, synced again, tweaked mixtures, and something's still not quite right, because the idle's funky... but that's another thread.
  16. kerstingm
    kerstingm Member
    Columbus Oh
    Right after I posted this I saw another thread and my question was answered about the differant styles
  17. Energi2er
    Energi2er Member
    Northwest
    I broke down and bought me a book today "The haynes motorcycle fuel systems techbook" It explains what happens from the airbox, all the way to exhast, including full detail of carbs. After taking apart mine and putting them back together, it got me curious.
    Link to the book on amazon
  18. RickCoMatic
    I hope they corrected the misprint that has befuddled so many using Haynes as a reference for Carb Cleaning Hitachi Carbs.
    They misprinted the values of the Main AIR Jet and Pilot AIR Jet, thereby causing many of those who removed them during cleaning to misplace them during reassembly.
    When you've just "White-gloved" a set of Carbs and followed the procedure to the letter ... it's hard to imagine why the Bike won't run right ... particularly if you double-check your work and find everything is done according to the book.
    Just remember:
    The Main AIR Jet is Opposite from the Main FUEL Jet which is LARGER than the Pilot FUEL Jet.
    Thus, ...
    The Main AIR Jet is Smaller than the Pilot AIR Jet.
    Smaller diameter Metering Port.
    I'd go look that up in that Book you bought and see if they got it straight, yet!
  19. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Like Rick said it doesn't have to be running. In fact the carbs don't even have to be on the bike. But if you are checking with the carbs on the bike and the engine is not running then the petcock should be on "PRI". This way fuel will flow through the carbs. With the engine running "ON" or "RES" is fine.
  20. Energi2er
    Energi2er Member
    Northwest
    Actually I havent found anything about hitachi in the whole book, its all mikuni and a few other brands. But they all work generally the same way, I have learned alot about what carbs are all about.
  21. chacal
    They haven't........
  22. RickCoMatic
    If they had any idea how screwed-up they made it for some people who trusted that text and removed the Air Jets (unnecessarily) ... they ought to send a check to every person who bought the book refunding the money they spent on it.
    At least three people in here have gotten burned ... and, I imagine there are countless others who delved-in to Carb Cleaning and did the same thing.
    I really think, at this stage in the game, that there ought to be a "Special Edition" dedicated strictly to Mikuni and Hitachi Carbs for those people who have older bikes and can't find a decent Dealership that will give them the time of day.
    A nice 200-Page ... Photo and instruction ... plus Special Tuning Section would be a nice thing to find under the tree this Holiday Season.
  23. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    With all these carb problems why don't we just make a manifold and put a Holley on it?
    Rick please don't have me killed for suggesting it.
    It's just that I do Holleys in my sleep.
  24. TIMEtoRIDE
    Santa's bringing me clear acrylic float bowls !! I wish !
  25. RickCoMatic
    I'm laughing at suggesting the Holley. If it would go, I'm sure there are Hot-Rod guys in here that would rather have the Holley than a 4-Pack of Carbs that need Syncing and tuning.
    Holley is one of the easiest Carbs to make tuning changes too. Just buy some Holley Jets and lift off the covers ... whammo ... rejetted ... no muss or fuss!
    I only have a problem with the Holley Power Valves. Blew a power valve on day onn the way to work and it looked like the Camaro was fogging the countryside to get rid of mosquitoes!
  26. greg_in_london
    greg_in_london Member
    London
    Just wondering if people can helpout as I have mine off the bike - has anyone written down the float height after they've got the petrol level at the 1-2mm below mating surface level.
    Maybe I'm just a Luddite, but I really like a a number/measurement that I can use to set the float too - I always seem to move the clear plastic hose and it never seems very exact to me, plus the outer two drain screws are corroded in.
    I found a site that said 15-17mm for the BS28 Mikuni, but they wouldnt go that low (and the carbs would then flood) while someone else said that 'all carbs of that period' are set to 21 mm.
    Has anyone written down their measurements ?
    Many thanks.
  27. twerth
    twerth Member
    Parkville, MO
    My bike has BS33s and the manual says to set them at 17mm, but like yours, they wouldn't go that low. I set them at 23mm and the level is about 3mm below the top of the bowl.
  28. greg_in_london
    London
    Thanks Twerth
    I'll set them at 21-22mm then and that should be about right.
    Now I just need to see if the spare/replacement carbs have got better diaphragms than the ones I took out ...
    Greg
