maxim X valve shim
Discussion in 'XJ Technical Chat' started by toolman, Feb 1, 2016.
  1. toolman
    toolman Member
    NS Canada
    are maxim x shims 7.5 or 9 mm in diameter
    thanks
    Toolman
  2. xHondaHack
    Orange CT
    The valve stem diameter is only 5mm. I just measured the outside of the shim and it's 7mm.
    Tony
  3. toolman
    toolman Member
    NS Canada
    thanks for the reply Tony. when I checked with my local stealer they told me that the shims (adjusting pads) would be either 7.5 or 9.0 mm.
    not to question your ability to measure but could there be 7mm shims just for the Maxim X.
    thanks
    Toolman
  4. Devin7717
    Devin7717 New Member
    Nebraska
    I don't mean to hijack forum but I havent been able to find how to make a new post...
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Go to the 'base forum' you wish to post in (Technical Chat; Hangout Lounge, etc.).
    In the upper right hand corner just underneath the Search box there should be a button to Post New Thread.
  6. k-moe
    If they don't know exactly which it is, then find another shop to buy parts from (I know a place that isn't difficult to find it you glance around here).
    The Maxim X shares the basic engine design with the FZ750 and Fazer, so it does not have a special sized pad.
  7. toolman
    toolman Member
    NS Canada
    I agree 100%. and thanks for the additional info.
    So when shopping on eBay, 7.0 mm shims is what I should be looking for not 7.5 or 9.0?
    thanks
    Toolman
  8. quebecois59
    there is no need to shop on ebay to buy shims, there is a shim pool here.
  9. toolman
    toolman Member
    NS Canada
    thanks for the info on the shim pool. I did know about it.
    I would like to have my own selection of shims.
    guess I need to order one and measure when I get it.
    Toolman
  10. XJ550H
    I went to local dealer asked for 29mm shims 3.45 thick. After looking in the book for 20 minutes they told me they do not carry 29mm thick shims. I only go there for my inspection now.
    cnewman likes this.
  11. toolman
    toolman Member
    NS Canada
    all I'm trying to do is find out what diameter maxim X shims are.
    I never expected it to be this difficult
    thanks
    Toolman
  12. quebecois59
    xHondahack member said he measured one at 7 mm, what is difficult to understand there?
  13. toolman
    toolman Member
    NS Canada
    did you ever get a second opinion on anything?
  14. quebecois59
    7 mm is not an opinion , it's a measurement.
  15. toolman
    toolman Member
    NS Canada
    and what a nice person you are to point that out to me.
    just my opinion
  16. XJ550H
  17. quebecois59
    searching ebay with "maxim-X valve pad" gave me several good results, more consistant results than with "maxim-x 7 mm valve pad" or "maxim-x valve shim". No flat shim is suitable for the Maxim-x.
  18. Polock
    if you measure the clearance, then take the tight ones out so you know what thickness to get, you can measure the diameter. then there's no doubt about it
    Stumplifter likes this.
  19. toolman
    toolman Member
    NS Canada
  20. XJ550H
    http://www.maxim-x.com/index.html
    good sorce of info for you they have a shim pool and its about both x 700 US and x 750 canada model
    motor differance is the stroke shims should be 7.5mm as the US X700 is.
    I have no Canada parts supplier lists
  21. quebecois59
    1985, 1986, 700 or 750, US or Canadian, they all use the same shims.
  22. hogfiddles
    What size shim do you need? I'll check my pool....... Yes, believe it or not, i do have a very small and limits shim pool for the X
  23. XJ550H
    say it ain't so:(
    He wants to buy a kit
  24. hogfiddles
    I guess I missed that on the first readthrough… If you wants to buy a kit fine, whatever…
    As far as shim diameter, it doesn't really matter as long as it still fits inside the bucket! 7 mm, 7.5 mm… Inside of the bucket is a lot bigger than that-
  25. dirtymike
    dirtymike Member
    You need to measure your clearance(feeler gauge) in order to find out what puck you need. As time passes the shim(puck) will probably be thinner as the valve is pushed further into the seat.
  26. xHondaHack
    Orange CT
    Just want to clear up any confusion.
    Yes a 7.5mm shim will fit inside the bucket, however the valve stem diameters vary between models. As far as I can tell, the current kits are not compatible because they need to fit on the 5mm valves on these models:
    FZ700T 1987 700 FZ700 Street
    FZ700TC 1987 700 FZ700 (Cal) Street
    FZ750N 1985 750 FZ750 Street
    FZ750S 1986 750 FZ750 Street
    FZ750SC 1986 750 FZ750 (Cal) Street
    FZ750T 1987 750 FZ750 Street
    FZ750U 1988 750 FZ750 Street
    FZ750UC 1988 750 FZ750 (Cal) Street
    FZR1000T 1987 1000 FZR1000 Street
    FZR1000TC 1987 1000 FZR1000 (Cal) Street
    FZR1000U 1988 1000 FZR1000 Street
    FZR1000UC 1988 1000 FZR1000 (Cal) Street
    FZR750RT 1987 750 FZR750R Street
    FZR750RU 1988 750 FZR750R Street
    FZX700S 1986 700 FZX700 FAZER Street
    FZX700SC 1986 700 FZX700 FAZER (Cal) Street
    FZX700T 1987 700 FZX700 FAZER Street
    FZX700TC 1987 700 FZX700 FAZER (Cal) Street
    FZX750S 1986 750 FZX750 FAZER Street
    FZX750T 1987 750 FZX750 FAZER Street
    XJ700XN 1985 700 XJ700 MAXIM X Street
    XJ700XNC 1985 700 XJ700 MAXIM X (Cal) Street
    XJ700XS 1986 700 XJ700 MAXIM X Street
    XJ700XSC 1986 700 XJ700 MAXIM X (Cal) Street
    XJ750XS 1986 750 XJ750X MAXIM Street
    I wouldn't use anything not compatible because you will potentially have a shim that doesn't seat on the valve correctly.
    Unfortunately doing a shim swap does take some time. You will have to measure all of the clearances, pull the cams and find out what shim is on the ones that are out of spec, and calculate the appropriate shim to get you the correct clearance needed. Swap your existing shims around to help minimize the new ones you need, then visit a reputable shop in your area to help you get the remaining ones you do need. Not the cheapest solution, but will help if you need to get back on the road quickly.
    With that said, this kit shows to be compatible with the 1987 and 1988 fzr1000 models that is included in the above list:
    https://www.denniskirk.com/hot-cams/valve-shim-kit-hcshim01.p148751.prd/148751.sku
    You could purchase at your own risk and see if they will work on the X model you have.
    Tony
  27. toolman
    toolman Member
    NS Canada
    I would first like to thank you all for responding and providing me with some valued and detailed information.
    I run my own shop and have many customers that bring to me an assortment of bikes to repair.
    I primarily work on Yamaha V Maxes and Ventures and currently own 7 V Maxes and 1 Venture. I provide engine tuning, rebuild motors, transmissions, carbs, starters, forks anything you can imagine.
    With that said I have worked on a couple of Maxim X’s in the last little wile and now own an 86 750X that I’m going to do a complete frame up restoration on. I plan on expanding my services to include tune-ups on the smaller Yamaha's.
    I already have an extensive collection of 25 and 29mm shims if anyone needs those sizes. The idea of a shim pool is great for the guy tuning his own ride, but for someone like myself I will need to have a good selection of shims on hand. I plan on buying on flea bag or wherever I can purchase them in order to establish my own shim kit.
    This forum is a great place to exchange information and my hat is off to everyone (not just to those that replied)
    Thank you all
    Toolman (a proud new owner of a 1986 Maxim X)
  28. quebecois59
    I've owned a 1985 Maxim-x , it was a great bike, it pulled hard and the engine ran very, very smooth once properly tuned up.
  29. hogfiddles
    We do have a few members who run shim pools.... There are shim pools in NY, CT, Ontario, and a few others. Some specialize in the Maxim X shims, others in the airhead shims. We also already have our supplier that has any size that is needed.
    I have never seen MaximX shims that have differing inside diameters... Heck, for that matter I've never seen any that have differing outside dimensions, either-----
    My pool is primarily for the airheads, which are all 29mm shims, but I do have a small pool of X shims, as well as a fairly extensive pool of the 25mm shims for people who may have the Venture/and other make/models that take that diameter shim.
  30. toolman
    toolman Member
    NS Canada
    if you need any shims let me know what size 's you're low on. The only charge is shipping and they are yours FREE for the pool. I also have the tool for the 29mm shims if anyone needs to BORROW that.
    Toolman
  31. hogfiddles
    Private message sent---
    Whew.... That poor vmax in your avatar--- looks like it overheated.... LOL
  32. XJ550H
    just a little heat from reentry
  33. toolman
    toolman Member
    NS Canada
    yes sir that was one HOT bike
    Toolman
  34. toolman
    toolman Member
    NS Canada
    if anyone has 7 mm shims for a 1986 Maxim X I have extra 25 and 29mm shims you might need.
    lets make a deal.
    Toolman
