Oil cooler? What do you think?
Discussion in 'XJ Technical Chat' started by Fionnbarr, Aug 11, 2007.
  1. Fionnbarr
    Fionnbarr New Member
    Ontario, Canada
    Saw an eBay ad for a Lockhart Oil Cooler for an XJ. (Item #140145329276 for the curious...) Never heard of such a beast, but am intrigued. What do you folks think? Advisable, or would it just muck things up?
  2. samsr
    samsr Member
    Colorado Springs
    I dont know much about the aftermarket oil coolers but I would say that I reallllllly like my stock oil cooler that I put on my xj700. Keeps the oil much cooler than without one And as we all know COOLER OIL IS BETTER. Also increases the amout of oil that the bike holds, as an added bonus. My adapter is from fron an 1982 xj650rk. Thats the secal turbo version. These can be hard to find at times. The cooler portion and lines are from a xj900 I believe. These can be fairly easy to find.
    In conclusion, if you can find an oil cooler to install DO IT. You will not be dissapointed with the results. coooooooler.
  3. RickCoMatic
    The XJ-Bikes run coolers off an adapter plate that goes on before the Oil Filter and becomes the Oil Filter Platform.
    I relocated the Horns on my 750 Maxim to run a large, XJ900RK Oil Cooler on the Max.
    Strictly a Bolt-on affair after you make-up a mounting plate that gets bolted to the frame using the two captive nuts the Horns are mounted in.
    Initially, I had a problem with the Lower Pinches if the Triple Tree hitting the Top of the Oil Cooler. Once I dropped the cooler down about 4 cm it cleared the top and everything is fine.
    A Cooler is a nice way to make the engine run a little bit cooler. But the Oil getting cooled will do wonders for extending the life of the Cams, Bearings and Rings.
    It you can make it work without a leak and ALL the mounting pieces are there...
    Do it!
  4. Fionnbarr
    Ontario, Canada
    Missed the end of the eBay auction, but will keep an eye out for another. Sooner or later, all good things come to eBay.
  5. jathomas42
    jathomas42 New Member
    Houston, TX
    The European XJ650RJ came with a stock oil cooler. The American version did not. I installed a Lockhart cooler shortly after purchase in 1982: no leaks, no problems. My bike spent almost 15 years on blocks, but rehabilitated 1 yr ago and runs great. Not exactly evidence in favor of the oil cooler, since the bike only has 33K miles, but I figure it can't hurt to have adjunct solutions for engine cooling in the great HOT state of Texas. Your decision probably depends as much on where you live as anything.
  6. Robert
    Glad to hear words of wisdom from an original owner, you folks are rare! Welcome to the forum Jathomas42.
  7. RickCoMatic
    The engine doesn't know where it lives. It only knows that it prefers running on oil that been circulated through a cooler.
    You could be cool and find a UK Member to help you locate an Oil Cooler Package off a European Model form a "Breaker" in the UK.
    Since it don't weigh very much; it might enjoy the trip "'Ore the Pond" to find a new job keeping your "Mill-Chilled"
    It would be an easy bolt-on situation.
  8. jathomas42
    Houston, TX
    Thanks for the welcome. Am sure I will learn MUCH more than I can contribute, but I love the bike and am sure the community will be fun.
  9. Fionnbarr
    Ontario, Canada
    Where's the in and out on the engine for such a beast?
  10. Robert
    Right out of the front of the block. The oil filter bolt passes pressurized oil right through the filter. The standoff cooler plate sandwiched between the block and the oil filter housing is the port. I've got two of the assemblies, I guess I ought to photograph them carefully and post the pics.
    Bear in mind that an oil cooler plate is available from one of our members, his link is at the top of the page in the Chat forum. $70USD or thereabouts.
  11. schmuckaholic
    California
    Time for me to resurrect another long-lost thread... or beat another dead horse until it's glue. Take your pick.
    I saw listed recently (as in tonight) an oil cooler made by Derale for the 1986 Yamaha XJ700S XJ 700 S/SC Maxim X.
    Not knowing much about these things, would this by any chance fit a stock 82 750? Namely, mine?
  12. TaZMaNiaK
    TaZMaNiaK Member
    NJ
    The important fit would be the oil filter sandwich adapter. If that fits, then the cooler itself can be made to fit. I am waiting for XJ Monster's spin on adapter with the cooler attachment, and I plan to use a small aftermarket oil/transmission cooler, rather than risk getting a parted out setup that isn't in the best shape and could wind up leaking on me.
  13. schmuckaholic
    California
    That's what I'm trying to find out. That and the bolt part thingie it comes with.
    I thought that was (a) still in the prototype/testing stage, and (b) having issues with keeping the same amount of pressure in the system as the stock oil filter.
  14. chacal
    Why would the addition of an oil cooler (or even a spin-on filter) change the amount of oil pressure in the system? Either change will require the use of more OIL in the system, but that shouldn't change the pressure......?
    BTW, as long as you have the factory oil cooler "adapter plate"---which is the part of the oil cooler system that the input/output lines bolt onto, it's the big round ribbed cast aluminum housing that actually fits into contact with the engine block machined pad---then the currently available spin-on oil filter adapter works just fine (it will go "on top" of the adapter plate).
    The "oil cooler" version of the spin-on filter adapter is only needed if the factory "adapter plate" is missing.
  15. schmuckaholic
    California
    I don't think it was the addition of the cooler so much as it was the automotive filter being used. The author was detailing how he was trying to match the oil pressure using a spin-on filter to using the stock Yamaha filter. I'll have to see if I can dig that up again; I don't remember if it was a thread I saw on here or if it was somewhere else on the net.
    <eyebrow> Is/was there such a beast available for the 750J Maxim?
  16. chacal
    The 750 Maxims never used a factory oil cooler....at least, not the North American versions.....but the factory oil coolers from a 650 Turbo model (1982-83) or a 900 Seca model (1983) will work with a little bit of effort (mainly, making brackets to hold the oil cooler itself to the frame....everything else about the oil cooler system is bolt-on and will fit your bike correctly).
    The 900 oil cooler is physically larger than the one used on the 650, and may require a bit more fiddling to get it to fit the 750. Either one will provide more than enough oil cooling even in the summertime. In fact, when I installed one on my bike, I added an in-line thermostat that bypasses the cooler until the oil temp reaches 180+.
    Once you get all the correct parts and pieces, figure about a long afternoon's work on installing it and getting things aligned, etc.
  17. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I'd be interested in seeing this turned into a How-To. Do you still have part numbers for the oil cooler and bypass t-stat?
  18. chacal
    Well, the oil cooler I bought a complete used assembly, I can't remember whether it was off eBay or off this list or one of the other lists. I replaced all the replacable parts (o-rings, mounting bolts, by pass springs, etc.) and then bought a small remote oil cooler thermostat (some auto racing application) and cut the cooler lines and adapted the thermostat in.....it uses 1/2" NPT fittings, and it's small and light enough to just be able to "hang" in place without any additional support.
    I can't remember a brand name for the thermostat but it was very small, and it actually always allows oil to circulate thru the cooler---it stays open 10% below 180-degrees (and bypasses 90% below 180-degrees) to allow the cooler to always stay filled and active and prevent air pockets from forming within it, which I thought was a very good idea. Above 180-degrees you get full 100% oil flow thru the cooler.
    I'll look at it next time and see if I see any part numbers or mfg. ID on it.....
    The spin-on adapter plate I bought from XJmonster but have since machined some myself, and they are available for sale in my parts list, along with the mounting o-rings and spin-on oil filters:
    http://www.xjbikes.com/Forums/viewtopic ... rt=45.html
    It's a neat set-up and work well, hasn't leaked a drop of oil since installed over a year ago.
  19. schmuckaholic
    California
    ...but not a 900/900F?
    Reason I ask is just for gits and shiggles I bopped over to ebay's UK site. It promptly spit out one for the 900 (no mention of a Seca), complete with adapter plate. He says he's willing to ship overseas, but only if he's certain the item will fit the target bike.
    Failing that, I sent an email to some place in Texas; I looked up the number for the adapter plate for the 650 Seca, let Google do its magic, and one match came up (a successful Googlewhack!). We'll see if they respond.
  20. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    The 900 should be OK. All the original XJs have the same filter arrangment. Even the X models might be the same but the later Diversion/Seca II are most likeley different (might be wrong on that). I have a 900 fitting on my 750D.
    The reason there is no mention of Seca is that the Scea/Maxim is a North American thing, rest of world goes by model letter after the XJ750, e.g., R, RJ etc.
  21. schmuckaholic
    California
    F model wouldn't indicate a Seca, though, would it?
    In any event, it's irrelevant... I reread the email "Nigel" sent, and his other condition for shipping overseas is that the buyer use Paypal, which I flat-out refuse to do.
    Anybody wanna buy an oil cooler for an XJ900/900F? Complete with adapter plate? Buy It Now price is only 20 pounds...
  22. chacal
    I'm interested!
  23. schmuckaholic
    California
    So was someone else, it seems... they done went and bought it, y'all. ;)
  24. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    It's a Seca, the cooler would have fitted.
    OK fess up who brought it? :D
  25. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    900F sounds like a Honda cooler.
  26. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    I've ridden a couple of those old Hondas. Stable on the road, great brakes too. Heavy as!
    As long as the add said Yamaha, there is a 900F.
    Yamaha XJ900F
  27. RickCoMatic
    Same cooler as on the XJ900RK ... Nice one. Got that cooler, lines and adapter bolted-on my 750 Max. Looks like it came that way.
  28. schmuckaholic
    California
    Okay. Bringing this thread back to life again.
    I did manage to find an adapter plate; the guy was selling it and ONE oil hose from an FJ600; after checking with the Yamaha parts site and finding that it was the same adapter plate used on the 82 650LJ, I bid and won.
    Next question would be which radiator/lines are compatible with this adapter plate on a 750 Maxim (besides Rick's 900RK). The one oil line I have obviously matches with the FJ radiator, but not the Seca. I saw one setup for an FJ1100 on ebay, but that one doesn't even look like it uses an adapter plate.
  29. chacal
    You need to use the oil lines for an XJ650 Turbo, the others will have the wrong configurations and/or fittings......
  30. Robert
    If you are resourceful, you can fab new lines but the cost for fittings can be a down side. Keep scouting Flea-Bay, they will turn up someday.
  31. Jackncoke
    Jackncoke Member
    Alton, Illinois
    Schmuckaholic:
    For the XJ750, you can try to find an oil cooler from an XJ650 Turbo here in the states. I am pretty darn sure that the 700 and 800 are much bigger diameter and will not fit on the 750. The bolt that holds the cooler to the block is interchangeable though.
    I am able to get ahold of 3-4 of the plates for the 700-800, the much wider ones, but not sure about the radiator part. I think I would pay around $30 for them. I will check to see if they have anything the next time I go there.
  32. schmuckaholic
    California
    Again: I have the plate and its mounting bolt. I need hoses and the radiator.
    Bonus: someone's selling a pair of apparently unused aftermarket coolers, complete with adapter plates, one for a 550 and the other for the 650/750:
    650 Maxim/750 Seca
    550
    Bid early and bid often!
  33. chacal
    Hey Schmuckster, those aftermarket coolers have a bit of clearance problems fitting some of these bikes. The radiator is MUCH wider than the stock one off of the 650 Turbo models.
    I have a good used radiator and hoses set available, write me if interested..... I would strongly suggest replacing the cooler and adapter plate hose o-rings.
    Also, now would be the perfect time to add the world famous (or is that Infamous?) Spin-On Oil Filter Conversion Kit that I offer, as it allows you to use a mini-can type oil filter and get rid of that atrocious factory paper element filter, housing, and bypass bolt system. It's completely bolt on with the stock cooler adapter plate that you have, and gives you the ultimate in oil filtration and protection for your engine.
  34. Jackncoke
    Jackncoke Member
    Alton, Illinois
    Schmuckaholic:
    Sorry ha ha ha, i feel kind of dumb, I was looking at the first page and missed the second one....
  35. schmuckaholic
    California
    Well, somebody DID bid early and often on those aftermarket coolers... the one for the 650/750 ended up at $122.50. 8O (They must have wanted it *badly*.) For the 550, only $39.
    So I noticed. I didn't figure that would be much of an issue, but as I didn't bid, the question is academic.
  36. schmuckaholic
    California
    Bumping this thread.
    I am being havink adapter plate. Thanks to Jackncoke, I now also being havink hoses and cooler. Now, about these mounting brackets... anybody got some pictures so I can get some kind of idea as to what to try and fabricate?
  37. chacal
    There is an old thread in the forums about this issue, I think if you search "oil cooler" it will turn up. I'd say at least a year old. Some good pictures, although if you start holding things up onto your bike/frame, you'll quickly see what is necessary!
  38. Robert
    I have the lower bracket out, I'll shoot some photos. The upper bracket is simply a ring welded to the gusset to hold a grommet.
  39. Robert
    I posted the photos in my gallery, let me know if you want more or send me an email address and I'll shoot them to you in the file type of your choice.
  40. schmuckaholic
    California
    Okay, so the lower bracket is pretty much just for keeping the hoses from flopping around, is that it?
    As for the upper, it sounds like that's the more important of the two. I'll see if I can dig up that thread and see what the upper looks like.
  41. RickCoMatic
    I mounted a cooler fromm a 900 on my bike. I had to make a bracket to keep the lower part of the tree from hitting the cooler. This also meant modifying the upper mount to fir the braze-on on the 750 frame.
    The lines up fromm the cooler got moved to a front-back configuration instead of side-by-side and the horns got moved to the back-end with an extra noise-maker clamped to the SlipStreamer Fairing bracket.
    I used Large industrial-strength tie-wraps to bind the hoses together to prevent them from flapping around and a home-made extension with O-rings as dampers for the insertion into the Brazed-on bracket.
    The results were outstanding.
    I have a large oil cooler mounted on a 750 Max and it does a bang-up job of keeping the engine temp regulated a bit cooler than without.
    Seeing as I have been deliberately been running 'On-the-lean-side' ... I'm sure the cooler has come into play regulating engine temps; too!
  42. Robert
    I'll shoot you a pic on the upper ring tonight. I also have the large retaining bolt for the stock plate and can snap some photos of that for you too.
  43. schmuckaholic
    California
    (snippage)
    I wouldn't mind seeing some pics of your setup, if you don't already have them in your gallery somewhere. I finally got the time to hold the whole thing up in front of the bike, and it looks like I'm running into the "horns are in the way" bit. If nothing else, it gives me an excuse to run out and get something louder. :mgreen:
    As for the lower mounting bracket, I thought that went into the bottom two holes on the cooler; silly me, I discovered after some forum searching that those holes are for bolting the cooler to the *Seca frame*. Oh, so sorry; no Seca frame, no mounting holes. Those holes on the cooler look like they line up with the horn mounting bracket, though...
  44. acergremlin
    acergremlin Member
    NE UK
    Removed mine from both the 650 and the later 600 due to leaking metal pipes, seem impossible to get unless you get then custom made and just not got the time at the moment to hunt out someone to make them for an affordable price. The adapter plate for both was the same.
