Hello from Minnesota!
Discussion in 'Hangout Lounge' started by Derson59, Feb 16, 2016.
  1. Derson59
    Derson59 New Member
    Bloomington,MN
    Hello all,
    I just became a member on here after I bought my first bike. I ended up getting a 1982 XJ750 Maxim. I bought it on craigslist for pretty cheap, it wasn't running so it was REALLY cheap. But so far I have cleaned up the carbs and inspected the fuel tank. Tanks was clean with NO rust, there is a plus there. Carbs were pretty gummed up, one diaphragm piston and float didn't even move. I got it free and everything looked really good on the inside except for the bowls(duh). But I got it running last summer but unfortunately not completely "roadworthy". I am in the process of rebuilding/mods to the bike. I fear that I have now the "itch to ride". I got divorced last year so now I have TONS of time to fix up the bike and get riding.
    I just thought that I would check-in and say hi.
    Derson59
    just dont put pods on it. if you must get it running correctly first to eliminate any problems.
    then go pod and try to fix the issuses that arise
  3. Derson59
    Derson59 New Member
    Bloomington,MN
    Sorry let me clarify, by "mods" I mean to fix the mods that the P.O. did to the bike, lots of cut corners mainly in the electrical system. I already took the toggle switch off for the horn which was taped to the side of the handle bars.
    k-moe and Stumplifter like this.
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Welcome,
    We have a few that like to ride down to Peppin and come back in the Wisconsin side.
    I will post dates when it gets warm
  5. Derson59
    Derson59 New Member
    Bloomington,MN
    that sounds like a great ride.
  6. Steve M.
    Steve M. Member
    Bedford co va
    Welcome, nothing says PO wiring louder than a toggle switch.except maybe tin foil wrapped fuses :eek::eek:
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    or morettes!
  8. Derson59
    Derson59 New Member
    Bloomington,MN
    I found the foil too on the fuses..
    MattiThundrrr likes this.
  9. MN-Maxims
    Saint Paul, MN
    Sounds like it needs a good going over and getting rid of PO bugs. Don't forget the brake lines are more than likely expired and the shoes and pads can and will delaminate if they are original.
  10. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard.
    Gary H.
