Help! What are these bolts?
Discussion in 'XJ Technical Chat' started by MikeMatt, Feb 18, 2016.
  1. MikeMatt
    MikeMatt New Member
    Calgary
    This may be a dumb question, but I have recently picked up a great little xj550 Maxim (1981) from an older man who had it in the barn for 20 years. I've got it running and am really enjoying building the project, but I have come across these bolts/plugs on each side of the engine.
    I have circled them in the picture, and was hoping someone could identify their purpose. Thank you!
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Do not try to remove the bolts they are part of the oil passage and are used for machining the block. They are easy to brake if you try to remove them. Nice looking bike.
    Alan63 likes this.
  3. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    IIRC you could drain the engine oil using either of these bolts, but as stated above they are easy to break and the proper drain plug is so much easier to use. Leave them alone.
  4. MikeMatt
    MikeMatt New Member
    Calgary
    Thanks for the feedback!!
  5. lostboy
    The rear brake foot arm looks a bit high. Is should be level with the foot peg or slightly lower. Still a good looking bike.
  6. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    True that.
    I believe XJ 650 Maxim is supposed to be 1/8" above foot peg top.
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard. I agree it's a good looking bike. The rear brake lever should have a location detent that should align with a marker on the spline. Looks like this...
    Gary H.
  8. k-moe
    Oil will come out of those holes, but only with the engine running. The sump is below them.
  9. Steve M.
    Steve M. Member
    Bedford co va
    I wish my xj looked that nice.... Heck, I wish any of my bike's looked that nice.
  10. k-moe
    Go > show.
    Stumplifter likes this.
  11. Steve M.
    Steve M. Member
    Bedford co va
    true, mine do go faster than they look it's that sleeper thing.I really enjoy that look you get when they pull up at the next stop light.I call it the how did that just happen look.Its priceless...
    rocs82650 and Stumplifter like this.
  12. XJ550H
    you need rear brakes. your adjuster on the drum is too long your pedal should be aprox 20 mm below foot pedal .adjusted to suit your foot movement more than the spec
    it has an level adjuster at the front of the brake rod
    read this link
    SAFETY ALERT Drum rear brake bike owners please take a look
    you will have to make your own mark on the spline when you remove the lever
    rocs82650 likes this.
