Humidity problems.
Discussion in 'XJ Technical Chat' started by ColtonS3290, Jun 7, 2015.
  1. ColtonS3290
    ColtonS3290 Member
    Ok, my 83 maxim has a weird issue that I can a not find a fix for. On hot dry days it'll fire up, run fine all day for hours no problem. On days cooler than 70 degrees the spark plugs won't fire and on days after it rains and it's a bit more humid than others I'll be riding it and it will kill as if I hit the kill switch and it will not start back up for about 20 minutes. As if the sparks aren't firing again like on the days under 70 degrees. It so frustrating riding on the highway and having it kill. I have no idea what the problem is or where to evan start looking. All the connections are fine and all the rules are good. Is this a common problem among the maxims?
  2. k-moe
    You probably have cracked plug wires, or cracked coil housings. To confirm you can start the bike in a dark garage, or at night. If you see a lightshow, well...that's your problem.
  3. XJ550H
    a quick mist with a spray bottle on a good day may replacate the problem. I would try the dark garage first.
  4. ColtonS3290
    ColtonS3290 Member
    I have called a electrical guy about this problem and he was saying it could be multiple things, but wants me to look into the stator, he said they go bad commonly with the older xjs (His words) or possibly that there might be flooding in the carbs. I'm not to sure about the stator because i still have power to the lights, horn and turn signals. Doesn't the stator charge the battery? I'm not to familiar with the stator.
  5. XJ550H
    the stator is part of the alternator
  6. XJ550H
    start by ohming out your charging system info on how is in the
    The Information Overload Hour
    do the same for your ignition system
    what maxim do you have??
  7. ColtonS3290
    ColtonS3290 Member
    Vin says it's a mid max 750.
  8. k-moe
    No they don't.
    Carbs flooding won't keep the plugs from firing, and you would have wet plugs, and it wouldn't be related to the humidity, and it wouldn't suddenly happen while you're already riding.
    Your electrical guy does not sound like good source of help for this problem.
    What were the results of checking the plug wires and coils for cracking?
  9. ColtonS3290
    ColtonS3290 Member
    I started it at night as well as sprayed around the coils and plugs with mist. However I did not see any light show or have it recreate the bike dying. However it did die on its own without the mist and struggled to start again for a few hours this time. I am going to check the ohms as XJ550H as suggested as well.
  10. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Ok let's look at a few things. Go ahead and check the ohms. These bikes came with the cheapest electrical connectors made by mankind. You need to inspect all of your electrical connections from the tail light all the way up to inside the headlight.
    Unplug every connector and inspect the terminals inside to see if they are green or black with corrosion. Treat every good connection with Dielectric Grease or Tune Up Grease as it may be called. All auto parts stores carry it. If you still have the original fuse block replace it with a modern blade fuse style fuse block.
    When you have your tank off, inspect the coils for hairline cracks and check the wires for any damage, cracks or weather checking. There is a central grounding point under the tank also. Inspect the wires and clean all of the connectors and treat with the tune up grease when you put them back on the stud.
    Lastly pop the cover off of your TCI and inspect the soldier joints for cracks. Temperature can effect those connections if there are cracked joints.
    Check your charging voltage at idle, and at 2500 RPM. If you are not getting the proper voltage at 25K you may need to look at the brushes in the alternator cover. I like to see anything over 14 volts at higher RPM's but I have a cheap analog meter.
    I also suggest to look at the three wire connector from the alternator to the regulator to see if has any burning connections. If its an electrical issue going through and checking your connectors is always a good maintenance thing to do on these older bikes.
  11. boomerangg22
    boomerangg22 Member
    USA
    sounds like a bad coil to me.
  12. XJ550H
    I had a problem very similar to what you are discribing when bike finially died and would not start anymore I had a bad pickup coil and the resistors in the plug caps had failed one had blown apart the other was measuring 25 k ohms and all carboned up. it was plugs 2 and 3 and the bottom pick up.
    I would get 10 miles out and stall I kept checking for an air bubble in my fuel line took out the filter. then near the end 5 miles and would stall at the same place in my test ride loop 30 to 40 min later it would start.
    not saying this is your problem but that is why I suggested ohming the ignition system
  13. mlew
    Side stand safety relays are going bad and intermintly cutting ignition.
  14. k-moe
    Possible, but in that vein it's more likely that the sidestand switch is sticking and being activated when going over a bump. Relays generally fail, and then don't return to working order without being serviced.
  15. MN-Maxims
    Saint Paul, MN
    Temperature and humidity related no start condition, my money is on crappy connections and or bad coils.
  16. XJ550H
    or possibly the clutch safety switch is on the way out.
    jump it out in the head light bucket at the connector as well as the
    Sidestand (kickstand) relay:
    - unplug the safety relay which disables the whole bloody mess but DO NOT leave it that way, fix it right!
    Clutch hand lever position switch:
    - jumper the wires (on the main harness) to each other, the circuit will think the hand lever is pulled in.
    try this to eliminate them as possible problems
    simple to do and 2 less things to chase in finding your problems
    when you are sure it is not the problem put them back the way they are supposed to be
    when the bike dies is the time to check plug wires ohms and pick up coil ohms plus coil primary ohms .
    pick up and primary can be done from tci connectors.
    if the resistors are cracked they may be going full open with the heat and arcing across the gap reducing your plug spark intensity
  17. Steve M.
    Steve M. Member
    Bedford co va
    Obviously wicked witches have put devils in your TCI.(I apologize inside joke):DNow seriously
    awesome trouble shooting guys. The only thing I could offer is possibly there is short at the ignition switch. on the run side of the switch Either at the harness connection or in the bottom of the switch itself.honda has a small board the wires hook to.so far I haven't taken a Yamaha switch apart. So it might be different.anyway if it's not something already covered in the thread ....well when all else fails maybe an exorcism IS worth a try.
  18. k-moe
    GO slow. Test one thing at a time. That really is the only way to be sure of finding the problem and fixing it. Be methodical.
    Lightcs1776 likes this.
  19. ColtonS3290
    ColtonS3290 Member
    Update: Today I changed the oil and checked the wires and plugs for spark. They did not have any. When I was finished with the oil, I hit the switch and it fired up. So I shut it down, checked the wire for spark with a screwdriver. It didn't have spark at first, then after a couple cranks it sparked at the wire. So I got it running and took it down the street and just as I figured it killed about 30 feet from my house. I took the wire out again and checked and no spark. So it's killing the spark at the coil whatever the problem is. I am going to look into all the relays before I check the coils. Still have to buy an ohm meter. All this troubleshooting is extremely helpful.
  20. ColtonS3290
    ColtonS3290 Member
    This is exactly what it seems is happening. I haven't checked the pickup coil yet. I'm not to familiar with the setup of it yet. Gonna have a look I'm the manual.
  21. k-moe
    Are all four plug wires failing to have spark when the failure occurs?
  22. ColtonS3290
    ColtonS3290 Member
    Yes, all four wires loose spark when this occurs. But it is random when it happens. I'm starting to think humidity has nothing to do with it, but rather it was just happening during times of high humidity.
  23. k-moe
    Agreed. What this means it that you can concentrate on everthing from the primary feeds to the colls, back.
    I would verify that the sidestand switch is working both mechanically and electrically, and do the same for the clutch switch. The sidestand switches tend to get crap in them (making the plunger sticky) and will cut power to the ignition if you go over a sufficient bump.
    If you still have the original fusebox you should inspect it very carefully for cracked fuse clips.
    The TCI should be the last suspect.
  24. ColtonS3290
    ColtonS3290 Member
    I have replaced the fuse box with the block fuxes. I will check all these problem areas and post an update with what's find.
  25. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Start what k-moe stated by checking your connections to and through the fuse box.
    Gary H.
  26. ColtonS3290
    ColtonS3290 Member
    Update: sorry it took so long. I have done a lot of messing around and troubleshooting as instructed. I have come to a possible conclusion that the relay 12R under the gas tank is causing the spark to kill. I replaced it with the relay 4U8-00 on the side of the bike and it ran without problems. So I went and picked up another 12R relay and started it and it still killed even with the new 12R relay. So the relay 4U8-00 will provide spark every time I crank and run it but the 12R will kill the bike after about 2 minutes. I've never had this happen in the first 2 years of owning the bike. I have never replaced any relays till now, Is this relay not the correct relay. According to the relay master guide here on xjbikes it's the ignition cutoff relay. Which kinda makes sense with something 20160307_160205.jpg 20160307_160205.jpg 20160307_160136.jpg 20160307_160127.jpg killing the spark.
  27. XJ550H
    Relay Assy (12R-01) 12R-81950-01-00
    Relay Assy (4U8-02) 4U8-81950-02-00
    relays listed for your bike two different relays
    this link helps with relays
    1982-84 XJ750 Maxim and Midnight Maxim models:
    Starter/Ignition cut-off relay (no color): behind self-canceller, under rear of tank.
    Sidestand (kickstand) relay (blue): behind the left frame side cover, on the plastic regulator-rectifier mounting plate
    What do you replace the relay with that you remove from side of bike the 4U8 relay. if nothing this is probaly your problem
    BY-PASSING SWITCHES AND RELAYS:
    Starting/Ignition Cut-Off/Neutral Safety relay:
    basicly when you unplug the relay you bypass it putting the wrong relay in the position is the same as bypassing it.
    PUT your relays back where they belong then remove the Starter/Ignition cut-off relay the 12R relay
    and ride your bike to see if the problem goes away.
    then repete process for the 4U8 relay
    then remove both relays
    you could have 1 bad relay or 2 bad relays
  28. Rooster53
    North, FL
    Replacing the starter cutoff relay (12R) with a side stand relay (4U8) will effectively disable the starter safety circuit. The relays have identical connectors, but are different internally and should not be swapped. Most of the relays are identified with a colored dot and a corresponding colored wrap of vinyl tape on the harness to ensure correct fitment. The starter cutoff relay is the exception to no color marking.
    From Len's guide:
    http://www.xjbikes.com/forums/threads/the-ultimate-relay-switch-sensor-and-diodes-guide.27543/
    Flasher: near the steering headpipe, on right side frame rail, under the right side ignition coil.
    Flasher canceller: under the rear of gas tank.
    Starter motor solenoid/relay: attached to and behind the battery box.
    Sidestand (kickstand) relay (blue): behind the left frame side cover, on the plastic regulator-rectifier mounting plate.
    Headlight relay (yellow): not used.
    1982 XJ750 Maxim safety relay single diode: outside the main wiring harness bundle, in the area just behind the fuel tank.
    1983-4 XJ750 Maxim Diode block: inside the headlight housing.
    Neutral switch: in a hole in the bottom of the crankcase, just "outside" of the oil pan, on the bottom of the engine, up inside a recessed "well".
    When you replaced the starter cutoff relay (12R) with the side stand relay (4U8), and if you did not install a relay in the side stand relay position, then you disabled the side stand safety circuit and the TCI was always enabled. Therefore, if this was the case you have isolated the problem to the side stand safety circuit, which is made up of the side stand relay, side stand switch, neutral switch, diode block, and associated wiring.
    When riding in gear, the side stand switch is totally responsible for engaging the side stand relay and opening a set of normally closed contacts to enable the TCI. The neutral switch is wired in parallel with the side stand switch through the diode block, so if the bike died in gear, but would restart in neutral, then that would point to the side stand switch. If the bike will not run in either instance, then the side stand relay or wiring becomes suspect.
    So, in summary from some of the earlier post to isolate the problem:
    Temporarily remove the side stand relay to disable the side stand safety circuit, does this fix the problem?
    The clutch switch will not cause a shutdown of the TCI, it is used in conjunction with the side stand switch to start the bike in gear. If you have a working clutch switch, then you can use this as a troubleshooting aid. When the bike dies, can you engage the starter with the bike in gear and the side stand up, if so the side stand switch is working and is not the root cause of loss of spark.
    The starter cutoff relay will not cause a shutdown of the TCI. It does exactly as the name applies, and shuts down the starter if the correct parameters are not met to safely engage the starter. Removing the starter cutoff relay will not bypass the circuit, but instead will just disable it unless a jumper is installed from R/W to R/W. You don't need to go there unless you are having issues with engaging the starter.
  29. Mike Flores
    Mike Flores Member
    Auburn, WA
    If the plug wires are cracked do you have to change the coil?
  30. XJ550H
  31. k-moe
    XJ550H likes this.
  32. k-moe
    If you splice, wrap self-amalgamizing tape around the remainder of the old wires to insulate it.
    XJ550H likes this.
  33. Mike Flores
    Mike Flores Member
    Auburn, WA
  34. ColtonS3290
    ColtonS3290 Member
    I took the 4u8 relay out and am able to ride it with no problems. So this relay is probably causing the problem. I will replace it and see if the problemreturns.
  35. XJ550H
    it is the sidestand safety switch relay could be your sidestand switch is failing check it out
  36. k-moe
    +1 Because of their location, the sidestand switches are prone to get grimy and sticky. Corrosion can also be a problem. I clean mine annually and use a dry-film lubricant.
  37. ColtonS3290
    ColtonS3290 Member
    Update: I think I bypassed the kickstand/neutral relay, my rubber cover was ripped and it looked like it was a 2 piece plunger style relay. I just left the relay part and took the second plunger out, that the kickstand hits, completely. I also tightened up my clutch cable because it was a bit loose. I noticed it seemed to get up and move better after that. I let it warm up for about 30 minutes and took it around the block about 12 times and it didn't seem to have problems with loosing spark again. but that don't mean the problem is fixed. I'll have to ride it a few more times before I can be sure.
  38. k-moe
    You basically did disable the sidestand switch. If you don't have a repeat incident then you can pretty well assume that the switch needs at least cleaned out, or replaced. A better way to bypass it is to just unplug the switch. The way you have it now does leave the possability that it can trip the switch with a bump if there is enough corrosion in the switch.
    Clean them is pretty easy, but does nto always work. Since the switch is cased in epoxy the only real cleaning you can do is to spray contact cleaner up into the plunger hole and move it around to loosen things up. The contact cleaner will spill back out when you tip the switch housing.
  39. ColtonS3290
    ColtonS3290 Member
    [QUOTE="A better way to bypass it is to just unplug the switch.[/QUOTE]
    I did try this. But for some reason the bike wouldn't start all together in neutral or in gear.........least I believe I followed the switch up to the TCI biggest plug with two wires coming out to a ground and power I'm imagining?
  40. ColtonS3290
    ColtonS3290 Member
  41. XJ550H
    the side stand wires and a sky blue wire go to a connector above the lowermud guard to a connector then to the relay not to the tci. the wire you followed is from the pickup coils
    both harnesses follow the same path under the motor and up the frame in front of the read plastic fender
  42. k-moe
