1965 Honda S65 Sport
Discussion in 'Other Motorcycles' started by Bigshankhank, Oct 20, 2015.
  1. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Just picked this up super cheap on the local craigslist. Turns over and shifts through the gears, no rust on the chrome, original paint on the metal and original uncracked/torn leather on the saddle. Should be an easy tiddler to run around on.
  2. Bigshankhank
    Bastrop, TX
    Shoot what kind of newb am I not posting pictures?
    I'm thinking about a pod filter... :cool:
    Andrew550seca and Alan63 like this.
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    A friend's dad has an s90 in storage... red and white. I'm the only one who has even touched it in the last 20 years, and he still won't part with it! Tough little bikes, just plain nice! I'm happy for you.:Blackalien
  4. Polock
    not sure if that's a rider, it might be a collector
  5. Bigshankhank
    Bastrop, TX
    It runs, and was a rider last night ;)
  6. a100man
    a100man Well-Known Member
    Bedford, UK
    Dad bought me and my bro an S90 years ago for field riding - cost 15 pounds in the late 70s if I recall, but needed a float needle. Happy days...
  7. k-moe
    They're all riders. Nothing worse for a machine than to just let it sit (just don't go hopping curbs with it ;)).
  8. Polock
  9. Bigshankhank
    Bastrop, TX
    Still waiting on Vermont to send me a plate, I am planning on giving this to my daughter for xmas but she will only be able to putt around the campground until the municipal stuff is done.
  10. Taku
    Taku Active Member
    Morganston, Ontario
    Hey BigShankHank,
    I have one of these, in Black, I like the white though, looks great. I have mine running, but second gear is a mess. Apparently this was a common problem with these bikes. Winter project to split the cases and replace the gear, should be fairly easy.
    Great looking bikes, it's nice to have a manual clutch on a little honda. Parts are easy enough to come by for any of these old hondas.
    I have it in my chicken house (I have a wood stove in there) ready to take apart this winter.
    Bigshankhank likes this.
  11. Bigshankhank
    Bastrop, TX
    Woohoo, you just answered a huge question for me, now answer another; are those OEM blinkers? I have what looked like mounting points on the forks but not on the rear fender, and no L-R switch on the handlebar pod so I wasn't certain they were an option on this bike. Actually if you could send me a close up on the rear ones that would be great. I don't think I have wiring either front or rear for blinkers but I know the wiring diagram I have shows them so it should be a simple matter to add them.
  12. Taku
    Taku Active Member
    Morganston, Ontario
    Hey Hank,
    Glad I could help. I just ran out and took a few pictures of the rear lights - they are stock (I've seen them on a couple of other S65s).
    Here are the close ups of the lights and the handlebar controls are in the next message.
    Regards
    Gord (Taku)
  13. Taku
    Taku Active Member
    Morganston, Ontario
    Handlebar controls
    PM me, I have a .pdf manual for this bike as well that I can send you. IMG_1370.JPG IMG_1371.JPG
  14. Bigshankhank
    Bastrop, TX
    Awesome man, I appreciate it.
  15. Bigshankhank
    Bastrop, TX
    Well I discovered that while all of the wiring in the bike works/tests as per the diagram, the ignition switch is screwing up the works. And what to my wondering eyes should appear, but definite signs of PO abuse on the switch housing itself. Sigh. Upon disassembly (made very easy by the amount of prying the PO performed previously) I found some missing and some pieces, rendering it out of commission. I find it kind of funny that this bike was designed to work if you disable the ignition switch, rather than ANY OTHER WAY TO DO IT. Anyway, the hunt is on to find a replacement, or else to find the courage to refurbish the one I have.
    So other than testing electrical stuff, which as I said all works now that I have taken the switch out of the circuit, I spent the weekend pulling off bare aluminum and chrome parts and sanding/polishing to a reasonable finish. As this is not getting a full bore restoration so much as survivor revival, I cannot go overboard without making the patina look like crap. So no high polished aluminum, no straightening out all the dents in the exhaust shields, but cleaner and nicer than before with a daily rider look to them. Its a fine line...
  16. Taku
    Taku Active Member
    Morganston, Ontario
    Odd way to do it with the ignition switch, I agree. Not the most secure thing on earth.
    Then again, you could go for a leisurely stroll dragging one of these little bikes behind you...easy enough to steal any way you look at it.
    You'll have to post some finished pics when you are done.
    You may get lucky digging around the bike scrappers for an ignition switch.
  17. Bigshankhank
    Bastrop, TX
    Been scouring the web to little avail, at least not within what I would call a reasonable price range. You are right though, I can practically toss this into the back of my wife's Jeep by myself, I think full coverage insurance will be my only real defense against theft. I did notice that the key does not turn the fork lock so I might take that out and see about getting a key cut for it as well, at least then a thief would only be able to ride it in a gentle circle...
  18. Taku
    Taku Active Member
    Morganston, Ontario
    When I was at Mid Ohio last year there was a guy selling keys for 60's Hondas. All he needed was the number from either a key or from the lock. He had a lot of numbered keys in trays. I'm not sure what to make of that, other than I think a key can be made up if there is a number on the lock.
  19. Bigshankhank
    Bastrop, TX
    Cleaned up and tightened everything up in the front and rear ends, including new brake shoes. Fronts were somewhat contaminated by the grease from the speedo gear so that's a little disappointing. Otherwise the driveline and suspension are good and tight. Waiting on an ignition switch from a honda forum member and this one should be ready for the road.
  20. Bigshankhank
    Bastrop, TX
    It may be slow, but with the ignition switch in place allowing the lights to work, new brakes and tires and a valid plate, it still meets the state regulations for a legal motor vehicle in the State of Florida, so I took it for a spin. My daughter is going to love this thing.
  21. k-moe
    Hang-off more. It'll look faster :)
    Taku and Bigshankhank like this.
  22. Bigshankhank
    Bastrop, TX
    Yeah, moped tires don't have tremendous grip on their edges. :(
  23. Taku
    Taku Active Member
    Morganston, Ontario
    Hi Tyler,
    Here are the pictures of the brake light spring on my bike.
    Regards
    Taku
  24. Taku
    Taku Active Member
    Morganston, Ontario
    The lighting wasn't good for pictures. But you should get the idea.
    It's a single spring from switch to brake lever arm.
  25. Bigshankhank
    Bastrop, TX
    Got, thanks man. Oddly, the engine mount bolt just above the brake lever is different than mine, I'd be willing to be there is a pinhole through that bolt that the lever return spring would connect through. Mine is just the cap end of a common hex bolt.
  26. Taku
    Taku Active Member
    Morganston, Ontario
    That is odd. Could it be in backwards? Inserted from left to right instead of right to left ?
    Looking at my pictures, I see I have a lot of cleaning to do ! Haha.
    Late summer I guess. Racing season is about to start in a few weeks and I'm busily preparing my '74 CZ 400 for the vintage MX class.
    You daughter is going to love that bike.
    Gord
  27. Taku
    Taku Active Member
    Morganston, Ontario
    "Your"...not you...
    Typing too fast :)
