My chopper
Discussion in 'XJ Modifications' started by Spyderbuggy, Aug 7, 2007.
  1. Spyderbuggy
    Spyderbuggy Member
    Texas
    Hello all,
    I bought this chopper on Ebay last summer. The guy said it had electrical problems. I found an ignition wire broken. The bike started right up. I then did a total rewire. welded in some mounts for the tank and coils. I took the tree to a machine shop and had tapperd berrings fitted. Who ever built this frame did a great job the bike rides so smoothe. Turning is nice it dosn't want to fall over like some choppers do. I call it a chop rocket .It sounds like a crotch rocket but looks like a chopper.
    One pic is off the Ebay add the other is it today.
  2. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Looks cool man! Seat looks hard though...
    More pics would be nice!
  3. Spyderbuggy
    Spyderbuggy Member
    Texas
    I did pad the seat. Here's another pic. Any one have info on front brakes on girder style forks?
  4. samsr
    samsr Member
    Colorado Springs
    Looks like the good news would be you can use the stock xj set up for the front brakes. Bad news is you are going to have to weld on some mounts. For that fact it is a clean slate use whatever will fit the rotor on the front rim. Have fun with the rotochopper
  5. 82XJ
    82XJ Member
    Far SW suburbs of Chicago, IL
    That is, without a doubt, the first XJ chop job that I've seen that I'd want to ride myself. Nice one!
  6. Schaf1cm
    Schaf1cm New Member
    Central Michigan
    Is that an 1100? of so, that is the sweetest maxim i have ever seen. Well, maybe be it is anyway....
  7. Spyderbuggy
    Spyderbuggy Member
    Texas
    It's a 650.
  8. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    does that thing have the stock neck? I really want to put a springer on mine but i dont know if i will have to switch to an HD neck or not
  9. Spyderbuggy
    Spyderbuggy Member
    Texas
    yes, it has the stock neck. It also has the stock taper bearings. I just had a machine shop turn down the top part of the girder post to fit. the lower bearing fit with no mods. just needed a spacer under bottom bearing.
  10. Deathmetaldan
    Sunbury PA 17801
    interesting... how much rake is in the neck? it looks like there is some rake in the clamps also... how much is that? Sorry for all the newb question but i never delt with a front end before and im trying to get all the info i can
