Camshaft caps installed wrong
Discussion in 'XJ Technical Chat' started by Dave Johnson, Mar 2, 2016.
  1. Dave Johnson
    Dave Johnson Member
    Oak Grove,Minnesota
    So, I'm putting my engine back together after I get the head back from the machine shop (replaced a broken valve guide and complete valve job) and check my before photos of the valve train with the assembly diagram in the manual. I notice the manual says the cam caps should be E1 (exhaust 1) and I1(intake) should both be on the left side of the engine. My exhaust cam caps are flip flopped. I got this bike as a basket case, was told it ran well when PO started the project. 24000 miles, and I have no idea how long the caps have been on wrong. Do I reassemble as I found it, or put them back on where they should be? CSjpeg.jpg
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    Well they are aligned bored in place when the head was built, so they should go back in the original positions. The question now is was the bike run with them in the wrong spot. Is there any noticable scoring/damage? Some plastigauge will tell you where they fit best.
  3. Dave Johnson
    Dave Johnson Member
    Oak Grove,Minnesota
    Everything looks clean and smooth. But, I really can't be 100% sure it was ever run like this. My first thought was to put them where they belong, but started thinking if it was run like this for a few thousand miles, they might be wore together to where it might be better to leave them where they are. Plastigauge is a good idea, thanks.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    There never should be contact as there is the thin layer of oil between the cam and caps/head when it's running. If it's all shiny smooth, then it's possible the PO disassembled and just slapped it together without running or he got lucky. You're probably good to switch them back but plastigauge will say for sure.
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    Numbers you need. I did see you have the manual but good reference if someone else hits this thread. Hopefully nobody's pulling without a manual though.
  6. Dave Johnson
    Dave Johnson Member
    Oak Grove,Minnesota
    I only have a Haynes manual, I don't think it has these specs. Thank you! I'll let you know what I find.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    That's an YICS (82 - up) 650 motor right? Just wanted to make sure I gave you the right one. I'm taking best guess from your pic, putting the model and year of your bike in your signature will help future posters though!
    Good luck!
  8. Dave Johnson
    Dave Johnson Member
    Oak Grove,Minnesota
    Yeah, good point. It's an 82 XJ750 J, Maxim.
  9. k-moe
    The 650 and 750 cam bearing clearances are the same.
    Dave Johnson likes this.
