Caliper bleeder screws
Discussion in 'XJ Technical Chat' started by RPS, Mar 8, 2016.
  1. RPS
    RPS Member
    North Carolina
    I have a very small amount of fluid that seems to be coming from around the threads on the bleeder screws. Is this a problem? How can I fix it if it is. Just enough to see a little wetness of you run your finger around it
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Try tightening a sconch. Not even a 1/16 of a turn, just give her a bump.
    That little amount, providing it doesn't build into a drip, wouldn't worry me.
    Oh wait, this is an XJ700 and you are saying BOTH bleeders are doing the same weeping?
    When is the last time they were fully removed?
  3. mlew
    Did you try to tighten them? Not suppose to leak at all
  4. RPS
    RPS Member
    North Carolina
    They we're removed a couple days ago, I have tightened them, but did not put a lot of torque on them.
  5. Stumplifter
    near Irma, WI
    Were the holes and threads nice and clean when put back together?
    Assuming you understand the importance of not over- torquing and hearing you say you did not put a lot of torque on them.
    I would suggest putting a wee bit-o-torque on them and see if that helps.
  6. k-moe
    When they were removed did you look at the taper and at the seats?
  7. RPS
    RPS Member
    North Carolina
    I did look at the taper, but not the seats. Maybe didn't look good enough.
  8. RPS
    RPS Member
    North Carolina
    I have replaced the brake lines, but have not rebuilt the calipers
  9. k-moe
    Please rebuild the calipers. The seals are just as old as the brake lines were, and the calipers are likely full of goopy crap.
  10. RPS
    RPS Member
    North Carolina
    Good point
  11. RPS
    RPS Member
    North Carolina
    Could not rebuilding them cause the screws to weep? Or is that another issue
  12. k-moe
    It's another issue, ulness some crud is stuck between the taper and the seat.
  13. RPS
    RPS Member
    North Carolina
    Ok, thank y'all for the help
  14. Polock
    after you rebuild the calipers use teflon tape on the bleeder screws but keep the little hole clear
  15. RPS
    RPS Member
    North Carolina
    Ok, didn't know if the fluid would eat the Teflon tape or not
  16. XJ550H
    is it a standard bleeder ?
  17. k-moe
    Nothing except very high heat can damage Teflon. It is the cockroach of materials.
    RPS likes this.
  18. RPS
    RPS Member
    North Carolina
    Yes they are standard screws
