New member - 83 750 maxim midnight
Discussion in 'Hangout Lounge' started by Turbo20, Mar 9, 2016.
  1. Turbo20
    Turbo20 Member
    Oshawa
    Hi all just picked up a 1983 maxim midnight 750 with 34000km on it and im looking forward to restoring as much of the bike as i can . the bike is in running condition but the collector has a nice hole right in the middle of it and the mufflers dont look to be original which i think is my biggest worry because it doesnt look like these are available anywhere anyway ive been reading the information overload thread and its great having so information available
    Stumplifter likes this.
    XJ750 manuals
    free down load
    ebay used parts or clist we also have a used parts forum
    can it be welded?
    Ray likes this.
  3. Turbo20
    Turbo20 Member
    Oshawa
    Thanks for the link. The hole isn't to big and looks like it can be welded I took my time and pulled the exhaust system apart yesterday and the metal still seems very strong except the 4 ends that connects to the header pipe the metal is very brittle and I have lost a couple tabs already
  4. boomerangg22
    boomerangg22 Member
    USA
    welcome aboard Turbo20
  5. Turbo20
    Turbo20 Member
    Oshawa
    thanks boomerangg22. im looking forward to riding and restoring this bike also to mention the bike only has 34000km on it
  6. Mike Flores
    Mike Flores Member
    Auburn, WA
    Nice bike! I have the same one!
    Ray and Turbo20 like this.
  7. Turbo20
    Turbo20 Member
    Oshawa
    XJ4ever was able to get me a collector so ill be up and running again shortly now i will try to slowly restore this midnight to its original glory . hopefully lol
    Mike Flores likes this.
  8. Mike Flores
    Mike Flores Member
    Auburn, WA
    Cool, I'm getting my Carbs cleaned and rebuilt on mine to get 33 years of crap out of em so I can get em synced next week!
  9. Turbo20
    Turbo20 Member
    Oshawa
    nice are you cleaning the carbs yourself? im going to do the carbs after i put the exhaust back together
  10. hogfiddles
    You are correct--- those are not the right mufflers for your bike. Yours should be black, and should have an angle to the end so that the back of the mufflers is about perpendicular to the road, not to the centerline of the mufflers
    Nice fined :)
  11. Turbo20
    Turbo20 Member
    Oshawa
    Thanks hogfiddles , im going to have a fun time trying to find the OE mufflers but thats part of restoring 30+ year old bike as for the collector im going to cut and re weld the black heat shields onto the new collector
  12. Mike Flores
    Mike Flores Member
    Auburn, WA
    I'm pulling em and giving them to a guy who put them in a chemical boil to dissolve any hardened residue from all the old gas. Then I'll put em back on!
  13. k-moe
    Tell your guy that he'll need to do more than just boil them if you plan on having the engine run correctly afterwards.
    In the Church of Clean
    The Secret Life of Carburetors
    Clean Your Own Carbs --- The Whole 9 Yards
    Setting the Fuel Levels
    This is the part were recommend that you do the work yourself the first time, so that you don't have to re-do the work that you paid someone else to do.
    Ray and XJ550H like this.
  14. Turbo20
    Turbo20 Member
    Oshawa
    i plan on doing the carbs my self previously did my 83 gs650L and my 83 Magna v45 (total bitch) . i have question about the handle bars are they supposed to be black or chrome on the midnight? mine are currently chrome
    Ray likes this.
  15. hogfiddles
    Carbs...... Don't trust them to work right when he's done. When he's done boiling them, your seals are gonna be shot.....you''ll end up taking them apart anyway. So, if you're gonna take them apart anyway, your' re only on step away from where you'd be anyway. Clean them yourself, do it all yourself, readthe links that were given to you..... And if you have any problems then WE ARE RIGHT HERE to help, and it's free here on the forums.
    Handlebars - they should be black.
    Dave
    Ray likes this.
  16. Turbo20
    Turbo20 Member
    Oshawa
    Great thanks
  17. hogfiddles
    Wow.... That collector box is rough---- and OILY
  18. Turbo20
    Turbo20 Member
    Oshawa
    The oil is actually seafoam deep creep (like wd40) I soaked the the hell out of everything for a day even the header pipes where it connects to the Box and still literally fell apart as soon as tried to pull on the pipe or unbolt a clamp( I dropped the collector and pipes as one piece with hopes dismantling with minimal damage while having it off the bike) lol wait until you see the brake fluid
  19. Turbo20
    Turbo20 Member
    Oshawa
  20. Turbo20
    Turbo20 Member
    Oshawa
    Here's the banjo going to the caliper IMG_20160312_113437.jpg IMG_20160312_113314.jpg
  21. hogfiddles
    Seafoam..... Good call. Didnt realize you had sprayed it down already
    Brake ---yummy. The bolt looks tasty too:)
  22. boomerangg22
    boomerangg22 Member
    USA
    My MC looked almost the same. I broke the mirror off in it so I'm going to have to replace it anyway. I tried to get it out but no going.
  23. Turbo20
    Turbo20 Member
    Oshawa
    That sucks I'm having a similar issue one of the screws for the MC. Cover broke off and I can't get it out the the screw metal is to soft I'm hoping I can maybe drill out what I can and put in a screw a spec longer or a spec thicker if possible. Have you tried and extractor bit ?
  24. hogfiddles
    Careful drilling/milling extracting
  25. thench
    thench Member
    Charleston, WV
    Folks, I recommend that if you're going to own older motorcycles, especially metric ones, that you go ahead and invest in a good quality impact driver. For me, owning one is a must, and can usually save you some trouble with rounded out/stripped screws.
    Oh, and nice looking brake fluid you have there!
  26. Turbo20
    Turbo20 Member
    Oshawa
    Not much more you can do after that lol
  27. Turbo20
    Turbo20 Member
    Oshawa
    I have a pretty good one fom mastercraft thats what got me started on the MC cover screws without that it wouldn't budge. I was able to get one side out no problem the the other side it just ripped the head off lol
  28. boomerangg22
    boomerangg22 Member
    USA
    I agree Turbo, I've used my impact driver several times course after I messed up the screw. Seems like they are very soft material, using the correct size screw driver helps but not always.
    hogfiddles likes this.
  29. thench
    thench Member
    Charleston, WV
    Well, yeah, using an impact driver is kind of an "all or nothing" type of approach, and you usually only get one shot at it, so it's best to have the right bit in it and be as square as you can be when you hit it.
    Basically, if it doesn't come loose with an impact driver, you probably weren't going to get it without drilling it anyway.
  30. Turbo20
    Turbo20 Member
    Oshawa
    Ya for sure . when I took the cover off there was enough of the screw sticking out that I was able to get vise grips on it and try again after soaking it with deep creep for a few hours but still no luck that also broke off . I will try to drill and tap something a bit thicker in if it works great if not I will purchase another MC. I will continue to update this thread as I go through the bike fix/ restore the midnight
  31. k-moe
    Degrease the screw.
    Use clay to build a dam around the screw head.
    Disolve some (yes, this is the exact quantity lol) alum into some warm water.
    Fill the clay dam with the solution.
    Wait a few days.
    Look to find that the old screw is no more, and you have clean threads for the new screw.
  32. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard. Nice bike. All the screw heads are JIS (Japanese Industrial Standard). They are slightly different than standard Phillips.
    Gary H.
  33. Turbo20
    Turbo20 Member
    Oshawa
    Thanks k-moe I never heard of this before so I googled it lol. I read you can pick up some alum at the grocery store so I will give it a shot today when I get home
  34. Turbo20
    Turbo20 Member
    Oshawa
    Thanks for the info rocs82650
  35. Turbo20
    Turbo20 Member
    Oshawa
    didnt get to try the alum bath last night but i did get a little further on the left caliper . i was able to get the piston out using the grease method then cleaned it / polished it up but the retaining pin that holds the pads was a total pain , i was able to unscrew the threads all the way out but the rest of the pin needed to be hammered out with an old screw driver and a mallet as for the right caliper the retaining pin head is stripped and wont budge and thats after soaking in some deep creep for the weekend, i will try again today when i get home maybe i can heat it up and maybe squeeze some vise grips on the pin in between the pads anyways here are some random pics of the first caliper IMG_20160314_174704.jpg IMG_20160314_174712.jpg IMG_20160314_175007.jpg IMG_20160314_174720.jpg
