Mikuni BDS26 throttle plate screws
Discussion in 'XJ Technical Chat' started by PepNYC, Mar 21, 2016.
  1. PepNYC
    PepNYC Member
    Charlotte, NC
    Hey guys. So I stripped the darn butterfly screws on one of the carbs and can't get the buggers out now so I can change the shaft seals. Anyone have any helpful tips on how to remove them? I'm thinking of drilling them out with a small drill bit. Any other suggestions welcomed. Also, does anyone know where I can get some replacement screws or what size they are? Maybe I can match them up at home depot or lowes?
    the screws are peened over on the thread side need need to be filed down before removing them.
    if they can be screwed back in do that then file them down
    replacments from chacal www.xj4ever.com his email is on the web page he has allen head replacments.
    He may also have the shaft if you have stripped that out
    what bike are you working on?
  3. PepNYC
    PepNYC Member
    Charlotte, NC
    Yeah. I wish I would have noticed that before I tried to unscrew them. It's only one carb. Once I stripped them I walked away. Didn't touch the others. I wasn't going to even try. The shaft is fine since the screws didn't even move. It's a 1993 XJ600 SECA II
    I'll check out his webpage. Thank you!
  4. XJ550H
    did you strip out the screw slots?
    there are special screw drivers called JIS for the screws a regular phillips may not work he sells them too
    there is a thread on the new standard in this forum
  5. k-moe
    Superglue helps. Glue the driver to the screw head and you might be able to break them loose.
    XJ550H likes this.
  6. PepNYC
    PepNYC Member
    Charlotte, NC
    No Didn't strip the slots. I stopped immediately once I couldn't get a good grip on the screws so they're not actually entirely stripped. I still might be able to get them out with the JIS screwdriver and by filing down the other end as I should have from the start but for now as to avoid making things worse, I'm not touching them.
    I spoke to Len last night. The vacuum leak may just be from the carb boots which I already have on order. I might try those first before I start braking the rack down. Knowing the way I am though, I'll probably end up changing the shaft seals anyway. I don't like doing things half a$$ if ya know what I mean. Might as well while I have the carbs off the bike and they're probably well past their prime and well worn. Can't hurt. I already had them apart last year, cleaned em, replaced every other seal and gasket and adjusted them. I didn't do the shaft seals because I didn't want to mess with those screws. I should have just done it then. ugh
  7. PepNYC
    PepNYC Member
    Charlotte, NC
    Really? Super glue on metal? Never would have thought of that.
  8. k-moe
    Superglue on almost anything.
