intake valves
Discussion in 'For Sale, Trade/Swap, Wanted' started by davy, Mar 30, 2016.
  1. davy
    davy Member
    canada
    Hi guys I need two intake valves for my 81 XJ750.
    click the logo in the upper right of the page
    xj4ever or go to www.xj4ever.com then email len
    All XJ650, XJ700 non-X (air-cooled), XJ750 non-X (air-cooled), and XJ900RK engines:
    HCP5073 OEM cylinder head intake port VALVE, without springs, seat, keepers, or retainer, for all XJ650 and XJ750 non-X (air-cooled) engines, each:
    $ 52.95
    HCP5073SET4 OEM cylinder head intake port VALVES, set of 4:
    $ 199.95
    HCP5072 OEM cylinder head intake port VALVE, without springs, seat, keepers, or retainer, for all XJ900RK, RL, N/FN, and F engines, each:
    $ 62.95
    HCP5072SET4 OEM cylinder head intake port VALVES, set of 4:
    $ 239.95
  3. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Do you mean, two valve shims? What size are you looking for? If you want to buy them contact Len, otherwise you may want to contact hogfiddles
  4. k-moe
    And if you do mean valves I'm curious as to why. There has to be a story, and I like stories.
  5. davy
    davy Member
    canada
    OK panic over,I got them direct from Yamaha Canada for $32.76can , cant beat that.And yes ABIDE there is indeed a story, I was replacing the starter chain guide and the local bike shop gave me a loan of his alternator extractor, unfortunately it was a cross shape with four sizes and would not screw home, and yes, you guessed it , I turned the motor backwards and bent the valves, be warned.
