Brakes Breaking
Discussion in 'XJ Technical Chat' started by Ky13harbor9, Apr 7, 2016.
  1. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Hi all,
    Pardon the pun above. I have had this issue ever since I got my bike - sticky brakes.
    After bleeding, cleaning the return hole, and replacing the brake line itself, I still can not fix this issue.
    My only guess now is that I will either need to clean or rebuild my master cylinder.
    I'm pretty sure that it's not the caliper because whenever my brakes stick, I can relieve the pressure through the bleeder valve on the side of the road, and bam, a nice feeling brake lever and no more sticky brakes.
    Also, whenever I had the '81 lines on the bike, the return hole would fill up with little tiny pieces of rubber hose, blocking the return hole and causing the issue.
    As per usual, I have essentially two questions:
    1. It is the master cylinder, right?
    2. What can I do to solve this issue? Is it worth a rebuild or should I try a good cleaning first?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Sounds like m/c guts failure. If it's never been rebuilt it's way past due.
    Gary H.
  3. XJ550H
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I agree. Rebuild everything, and I would consider new brake lines since you know you have bits of rubber floating around.
  5. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    If it's not relieving pressure without you hitting the bleeder, it's probably the MC. However, for the cost of it, as well as the ease of mind, wouldn't you just spend a few bucks for a MC and Caliper rebuild kit? And maybe some new hoses while you're at it...
  6. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Ok,
    I just spent lots of money to get three things.
    1. K&L Master Cylinder Rebuild Kit
    2. K&L Caliper Rebuild Kit
    3. Yamaha NOS Front Brake Pad Kit
    Thanks for your advice, guys.
    EDIT:
    Yes, I already replaced the brake line. It's the Goodridge universal one with banjo fittings.
  7. PilotSmack
    Calgary, Canada
    It might seem like lotsa money. But personally, I wouldn't wanna end up as raspberry jam on someone's bumper cuz of 39.95
    Ky13harbor9 likes this.
  8. tabaka45
    Brunswick, Georgia
    I would be sure to flush the fuel line with clean brake fluid just to make sure you get and rubber bits out.
  9. XJ550H
    and flush the brake line with gasoline:eek:
    Big swede, DrewUth and PilotSmack like this.
  10. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    So I have a little problem...
    I'm pretty sure that the MC rebuild kit I bought doesn't work. Whenever I try to bleed the system, it doesn't advance. It just pushes then pulls back the same amount.
    I've tried just about everything in the book, but nothing works. I bet that if I put the original plunger back in, I could bleed out all the air in 5 minutes and have my sticking brakes back, but that's no good...
    What should I do before buying a new MC?
  11. rocs82650
    Middle Tennessee
    Are you sure the kit is the correct diameter for the bore? Are you fully closing the bleeder screw before you let off the handle?
    Gary H.
  12. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    While I haven't measured the exact diameter, it seems like an exact match, and the ebay listing specifically says XJ550 Seca of all kinds, as well as a lot of other Yamahas.
    And yes, I am sure I am bleeding them correctly. I've done it 4 times before on XJ550's.
    EDIT:
    Yeah the master cylinder had never been rebuilt. I could build a mountain out of all that rust. I'd upload a photo but I think you get the picture.
  13. XJ550H
    orings correctly oriented. proper location
    did you clean out the little holes from res to plunger
    hone the cylinder ?
  14. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    What do you mean by "Origins correctly oriented," this may be my problem. Do I need to rotate the plunger?
    I did clean the holes, and I have been since I got the bike. The rust from the original plunger was seeping up into the holes and clogging them, I think.
    Also not sure what you mean by "hone the cylinder."
    But I think you may have the solution.
  15. rocs82650
    Middle Tennessee
    Are you saying that when you pull the handle fluid doesn't exit the bleeder screw? Are the banjo bolts clean and clear of debris?
    Gary H.
  16. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Sorry that was a little unclear.
    The fluid does exit the bleeder valve, however...
    Once I close the valve, release the lever, pull the lever, and open the valve again, it just sucks back up, or does't move at all.
  17. XJ550H
    the orings go on in a certain direction on the plunger
    hone take a small dowel and wrap 1000 grit wet dry sand paper on it put in a drill and run it in and out a few times to clean the walls.
    wet it with brake fluid
  18. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Oh, yes, I'm about 80% sure that I got the o rings on in the right order. I even had to reinstall one because it was on the wrong way. I used the original as a model.
    And no, I didn't sand the bore. It actually looked pretty clean even though the plunger was so nasty. I might have to do that though.
  19. XJ550H
  20. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Ah, I've heard of that, but never tried it. It's very possible since I've used it so much.
  21. XJ550H
    read the link i posted good info
  22. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Well, sorry to keep bumping this old thread, but I'm going to try and reuse the old plunger.
    The K&L one doesn't work so good, I'm about 90% sure it's the problem.
    The old one looks like lead, but it's now pretty much clean on the internal part since I gave it a good scrubbing with a wire brush.
    The external part is a little bit pitted with rust but I don't think that will be an issue.
    And more o-rings are on the way since I broke both of the center ones :confused:
    But should I keep the old one?
    I think the gunky buildup on the plunger was actually causing the issue, rather than the plunger itself.
  23. XJ550H
    if the plunger works use it
    fluid flows around the plunger if gunked up thats was a problem
  24. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Gotcha. That makes so much sense.
  25. Yardawg
    Yardawg Active Member
    Hatch NM
    I just honed the bore on my m/c yesterday and I discovered that 0000 steel wool with the dowel and drill works excellent. Just be sure to blow it out real good before reassembly
  26. rocs82650
    Middle Tennessee
    What he ^ said.
    Gary H.
  27. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    I give up. Even the old plunger doesn't work anymore.
    A new master cylinder is on the way...
    But, what could have caused this?
    It's not the return hole which is my only guess.
  28. XJ550H
    I am looking for a 550 mc if your done with yours start a conversation with me
  29. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Alright, I got the new master cylinder, but it's not working 100%.
    I can feel a delay in the lever, as in it takes about 15% before the brakes kick in.
    I can feel the brake piston advancing before pressing the brake pads against the rotor if I put my fingers on the bottom of the brake pad.
    It's like the opposite of what I had before...
    Any ideas?
  30. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    Don't know if i've got this right, but it sounds like your calipers seized (the sliding bolts). You can remove the pads and check that it moves freely.
