Maxim-X front axle/speedo cable
Discussion in 'XJ Technical Chat' started by granitize, Apr 10, 2016.
  1. granitize
    granitize Member
    Canada - East Coast - Prince Edward Island
    Good morning.
    Perhaps a stupid question!
    Last fall my speedo started "whining".
    When I checked, the fitting was loose @ the axle.
    I removed the cable, cleaned and applied cable ease.
    The fitting @ the front wheel is a little gritty.
    Should I remove the front wheel, clean and re-grease the axle?
  2. k-moe
    I would, especially if you've never done it since taking ownership of the bike.
    granitize likes this.
  3. granitize
    granitize Member
    Good,
    Thanks.
    Is there a grease nipple or do I just repack it.
  4. k-moe
    The bearings are shielded, but can be repacked with a needle. The speedometer drive can be disassembled, cleaned, and regreased.
  5. granitize
    granitize Member
    Thanks.
    Next job! :)
    But I am having trouble getting the Axle bolt off!.
    Removed the brakes, removed the "tightener" on the right side, removed the speedo cable.
    Cannot get the axle to release!
    Do I just need a longer socket handle and a mallet? lol
