550 Seca Brakes
Discussion in 'XJ Technical Chat' started by patmac6075, Apr 13, 2016.
  1. patmac6075
    patmac6075 Active Member
    MKE
    While I'm waiting on some carb parts to arrive thought I'd get started on this 550 Seca's brakes. No fluid in the system and tons of crud in the master....actually I have the master pretty much crystal clean (even that teenie tiny hole is clear!).
    My question is: "How do I break apart the caliper? Got the pads and pin out...I removed the cotter from the slide pin, but how do I break the two halves of the caliper apart? That pin (with the rubber boots on it), does not want to free itself from the caliper....do I tap it out or pull it with a pliers? Don't want to bust it, so I thought I'd ask questions first....
  2. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Did you clean out the plunger and hone the bore?
    If you just cleaned the reservoir, that didn't do a whole lot.
  3. patmac6075
    MKE
    Well, not sure if you're answering my question or checking my work?
    MY question was how do I split the caliper halves?
    To answer your question, yes, of course I cleaned the bore, and polished it.
    Do you think I can reuse this part?
  4. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Sorry, I shouldn't have said anything.
  5. XJ550H
    buy the rebuild kit with the piston , you can try to clean it.
    there are 2 pins one goes through the pads. then there is a plastic cover 1 screw top rear of caliper ,take that off there is a pin going through the caliper halves you will see 2 rubber boots with a pin going from one side to the other spray with pb blaster then tap it out with a dowel
    the boots are very expensive 25$ each try your best not to tear them . the boots are fitted in and hard to remove fit into a recessed groove in the side of the caliper
    need a pic I will post one shortly
  6. patmac6075
    MKE
    SorryKY....thatcameoutwaymoresnarkythanImeantittobe.
    ThanksXJ550H
  7. patmac6075
    MKE
    ThanksXJ550H
  8. Ky13harbor9
    Ky13harbor9 Member
    Lexington, KY
    Oh, ok. I still shouldn't have said anything anyways :rolleyes:
  9. XJ550H
    partialy removed pin, cover on left. pin has a cotter pin holding it in second photo pin installed in boots on mount
  10. XJ550H
    when you go to install the pads you may have to file out the holes in the pad into an oval to properly fit on the pin,
    chacal states this in one of his writings I think it is in his brake parts section.
  11. patmac6075
    MKE
  12. patmac6075
    MKE
    Crap! I need a little help here!
    Got the calipers split (thanks 550H)....How important are those stainless slides? You guessed it....somehow, at some point, that little one took off on me and for the life of me I can't find it anywhere....of course it's not shown as a separate part, so I can't order one...does anybody have one? How catastrophic would it be if I went without it (I really don't like second guessing those early 70's Japanese engineers, especially when it comes to brakes...they put it there for a reason).
    I'm open to ideas.....
  13. XJ550H
    from xj4ever brake section
    the slides prevent rattling and binding good read in the section on them
    and the part
    HCP18487 Aftermarket front disc brake caliper RETAINER-TO-CALIPER SHIM PLATE, small rectangular shape. This steel "shim" snaps onto the small, machined bottom rectangular edge of the retainer plate where it joins against the caliper body and provides the spacing needed for the caliper body to properly "float" independent of the retainer. Fits left or right side calipers. For all XJ550 models, 1981-83 XJ750 Seca, XJ750 Euro, and XJ1100 (front) models. Use 1 per caliper. Each:
    $ 17.95
  14. patmac6075
    MKE
    Johnny on the spot....how can I ever repay you?
    You have my gratitude.
  15. XJ550H
    a picture when its done
