1981 maxim 650 first timer
Discussion in 'XJ Modifications' started by willmarmnxj650, Dec 14, 2015.
  1. willmarmnxj650
    willmarmnxj650 Member
    Willmar mn
    Here is my first ever motorcycle that I decided to change up a little please let me know what yall think I'd love to take some opinions and suggestions
    Jetfixer likes this.
  2. willmarmnxj650
    Willmar mn
    More pics
  3. willmarmnxj650
    Willmar mn
    More
  4. willmarmnxj650
    Willmar mn
    And more
  5. willmarmnxj650
    Willmar mn
  6. k-moe
    Looking good. Was it running well before you tore into it? Valve clearances checked, brakes rebuilt with new lines, and all of that other maintainance stuff that none of the prior owners ever do?
  7. willmarmnxj650
    Willmar mn
    Yes it was running ok until my father in law mixed some oil treatment into the engine when I was changing the oil and after that it started making this squeeling sound in the engine it sounds almost like a belt squeel
  8. willmarmnxj650
    Willmar mn
    Want to try hard tailing it
  9. k-moe
    That would be the starter clutch slipping.
    What treatment did he use?
    Flush it all out with an inexpensive (sacrificial) oil, then refill with a JASO MA rated oil.
    There is a link ☟down there☟that you should read.
  10. k-moe
    You are wise to use solid links to try out hard-tailing. Makes it easy to switch back once you find out why motorcycles from the 1920's have sprung saddles.
  11. willmarmnxj650
    Willmar mn
    What link? I don't see anything
  12. willmarmnxj650
    Willmar mn
    Lol yeah I have to try it out first before I decide to hard tail
  13. quebecois59
    Are these Jardine mufflers? I had two very similar ones on a '79 Goldwing, I loved how they sounded.
  14. XJ550H
    this link in his signiture line right under
    82 XJ750 Seca
    Choosing Oil for a Wet Clutch Motorcycle
    very important to use JASO rated oil not standard auto oil
    hope he did not use STP or similar oil treatment
  15. willmarmnxj650
    Willmar mn
    Yes it was stp oil treatment I had left to go inside to grab a beer and take a piss and when I had came outside he said he added a little bit bit of stp oil treatment and after that it started making a skreech
  16. k-moe
    It'll flush out. You might run a bit of seafoam in the sacrificial oil to help get all of that slick crap out. The STP won't do any harm, but it does need to come out or that starter clutch will keep slipping.
  17. willmarmnxj650
    Willmar mn
    But if I flush it all out will I still be hearing that squeeling sound? It sounded awesome until he added the stp and it started happening
  18. k-moe
    Once you get rid of the STP, and put the correct oil back in, the squeal should go away. The big issue is that without the correct oil the starter clutch will eventually begin to slip enough that the bike won't be able to start.
    At some point the clutch rollers will be worn and need to be replaced anyway (this requires splitting the engine cases), but the goal here is to try and push that date as far into the future as possible.
  19. willmarmnxj650
    Willmar mn
    The oil I had used was the recommended yamaha oil and filter and fresh oil change too n now I got to dump it all out that's a bummer but I don't want that noise anymore so I'll do whatever I got to do to do it right without having to open the engine what steps do your recommend me for doing this do I add seafoam to the engine oil?
  20. willmarmnxj650
    Willmar mn
    To be honest I don't have a clue to what kind of mufflers they are they were on the bike when I got it but they do look cool
  21. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Love the picture of the lil guy wrenching on your machine. I gotta get my guy out in the garage with me... It's never too early to learn!
  22. k-moe
    If the engine is starting easily, then Id kive with the noise for 1500 miles, then change the oil. If it begins to get to where it won't rutn the engine over every time, then drop the STP contaminated oil, follow the directions on the Seafoam can for use in the engine oil, and run it until the slipping stops. It may take more than one oil change for it to go away entirely. If you can't spare the cash you can run the seafoam mix until the next regular oil change.
  23. willmarmnxj650
    Willmar mn
    Thanks but I think I'm better off just draining all of the oil and do the sea foam I'm just hoping it will help it
  24. willmarmnxj650
    Willmar mn
    Thanks yeah he's only 2 n loves working with me helping me out in the garage it's good to teach them young he'll even use gojo and shop towels to clean his hands when he gets a little bit of grease on his hands
  25. willmarmnxj650
    Willmar mn
    Here is an update on the bike just took pics of it 5min. Ago going to use the same rear fender fill in the holes and bend the fender a little to give it that even curve over the tire going to be ordering the springs for the seat
  26. willmarmnxj650
    Willmar mn
    2 more pics
  27. mc1oo1
    mc1oo1 Member
    LB,Ca
    NICE, starting to look BRAPPED out.
    willmarmnxj650 likes this.
  28. MattiThundrrr
    Turn outs on the exhaust look good. Nice touch.
    All my recent posts are about mufflers. I'm getting EXHAUSTED!!
    Ouch.
    Mustang and willmarmnxj650 like this.
  29. willmarmnxj650
    Willmar mn
    How would I go about taking off the tachometer and the ugly plastic square turn signal flasher and only have my speedometer on
  30. k-moe
    You would buy an aftermarket speedometer and mount, as well as a blanking plug for the tachometer drive. I reccomend that you keep the tachometer; redline comes up pretty darned fast.
    Yamaha signals from the late 80's/early 90's are smaller, and will fit without needing to make any modifications. Be sure to stick with 27W bulbs or you may experience problems with the flasher relay and self-canceling unit not working properly. Lower wattage bulbs can be used, but require a bit of additional work.
  31. willmarmnxj650
    Willmar mn
    I bought a new relay switch I'm changing the turn signals to led I want to keep the old speedometer I just want to eliminate the turn signal flasher box and the tach
  32. k-moe
    You can't do that easily. The gauges are part of an integrated housing. You'd have to pull the speedometer from the housing and make your own can to put it in. I suppose that you could cut the existing housing, but then you'd have an ugly hole to fill up, and it would not look good at all.
  33. willmarmnxj650
    Willmar mn
    I appreciate the help thanks and one other question how has everybody hidden that big piece with all of the electrical pieces on the left side of the bike? I'm trying to eleminate as much as I can to give the bike a cleaner look what I did was I flipped up and some tape for now to hold it in place under the bottom side where the seat will go
  34. willmarmnxj650
    Willmar mn
    This is what I'm talking about and this is what I did any tips on how to hide most of the wiring for a cleaner look?
  35. k-moe
    Honesty, most people use the side covers ;)
    Those that clear out the middle all seem to make different choices. Some relocate everything under a custom seat (in the hump), or build an enclosure. Whatever you do, make sure that the voltage regulator (the aluminum finned bit) gets plenty of airflow.
  36. willmarmnxj650
    Willmar mn
    Thanks for the input
  37. willmarmnxj650
    Willmar mn
    So I just got my front turn signals in the mail today does anybody have any pics of how they took off there old front turn signals and installed aftermarket ones??
  38. willmarmnxj650
    Willmar mn
    Got them on :) decided to wing it now got to open up the headlight and figure out how to wire it
  39. willmarmnxj650
    Willmar mn
    I made these today at work.....
  40. willmarmnxj650
    Willmar mn
    A few pics from a little bit ago buddy from work let me borrow his wire feed welder so I'm going to start working on a few things this weekend what do yall think so far? Yay or nay?
  41. willmarmnxj650
    Willmar mn
    Wow great input on this site!! Lol
  42. willmarmnxj650
    Willmar mn
    Decided to hardtail since I was borrowing a welder
  43. willmarmnxj650
    Willmar mn
  44. willmarmnxj650
    Willmar mn
    Does anybody know if it's difficult to swap gas tasks? I want to go for something smaller
  45. k-moe
    The tank that you have is the smallest one that will fit without having to make mounts.
  46. mnrider
    mnrider Member
    Minnesota
    I thought it was a piece of cake to do a tank swap but yes you will need to make mounts which in my opinion isn't hard. You have already have done the hard tailing so I would say go for it. Find a tank that you like, buy it, and make it work.
  47. RiceBiker
    RiceBiker Member
    San Leandro, CA
    Bumpy!
  48. willmarmnxj650
    Willmar mn
    What does anyone recommend for a new gas tank off of what kind of bike? I would like to find a similar one but smaller, going to be going to local auto junk yard here and look after the snow melts a little
  49. willmarmnxj650
    Willmar mn
    Took off the exhaust going to try n tackle the minimal wiring harness wish me luck will probably be taking off the engine for repainted and body
  50. Mustang
    Mustang Member
    Masonville
    My niece was 2 years old and me and my brother gave her a wrench put it on a nut and told her to push, it was so cute she had the mad push face and everything
