How wide a tire can a seca fit?
Discussion in 'XJ Technical Chat' started by Shanesajda, Apr 18, 2016.
  1. Shanesajda
    Shanesajda Member
    southbury ct
    Have a 1982 seca 750. Not sure the stock size but id like to go a little wider on the rear tire. Im sure i cant go a ton wider but it looks like theres space on both sides of the sidewall where i can get away with a wider size. Anyone know the max tire size that will work?
    And i need new tires regardless, so any suggestions?
    And will it fit the factory rim
  2. k-moe
    There is very little extra room on the driveshaft side. Some 130 tires will fit without rubbing.
    120/90-18 is the stock size. That's the size I run, and the bike is capable of scraping the pegs.
  3. xHondaHack
    Orange CT
    I just put a pair of Avon Roadriders on my X. I'm very impressed and have no problem recommending them.
    Check out this chart for sizes available:
    http://www.avonmoto.com/products/street-bias/roadrider
    Looks like the 130/80-18 is a very close match to the 120/90-18. You should be able to sneak it past the rear diff when installing, but I would grind down the weld (where the tire would rub) just to get a bit more clearance.
    Tony
  4. Shanesajda
    Shanesajda Member
    southbury ct
    Anyone know which 130s won't fit so I don't buy one that won't work. I assume theyd all be the same
  5. Shanesajda
    Shanesajda Member
    southbury ct
    I was gonna go with Michelin if they have it, or I'll checkeep those avons
