Shifting gears not smooth. Hard to shift
Discussion in 'XJ Technical Chat' started by tjm, Apr 22, 2016.
  1. tjm
    tjm New Member
    missori
    I have an 1982 seca 550. I followed great instruction on this website to replace clutch plates and adjust the clutch. Road bike for 500 miles with no problems. Bike shifted smoothly for 500 miles. Now shifting is notchey and clunky. Hard to shift between 1 & 2nd gear. Very notcheey down shifting and hard to get out of neutral. Does anyone have any ideas on how to fix this. Thanks tjm
  2. k-moe
    Re-adjust your clutch cable.
  3. mlew
    Inspect your clutch cable first. A sudden change in the way you clutch feels and preforms in a good indication that it has stretched and is ready to break. Look at the cable end connections and see if there are any frayed wires . Cables can break in the middle but that's rare.
  4. tjm
    tjm New Member
    missori
    Thanks to both of you for your advice. I really appreciate it. It is going to be a while before I can ride/ make any adjustments. But went u do I will post how it goes. Thanks again
