Charging issue
Discussion in 'XJ Technical Chat' started by Bobbers4life, Apr 28, 2016.
  1. Bobbers4life
    Bobbers4life New Member
    Austin mn
    So I re wired my Xj550 RH to a basic hard wiring diagram off the diagram there are 3- 10amp accessories add fuse blocks. my motorcycle ran and charged the battery fine prior to me adding my headlight to one of these add on 10 amp blocks. took my bike out for a ride to makes sure it would stay charged because charging I have had charging issues with it sense I bought it got home and shut it off low battery and would not kick over and start. I have replaced everything to do with the charging system except cleaning the drum I get perfect volts when idiling and running but after hooking up my light it won't start after a ride . any ideas . 0428161834_HDR.jpg
    have you checked your brushes for wear?
    clean the copper rings while your checking the brushes
    use an eraser and electrical cleaner more eraser than cleaner.
    how old is the battery ?
    what size headlight, watts?
    did you clean the ground connection to motor and frame
  3. k-moe
    Yes. Start by looking where the magic pixies are born unto the world....the alternator.
  4. Bobbers4life
    Austin mn
    iv done all but the cleaning of the copper ring from the alternator . new brushes new wire throughout the whole motorcycle all grounds are clean and to the frame as well . head light is 12 volts if it was over 10 amps the fuse would burn out and kill it . also anyone know how many gear this motorcycle is suppose to have cant break 60mph and it sounds like its flooding carbs have been sync and rebuilt as well . thanks for the info .
  5. Bobbers4life
    Austin mn
    oh iv gone through 4 battery s trying to fix the charging issue originally so I went through the whole charging system from the ground up with all new parts . so yes new battery and tested its an acid battery .
  6. k-moe
    Fuel levels wet-set?
    Your bike should go like stink anywhere above 5,500 RPM and top out at around 110 MPH. It has a six-speed transmission.
    XJ550H likes this.
  7. XJ550H
    it is not about being over 10 amps(120 watts) it is about the wattage of the bulb 50/40 watts
    it is also high or low beam not both for the head light
  8. XJ550H
    did you ground motor to frame and battery?
    how does it run if you pull the fuse for the head light?
  9. Bobbers4life
    Austin mn
    It ran fine without the light that's why I'm wondering if it's my light il check the watts . and I can't shift to 6the gear what's the common cause of that.
    Thanks for the advice fellas .
  10. Bobbers4life
    Austin mn
    Shit I can't even get 60mph the motorcycles in my profile pick I run pods and what's wet set .
  11. Bobbers4life
    Austin mn
    It crackles and Boggs down when i try to go to 645th no go so I can't break 60mph .
  12. Bobbers4life
    Austin mn
    Oh what should be the max watts for a head light .
  13. XJ550H
    this one is a little clearer View attachment 20852
    wet set is the fuel level in the carb bowls
  14. XJ550H
    fs manual states bulb 50/40 watts that could be for a sealed beam some H4 Bulb light setups have lower wattage, but not by factory spec reasons
  15. XJ550H
    when and how did you clean your carbs.
    mine runs like the above statement, 110mph if you stop at red line.:rolleyes:
  16. Polock
    a standard H4 bulb is 55/60 watts. that's not your problem though
  17. Bobbers4life
    Austin mn
    what is then .
  18. XJ550H
    are you sure that both bulb filliments are not being used at the same time?
    did you replace the brushes only or the holder as an assembly?
    clean the copper rings.
    ground from the voltage regulator is a heavy wire on my bike I belive it is the ground at the coil pack.
    my battery grounds to motor then from motor to frame.
    have you checked the charging voltage when you start the bike? should climb to 14.2 volts at 2000 rpm. try this with head light installed and uninstalled.
    it could be your brushes are making poor contact to the copper rings
    test fuel levels
    also check to see if all your exhaust headers are getting hot you may have some cylinders not firing
  19. DrewUth
    DrewUth Active Member
    South Jersey
    Forget the silly pod filters and put a proper airbox on the bike if you ever want it to run right. What kind of RPM are you running on the motor? Speak in terms of engine speed if possible, not vehicle speed.
