fuel petcock question
Discussion in 'XJ Technical Chat' started by yamahaha, May 6, 2016.
  1. yamahaha
    yamahaha Member
    Gday fellow xjers, just wanted to know which position is which on my xj. I have pri at 3pm, res at 9am and on at 12pm. Any help greatly appreciated
  2. k-moe
    That is correct. Prime is for filling dry float bowls after sitting. On is where the petcock should normally be kept. Reserve is...well it's reserve. The petcock is vacuum operated.
  3. yamahaha
    yamahaha Member
    Yeah righto, so there is no off position?
  4. k-moe
    Correct. When engine vacuum is lost (upon shutdown) the vacuum valve on the petcock closes and shuts off fuel flow.
    Rebuild thread here: http://www.xjbikes.com/forums/posts/213052/
    Lightcs1776 likes this.
  5. yamahaha
    yamahaha Member
    Thanks my man, you're a wealth of knowledge
  6. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    On is at 6 o'clock on my bike.
  7. FetusChrist
    FetusChrist New Member
    Utah
    Random question. Instead of rebuilding or finding a new vacuum petcock I just got a gravity fed off ebay for 5 bucks and plugged up the vacuum line that led to the old. Is there any issue with doing this to these bikes?
  8. rocs82650
    Middle Tennessee
    No but add a in line filter if there isn't one.
    Gary H.
  9. FetusChrist
    Utah
    Added one with the new fuel line.
  10. JB24
    JB24 New Member
    Hebron CT
    I went the rebuild route. Easy job-did it sitting at the workbench one Friday night after Chacal set me up with the rebuild kit.
    JB
  11. k-moe
    The only issue with fitting a non-vacuum petcock is remembering to turn it on.
  12. XJ550H
    and remembering to turn it off....
