Neutral Light
Discussion in 'XJ DIY How-To Instructions' started by capdu, May 8, 2016.
  1. capdu
    capdu New Member
    Switzerland
    Good evening. I have a Xj750 Seca and making a cafe racer. I'm almost done but I have 2 or 3 problems:
    - when in neutral the light is off. It turns on when I put a gear (any gear)
    - I put a speedometer/tachometer wit led lights, the problem its with the High Beam, the led its always on. On normal ist a weak light (it should be off), on high beam its a high light, really bright led..
    Hope that someone can help me with this issues!!
    By the way, does anyone have a wiring diagram converter to eliminate the Atari and bypass the electric stuff.
    I found some ones online (here also) but, since I live in Switzerland, I must have everything working perfect, so, I can't eliminate whatever I want...
    Thanks for your time
    Carlos D.
  2. k-moe
  3. capdu
    capdu New Member
    Switzerland
    Thanks for the wiring diagram.
    Now, just have to figure out how to fix the neutral!
  4. k-moe
    There is a relay under the fuel tank that clicks when you turn on the ignition. What color of paint is on it (should be a small dot near the connector)?
  5. capdu
    capdu New Member
    Switzerland
    The relay under the tank its the blinker relay, not?
  6. k-moe
    There is the flasher relay, the self-canceling unit, and the safety circuit relay under the fuel tank. The safety relay is the rearmost. Given how the neutral switch and light work, one thought I have is that someone swapped in a different type of relay I the safety position, and that is making the light work backwards. This is only a consideration because of how easy a fix that would be compared the the other choices.
  7. capdu
    capdu New Member
    Switzerland
    I know wich one is. Its the one from Omron. I'll check it this weekend.
    Thanks a lot for the explain!!
  8. Yousef
    Yousef New Member
    Hillerod, Denmark
    Did You make it work ? I have the same problem, and just cant figure it out. Is it the blue or brown, how should it be installed correct ?
