Top Speed
Discussion in 'XJ Technical Chat' started by kelokera, May 17, 2016.
  1. kelokera
    kelokera New Member
    Dominican Republic
    Hi!! I was testing my bike last night... I was running in a high way close to my home... I try to get as fast as I could! but only get 99 miles per hour (160 km/h)... I was reading that it can do more! 127 miles (204 km/h).
    The sparks are new, I wrap the headers, the coils are new! so... I don't know how to make it faster!
    BTW, my bike is a 1982 Yamaha Seca XJ750
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    It's old and lost some compression you might be able to get some back with a valve clearance adjustment and some new piston rings (if you can find them).How many miles on teh engine and how much do you weigh? Dem nipponese test riders com in at under 140 lbs..
    DrewUth likes this.
  3. Toomanybikes
    Tsawwassen bc
    Also possible speedo error due to undersized rear tire, bad cable or bad gauge or dirty air filter or .....a million other reasons like a100man stated to big a load on the seat !!
    Ps a heavier rider only helps with launch ..prevents wheel spin
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I weigh 210lbs and my 650 can can do the ton fairly quick. Unless you're a experienced speed rider like some of the members your 750, properly dialed in, should scare the sh!t outta you when it hits that powerband. Idk about 127 but it should do the ton no problem.
    Gary H.
  5. Toomanybikes
    Tsawwassen bc
    The other thing that kills top end power is tight valves
  6. k-moe
    Mine can hit 120 MPH on a bad day. Your actual top speed will vary depending on the weather, fuel quality, and your weight; even when the machine is in top-notch condition.
    We can't assume that the compression is low without doing a compression test.
    This could be a plugged needle jet orifice, a fuel quality issue, a dirty air filter, underinflated tires, or any number of small things conspiring to lower the top speed.
    It is also very possible that the speedometer is not reading accurately. I would start looking there first.
  7. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    My question is why? I've taken my bike faster than I should have, but I can't say it was smart. I would rather know it performs well at highway driving speeds - around 70 - with enough power to get out of the way if necessary. Just my two cents.
    Jetfixer, Polock, MN-Maxims and 2 others like this.
  8. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Going that fast on a thirty plus old bike could be not so good if a brake would delaminate or a wheel bearing were to crap out. Please consider the age of that stuff when you are running it that way.
  9. rocs82650
    Middle Tennessee
    Exactly.
    Gary H.
  10. waldreps
    waldreps Active Member
    Henning, MN
    That pops into my head sometimes even at normal highway speeds...gives me the motivation to keep up on the maintenance. :D
  11. rocs82650
    Middle Tennessee
    Agreed. I consider myself lucky to have found this model specific forum which absolutely leaves no stone unturned as far as maintenance/wrenching on these bikes. There are many things covered here that a lot of decent shops wouldn't do. These were very well built bikes for the era. A properly recommissioned and maintained xj will "get it" in good form and do it for years.
    Gary H.
  12. jayrodoh
    jayrodoh YimYam
    Cleveland
    You could also replace your POD filters with a factory airbox :D
  13. XJ550H
    why ? Just to know it can.
    I can not tell how fast my 550 maxim will go due to speedo not going up that high but I know it will exceed red line in 6th gear which should be about 110 mph.
    I was testing out some tci boxes
    what was your tach reading? if you redline it you would be going the max speed listed in the specs.
    as long as clutch does not slip and tires are proper size
    Kickaha likes this.
  14. Lightcs1776
    Upstate NY
    To each their own, but I did that kind of thing when I was younger. Sometimes I am amazed I lived through those years.
    Mechanic1978 and DrewUth like this.
  15. MN-Maxims
    Saint Paul, MN
    I did stuff like that too, but as you get older you tend to think how long it takes to heal road rash. No Thanks
    Lightcs1776 and DrewUth like this.
  16. DrewUth
    DrewUth Active Member
    South Jersey
    And how nice it is to have a bike that looks and works well haha. My XJ is the first bike I can say I have had 00% interest in modifying in any manner.
  17. MN-Maxims
    Saint Paul, MN
    I let the crotch rocket guys riding along on their back tire blow by me on the freeway and I just wave at them.
  18. k-moe
    I forgot that he has pods. 99 MPH will probably be about it then. ;)
    mlew likes this.
  19. Core
    Core Active Member
    Switzerland
    If you suspect the speedo is not reading right there is a really fast way to check it.
    Take your smart phone and download one of the many GPS speedo apps around. You should not need to pay for any of these.
    GPS speedos work by taking GPS fixes on the earth surface in rapid succession. Their algorithms simply do a distance vs time comparison between the fixes, and then smooths out the answer. All errors are random and cancel eachother out in the smoothing. Result: when you are moving at any speed more than 10kmh, the calculated speeed will be spot on.
    This is converse to the way the mechanical speedo works, which takes a reading from the front wheel in many cases, errors will be systematic and affect the speed in a constant way.
    If you can´t mount your phone next to your speedo, then have it somewhere where it can receive the sat signals and run the bike up to a certain speed. These GPS speedo apps usually have a max speed function. Compare and see what the error is.
    As we all know, speedos usually read a little faster than reality. Urban myth I´ve heard is that the manufacturers (cars and bikes) want to remove any chance of liability in speeding issues with drivers.
    I know that my XJ900RL is always reading about 5khm over which is quite normal. But at about 80khm the speedo starts to occilate +/-10khm (making it bloody useless) and then after about 95 it settles back down and is pretty much spot in if not reading a little low.
    Havent had mine beyond 140khm so far. Before I try that I want to have new brake lines at the very least.
  20. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Do you have a local drag strip in your area? Other than a GPS, a trip trough the traps will tell you electronically how fast you are going. You don't have to put in a full day, just a few runs would do. They also have a full onsite medical (Ambulance) available, that way if something lets go you will get taken care of right away instead of laying in a ditch or on the road until someone stops by. Plus you won't be breaking any local laws.
    2 cents!
  21. rocs82650
    Middle Tennessee
    Disclaimer: If you get a speeding ticket it's your fault.
    Download the digihub app. Tape your phone to the tachometer and go for a ride.
    Gary H.
  22. XJ550H
    I use the radar trailer the PD parks around town to check my speedometer.
    Hand and MattiThundrrr like this.
  23. rocs82650
    Middle Tennessee
    He's asking about top speed. About five years ago before I cleaned my speedo drive I paid a decent fine for going 73 in a 50. I thought I was going 55 or so.o_O
    Gary H.
  24. Core
    Core Active Member
    Switzerland
    Stuff the speedo, a raz down the 1/4 mile a few times is worth it just for fun's sake.
    would pods instead of the stock airbox really take so much performance away?
    I´ve been reading more and more about the carbs and the air filters and air flow and starting to get a sense for the influence that the air flow and relative air pressures can do to the performance of the engine.
    So a tuned in set of Pods in your opinion will still strip off quite some hp off the engine?
    (I know this is now sort of off topic)
  25. mlew
    Yep
  26. XJ550H
    just to know how fast the bike will go ...:)
    there is a post in a thread where Yamaha explains why you should not pod.
    it is likely possible to get it right if you have the proper equipment and knowledge base.
    we have a few people here who run pods but they seem to keep what they did to themselves.
  27. mlew
    Yes, yes and yes.
    CV carbs don't like all that free air. If you change the style of carbs then that's different. Not many in the XJ community are going to drop a grand on a set of carbs so they can get the benefits of pod filters. That's more that they paid for their bike.
    POD filters look good but make the bike suffer in performance and fuel mileage.
    Core likes this.
  28. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Our town has a radar speed display coming into town on one road. It is a 25 mph zone. I use it to test my speedo, and it is accurate to 30 mph. Since I don't want a ticket, I'm not testing it further!
    Some years back I ordered an air filter from the nearby Kawasaki dealer - they got me a pod filter. I guess a lot of people convert.
    Me, I'm keeping my bike as close to stock as I can.
  29. XJ550H
    we get pulled over at 12 mph over limit ticket at 15 over.
    our trailer is moved around to different speed zones.
  30. XJ550H
    the air box design allows backwash gas to be sucked into the other carbs,with out the common connection , pods would keep the excess fuel in filter until next cycle.
    the oval filters used for 2 carbs would be eaiser to use,
    if you had a well designed pod you could work the carbs to the pod. Pods are for max air flow which is what I see as the problem using them on cv carbs.
    then of course there is the boot which serves as a velocity stack.
    the best place to install pods would be inside the air box, but then you lose the "look" of having pods and still have to deal with excessive air flow=lack of vacuum
    part of podding may well be as simple as changing the spring in the diaphram setup to allow it to rise easier.
    interconnection of pods might help.
    many thoughts just no desire to spend money trying to work it out. Each change in the pod would require expermenting with jets.
    I would rather be riding as I can not see the pods when rolling down the road
    Core likes this.
  31. k-moe
    Pods really aren't for max airflow though. They look like they should flow more air, but in practice they don't always. The XJ airbox is realtively restrictive, but the advantages from the waveforms generated in the airbox overcome that restriction. In addition to providing the airflow necessary to allow the carb slides to move properly (and quiet intake noise), the airbox also uses the resonance developed from the "blowback" of the cylinders (a consequence of valve overlap) to force-feed a little more air through the one carb that is working on the intake stroke. With individual filters that free-supercharger (as Kevin Cameron calls it) does not exist.
    Have a look at what a modern aribox looks like on a sportsbike. They are huge, and have many different shapes within to further tune the resonance for maximum effect in the midrange (exactly where we see pods cause a flat-spot in our XJs). This is done even on (most) fuel injected race bikes, where one would think that pods would have an advantage without causing any fueling issues.
  32. Core
    Core Active Member
    Switzerland
    well that was a good fishing trip of mine. A mine of information.
    Super thanks to you all for shining a flood light on the issue.
    A
  33. Jerrod Robinson
    Jerrod Robinson Member
    Cardington, Ohio
    Yeah it will do better then 100, but not much. And it's the Transmission Restricting it so you really can't do much about it. Especially because it's Shaft Driven..
