Carb Trouble
Discussion in 'XJ Technical Chat' started by ChaseP, May 16, 2016.
  1. ChaseP
    ChaseP Member
    Texas
    I'm restoring my grandfather's 650 that has been laying on its side ever since he passed. So far the engine turns over, but the bike wont start. Each cylinder is compressing but no gas is pumping. I currently have the bike pretty ghetto rigged with a water bottle full of gas going to the carb (I'm a broke college student). I'm thinking that the carb needs to have a vacuum line connected to the petcock on the gas tank but I can't test my theory because the gas tank is completely rusted as is the petcock. This is my first decent bike I've worked on so any help would be greatly appreciated, especially good pictures of the inside and outside of the carb.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  3. XJ550H
    you need to start by cleaning the carbs inside and out, ohm out your entire ignition system. take a spare spark plug and test for spark on each plug wire plug plug into cap and ground hit starter button see if you have spark,
    if it has been laying on its side check oil level
  4. ChaseP
    ChaseP Member
    Texas
    The first thing I did was clean my carb out. I'm not too confident in the condition of my jets and float needle. I changed the oil and oil filters, but I'm a little worried that it is too full (could that play any role in causing it to not start?) and checked the spark plugs they all give sparks.
    Could you give me more information on how to ohm out your ignition system?
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    What do you think is too full, Engine oil ? Carb float chambers? you really do need to clean teh carbs thoroughly (all jets out loads of carb cleaer aerosols etc..) It aslo helps to have a basic knowledge of how they work. The ignition should 'just work' Fuel delivery is the key to getting these engines running and that includes valve train (clearances etc..)
  6. ChaseP
    ChaseP Member
    Texas
    The oil level. When I changed the oil the new oil didn't settle as much as I thought it would. I plan on cleaning them again today
  7. ChaseP
    ChaseP Member
    Texas
    It does thanks a ton!
  8. ChaseP
    ChaseP Member
    Texas
    So I discovered that my main jet and air pilot jet were switched (shown in picture). Would that explain why no gas was being pushed to the
    cylindersi254.photobucket [dot com] /albums/hh107/RickCoMatic/Yamaha/P5231436-1.jpg
    hogfiddles likes this.
  9. k-moe
    Unless you followed the Church of Clean, you didn't really clean the carbs.
    Is the petcock allowing fuel to flow on prime? On RUN?
    Open the float bowl drains. Does gas come out?
    I strongly suggest that you slow down, read the Information Overload Hour (link above) and only start work on the bike once you have an understanding of what needs to be done to each system to ensure that your machine will run reliably and safely.
    The swapped air jets were a problem, but a bike will idle even when they are swapped, so your problem lies elsewhere.
    jmilliken likes this.
  10. ChaseP
    ChaseP Member
    Texas
    I need to purchase a new petcock and gas tank because of rust. I currently have the gas fed by gravity through a water bottle until my next pay check so I guess no to your first question.
    I can't seem to find the float bowl drain but I'm pretty confident that the float bowls is filling up because after I attempt to start the bike and then remove the carbs gas pours out.
    I plan on researching my carb more so that I can understand it better so I can figure out exactly what is wrong with it once I can find the time after work. But for now I'm going through the process of the link you attached (meaning I'm going to completely break down all four carbs from the rods). I would like to know if the current gravity fed fuel system will work before I break the carb down and build it back together though?
  11. ChaseP
    ChaseP Member
    Texas
    I'm also wondering if its even important to sync the carbs up at this point if the engine isn't getting any combustion? I don't think that my diaphragms are bad but none of the pistons or needle valves are moving. I'm not sure how to fix this.
  12. sybe
    sybe Active Member
    NYC - Brooklyn
    Do you have a breather hole in the water bottle? If not the gas isnt moving. Drain the float bowls to make sure gas is going in. Also are you getting a spark at the plugs?
  13. XJ550H
    are you trying to move them with your finger?
    the diaphrams are vacuum operated they do not move with the throttle
    if they are frozen in place you have to use cleaner to loosen them
  14. ant797
    ant797 Member
    western australia
    should be able to set your petcock to pri to have fuel flowing freely if not take it apart and clean it ... simple idea is that fuel hose going to carby might be swelled or clogged
  15. ChaseP
    ChaseP Member
    Texas
    No breather for the bottle I'll try that however the carbs' float bowls still fill up so I don't think that is the problem. Yeah, every piston has compression and ignition but there isn't any combustion (no gas flows into the engine).
    I've moved one while turning the engine over however nothing happens. They sound sealed and I think I hear gas flowing when I push them but I think that there isn't any pressure build up to move them. Thats why I was concerned if I should have a petcock installed for the vacuum line. I've extensively cleaned the diaphragms' pistons with carb cleaner so they should be lubricated enough to operate.
    My petcock is beyond repair. Ordering a new one with a gas tank when I get paid.
  16. ant797
    ant797 Member
    western australia
    your pilot jet and main jet in the bowl could be switched around on one or more or all carbies by happenstance i accidently did this with mine not knowing what i was doing causing it to run ultra rich and soaking the spark plugs
  17. ant797
    ant797 Member
    western australia
    my advice to you if your a broke college student is to flog it off for whatever you can get for it by the time you overhaul it it will cost thousand or more to get it safe most likely have to replace the back brake pads cause they delaminate ..overhaul the front brakes new brake pistons and seals ..master cylinder rebuild .. new brake lines ...and by the sounds of it you need to replace a lot of rusted gear ...proberly by the sounds of it like mine you have a rusted frame along the lower kickstand side ..after its welded you will need to paint frame etc etc etc
  18. ChaseP
    ChaseP Member
    Texas
    I switched those already a would still run just fine even if they weren't switched.
    Not really an option. I already knew it would cost a lot its kind of the point of getting a project bike.
  19. k-moe
    $1000 is still cheaper than a newer used bike (that will still need work done).
    Lightcs1776 and ChaseP like this.
  20. ChaseP
    ChaseP Member
    Texas
    Just in case my thread is relevant to anyone this diagram helped out extraordinarily
  21. ant797
    ant797 Member
    western australia
    theres to sets of two jets two under the top lid under rubber diaphram ... and two under the bottom fuel bowl ....i would check the rubber diaphrams for holes and that there seated properly also check the slides to see if anyone has drilled holes to modify them if you found one set of jets the wrong way around check the others oposite end
  22. ant797
    ant797 Member
    western australia
    kmoe also posted this .....
    By air jets, he means the ones under the top hat, below the slide diaphragm. All of the service manuals have their positions labeled incorrectly.
    This is the corrected image:[​IMG]
  23. k-moe
    RickCoMatic posted it; I just borrowed the image.
  24. ChaseP
    ChaseP Member
    Texas
    I linked that picture. Everything is put together correctly. Its just a matter of making sure everything is clean, sealed, working, and the carbs are connected to the bike properly.
  25. ant797
    ant797 Member
    western australia
    i dont know much about head gaskets on air cooled bikes but for some reason im thinking head gasket or warped head for someone just to dump it on its side like rubbish for so long and you having suposedly saying it got good spark turning over and carbs all good and clean
  26. k-moe
    I apologize for missing this earlier.
    Without a way for pressure to equalize in the bottle, fuel will stop flowing as soon as enough gasoline flows out to cause a low-pressure area in the bottle. Vent it.
    ChaseP likes this.
  27. k-moe
    I would not jump to that conclusion.
    Head gasket failures do occur, but even then a bike will usually run.
  28. ChaseP
    ChaseP Member
    Texas
    Ruined the rubber on the valve for the float and the plastic for the choke to slide with carb cleaner so I got to replace those. As soon as I put the carb back together (healthy) I'm going to try and vent the water bottle. It makes sense that the vacuum won't work against the pressure in the bottle; I suspect that to be the problem.
  29. ant797
    ant797 Member
    western australia
    not exact same carby but gives you the gist
  30. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Check your valve clearances and compression test too.
  31. hogfiddles
    If you're sure you're getting gas into the bowls, but it's not getting to the cyl, then either your floats are not set right,or you have other clogs there
  32. ChaseP
    ChaseP Member
    Texas
    Finally got the carb put back together and I borrowed a dirt bike tank and it starts up! Lesson learned; vent necessary. Thanks everyone for the help (even if you gave bad advice -- we're all here to learn). I'm having difficulties trying to get it to idle now. I started another thread asking for help with the idle problem; I'd appreciate any further input helping me get my bike running.
  33. k-moe
    I noticed the thread, but didn't catch that this was the same bike. Please keep one thread per machine so we can look at everything that was done previously.
    ChaseP likes this.
  34. k-moe
    From the other thread.
  35. ChaseP
    ChaseP Member
    Texas
    K-moe: "
    Start by telling us how you cleaned the carbs. Did you do a full dissasembly, dip, and replace the throttle shaft seals?
    Did you perform a bench synch?
    Are the intake boots cracked?
    Did you replace the vacuum caps and vacuum line for the petcock? "
    Full dis assembly.
    Soaked the smaller pieces and used q-tips + carb cleaner on the rest.
    Replace the throttle shaft seals with a homemade fiberglass ring (I think we're talking about the same thing.)
    No bench sync.
    One is cracked but its before the fastener, not between the carb and engine.
    The current petcock doesn't have a vacuum line. I should probably get a new gas tank asap.
  36. ChaseP
    ChaseP Member
    Texas
    Really I'm not expecting anyone to say "do this" and it work. I'm more of expecting a list of things to look at.
  37. k-moe
    Problem one. Fiberglass rings do not a seal make. I hope that you are talking about the plastic washers that go on the throttle shafts, and not the seals that are rubber and have to be dug out from the throttle shaft bore.
    Throttle shaft seal (not actual size)
    This is a different carb, but it shows the seal (green in this case) in the throttle shaft bore.
    Leaky throttle shaft seals will create a lean feedback loop that will cause the engine to race.
    Bench synch is an important step and should not be skipped: http://www.xjbikes.com/forums/posts/51960/
    The crack on the intake boot may, or may not, be an issue due to the location. We'll tackle that by spraying carb cleaner on the crack to see if the idle changes, but I would like to know more about the throttle shaft seals before we go there.
  38. ChaseP
    ChaseP Member
    Texas
    First things first I'll get a good throttle shaft seal. I through that that was more of a bearing to keep the Al grinding is there any solution to this seal without going out and buying the designed part. Maybe rubber grommets from Lowes or auto zone? The choke plate shaft's have grooves notched into them that could hold o rings.
    I was under the impression that to bench sync you must have the bike idling first. How would I go about the bench sync without an idle?
    I can't seem to find any seals made for my 650 online for sale a link would be great.
  39. k-moe
    In my opinion there is no good substitute for the proper throttle shaft seal, however........
    @Polock has an alternative that involves doubling up viton o-rings. Perhaps he'll chime in with the details.
    A nench synch is done with the carbs on your workbench, and is done in order to help ensure that your engine will idle upon the first startup. http://www.xjbikes.com/forums/posts/51960/
    After you get a good idle, then you do a running synch using a monometer, or vaccuum gauge (home-made is fine).
    Start a conversation with Chacal. He has the throttle shaft seals in stock, and will never sell you the wrong part (unlike most of the online retailers).
    Jetfixer and jmilliken like this.
  40. ChaseP
    ChaseP Member
    Texas
    Thanks! I'll get on that asap. Work is picking up as well as I got a second job at Harley Davidson so it may be a little while but I'll post as soon as I complete my checklist.
  41. Polock
    two #11 o-rings for each seal can work. you have to use liberal silicone grease when you install them and you're going to find the clip on the outside of the 1 and 4 carbs tricky to get on but not really hard to do. you'll also find the throttle shaft is tight but a few dozen cycles by hand while you're getting the rack together loosens them up to the point they snap back as intended.
    i looked at mine last year and they looked like the day i put them in
    ChaseP, Jetfixer and k-moe like this.
  42. ChaseP
    ChaseP Member
    Texas
    I'm waiting for new boots to come in. While I'm waiting for the boots I'm trying to find a gas tank but I cannot find one that will not need major dent and rust repair. I know 750's and 650's can be swapped. What gas tanks can be used for my model ('81 650)? I would prefer larger tanks.
    I went to Lowes looking for #11 orings but they were clearly way too large... Do you remember where you purchased your's from and the brand?
  43. Polock
  44. DrewUth
    DrewUth Active Member
    South Jersey
  45. hogfiddles
    Assuming you mean a 650 MAXIM, your direct bolt-on swap for a larger tank would be the 750 MAXIM.
  46. ChaseP
    ChaseP Member
    Texas
    750 tanks are still hard to come by in good condition. Is that the only interchangeable tank on the market?
  47. k-moe
    Yes. But you can make any tank fit with surgery.
  48. jmilliken
    Dillsburg, PA
    Duct tape and JB Weld
  49. ChaseP
    ChaseP Member
    Texas
    That was my plan but I didn't want a tank that would interfere too much with the handlebars but I lucked out and found a 650 tank for $50.
  50. ChaseP
    ChaseP Member
    Texas
    I finally got all of my parts in (except for the #11 o-rings) and discovered that the airbox was bad and that was why it was running so lean causing it to race away. I put coffee filters on all four carbs and it idles but it seems that its only idling on the first cylinder (closest to the fuel line and the only one connected to the vacuum on the petcock). I didn't get much more time to tinker with the bike. Any ideas on why only the first cylinder is getting fuel. Important to note that it is flooding the cylinder on occasion and shooting flames.
    Also, to replace the airbox I would like to put pods on. Any advice on what that entails as far as re-jetting the carbs, aftermarket exhaust. ect. Planning on just going for a straight pipe.
