1982 xj650 complete engine rebuild and bobber conversion
Discussion in 'XJ Modifications' started by Eurotas, Apr 24, 2016.
  1. Eurotas
    Eurotas Member
    Edmonton
    Hey guys, I'm new to the thread here, and I have just acquired my first XJ bike. This will be my first bike to modify. What I'm looking for is some help so that I don't mess anything up. Engine ran ok, but doesn't anymore. Pulled the valve cover off, and found intake cam gear missing. I'm guessing the previous owner didn't know what he was doing, and now I have a dead engine.
    So now I have broken cam gear pieces at the bottom of the engine. Surprisingly there's no damage to the head. Just a few scratches from when the cam gear snapped. I realize that this requires a complete engine tear down, in order to get them out. Another thing that I've read is that the shifter fork can become bent/damaged, resulting in second gear not working and so on. What sort of things should I be doing to rectify that situation so that its doesn't happen to me when I have the cases split?
    I'm looking for some "how-to's", or advice on what i should be replacing in the engine since it'll all be completely apart. I figure since it's all apart, might as well put everything new in there. Money isn't really a factor. So whatever this bike needs, I'll buy it.
    The next thing I'd like to know is where you guys find your parts from? Obviously Ebay, but are there any other companies out there that specialize in parts specifically for this bike that can't be found elsewhere?
    I'm thinking that since it'll all be apart, I might as well change all the bearings, starter clutch, clutch plates, etc. So I'm going to need some help sourcing out information and parts for that. I'll be buying the clymer manual here shortly. Is there any special tools that I need? If so, where do I get them?
    The next thing I'm after is I would LOVE to put a Springer front end on this bike. I've done some reading, and have only found two companies that make the Springer front ends, however, they are only for the XS650. I have also read in some posts that they are compatible with each other. Has anybody in this forum done this swap before? If so how did you do it? What modifications need to be done in order to install it on this bike? Come hell or high water, that Springer is going on this bike lol.
    As for the rest of the bike, I'm chopping the rear of the frame off to build a bobber. The only thing I can't decide on is if I want to some how incorporate the rear suspension in it, or just leave it as a hard tail. What are your thoughts? I like the clean look without the rear springs, but is my back going to suffer? I've never owned a hard tail before, so I have no experience to speak on the matter.
    I'd like to find a decent exhaust kit on this bike, as I absolutely hate the look of the stock exhaust. Anybody have any ideas on that? I'm thinking I'd like to go with the wrapped look, but I'm not 100% sure on it yet.
    I'd like to go with some spoke rims on this bike. How do I find some rims that will match up to this bike? What measurements need to be taken? Can someone recommend where to get a decent set of rubber with white wall?
    And lastly, if there's any cool modifications that you guys have done, or know somebody else has done, gimme a shout! I'm open to all ideas right now. The head light is going away, as well as the turn signals and stock gauges. I'm going to be putting something a little more modern on the bike.
    This bike is going to be for the wife, so every small detail will not be overlooked. I'll need all the help I can get! I'd like to have this thing built in 6 weeks or less. Thanks in advance guys, I'll post some pictures soon.
  2. saftie
    New York, NY
    Hi,
    This is a very ambitious project. And unless you can work on it 24/7, I'd say not possible in 6 weeks, especially since this is your first bike to modify AND engine work is involved.
    If money is not really in issue, why not buy something running that already has most of what you are looking for? And keep the bike you have and slowly transform it into what you described above.
    Click the top right banner for parts. Len has everything.
    And you sure your wife would like a hardtail?
    Break your post into individual threads, and you'll get answers faster.
  3. a100man
    a100man Well-Known Member
    Bedford, UK
    Taking 6 weeks off work then or are you retired?
  4. Chance
    Chance Member
    Rockland, Ontario, Canada
    Welcome and wow wanting to complete it in 6 weeks is a lot, you will want to look at the catalogue at http://www.xjbikes.com/forums/forums/xj4ever-supporting-vendor.23/
    And then contact Chacal. He has parts and tools for rent. He has several kits available I would look at getting kits, and complementary kits and individual parts as well.(I myself am still going through the catalog for my xj550 parts, I was planning a weekend engine rebuild, now planning for winter rebuild so I can ride in the meantime) If this is for your wife and it will be her first bike, not really sure I would make it a hard tail.
  5. Eurotas
    Eurotas Member
    Edmonton
    I already have a nice bike for myself :). I have aaaaaaa lot of experience with fabrication.
  6. Eurotas
    Eurotas Member
    Edmonton
    Lol i don't work as much as I used to. Got a lot of free time now!
  7. Eurotas
    Eurotas Member
    Edmonton
    So does anybody have any info in regards to the Springer installation using either a DNA or tc brothers Springer kit?
  8. k-moe
    One quick question. Is this a Seca or a Maxim? If it's a Seca 650 then I suggest that you take time to reconsider your plan. That was a one-year bike in North America, and a lot of people are nolstagic for it, so long-term it will have greater value if left stock.
    When the engine is apart, rebuild the starter clutch and replace the alternator chain guide. The second gear dogs can be undercut, but second gear dog slippage is not nearly as much of an issue in the 650 as in the larger displacement machines.
  9. Eurotas
    Eurotas Member
    Edmonton
    15U000589 is my vin if anybody can some how check it.
  10. a100man
    Bedford, UK
    Should I start an export business then ? 650s don't fetch much here and we only got the 'Seca'.;)
  11. Eurotas
    Eurotas Member
    Edmonton
    Lol I dunno, I just wanted something to do instead of sitting around.
  12. k-moe
  13. Eurotas
    Eurotas Member
    Edmonton
    Well then it's gonna be one of a kind seca then!
  14. k-moe
    Get it reunning perfectly in stock form before you start doing modifications. It will save you time in the long-run.
  15. Eurotas
    Eurotas Member
    Edmonton
    I'm doing that outside of the bike itself.
  16. Eurotas
    Eurotas Member
    Edmonton
    Does anybody have a quick list of all the bearings required to be replaced inside the case on this engine?
  17. jayrodoh
    jayrodoh YimYam
    Cleveland
    There's no quick list. You need to plastigauge all of them once you split the case and see what's within limits. If one or more is out of spec, then you have the fun task of determining what bearing is in there currently and sourcing the correct one. There' a few threads on here where members have rebuilt their motors and have some how to pics on bearing sizing etc.
  18. Eurotas
    Eurotas Member
    Edmonton
    Oh I should've clarified, I meant roller bearings not main bearings.
  19. Polock
    don't remember anyone ever replacing the roller bearings.
    now you're down to 5 weeks and 6 days :)
    Stephen Downey likes this.
  20. Eurotas
    Eurotas Member
    Edmonton
    Lol engine is half apart as of last night, doing the rest tonight and hopefully plastigauge soon.
  21. Polock
    i won't get much done until the play-offs are done
  22. a100man
    Bedford, UK
    Polock, dear friend, your sums are poor. I make it 10 days in so only 4 weeks and 4 days remaining.
    'Easy,easy..' I hear them chant.
  23. k-moe
    It would be quite unusual for any of the roller bearings to need replacement, which is good since at least one of them is NLA.
  24. Chance
    Chance Member
    If you have no snags, and all you really need to replace are your gaskets, you could be done sooner depending on your available free time and part availability.
  25. Eurotas
    Eurotas Member
    Edmonton
    I've been busy for a little while. However I do have a question. What size of bolt is required to remove the alternator rotor?
  26. Chance
    Chance Member
    Try messaging Chacal he probably has that info or the bolt you need....
  27. Eurotas
    Eurotas Member
    Edmonton
    Ok thanks! Got that sorted out. On a side note, what kind of specs am I looking for when it comes to doing a plastigauge?
  28. Chance
    Chance Member
    I believe these are the specs you are looking for
    Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006")
    Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
    I could be wrong though. (it does happen from time to time)...lol
  29. k-moe
    All of that info is in the service manual, and you will want to have both the Yamaha service manual and the Haynes on hand as you reassemble the engine.
    Chance likes this.
  30. Eurotas
    Eurotas Member
    Edmonton
    Ok thanks man, will do.
  31. Eurotas
    Eurotas Member
    Edmonton
    So fellas, been working on the bike off and on for a little while. Just wanted to put up some pics to see progress.
  32. Eurotas
    Eurotas Member
    Edmonton
    So here she is
  33. Eurotas
    Eurotas Member
    Edmonton
    All gutted
  34. Eurotas
    Eurotas Member
    Edmonton
    Here's the Springer front end we bought for it
  35. Eurotas
    Eurotas Member
    Edmonton
    Here's the tank we took home to try and get an idea if it will work or not. What do you guys think? I think it's too big to be honest.
  36. Eurotas
    Eurotas Member
    Edmonton
    And here's my issue with the bearing races. Left race is the new one, right race is the stock one. Gonna have to do some digging to figure out if I can get a bearing that small, otherwise I'll have to get some machining done :/.
  37. k-moe
    The new race will fit. Search for the thread on roller bearing swap.
  38. Eurotas
    Eurotas Member
    Edmonton
    Nah it doesn't fit, the race is 2mm larger than stock
  39. k-moe
    Larger in diameter? Then no it won't fit, and it should not be machined thinner, nor should the headstock be bored out to accommodate it. The stem from the stock triple should be swapped onto the springer triple.
    If it's 2mm taller, then it will fit as long as the springer stem can accommodate the increased height.
  40. jayrodoh
    jayrodoh YimYam
    Cleveland
    The race for a tapered roller is taller vs. a ball bearing race. The replacement kit for the stock ball bearing kit is taller but works just fine (ask the hundreds that have upgraded). Like k-moe said if the diameter is good, try it and see if the springer front end can accommodate the additional height.
    Eurotas likes this.
  41. Chance
    Chance Member
    Not really sure if it was seated a little better it may make a difference, the way it is sitting now it doesn't follow the flow so it could be skewing the vision.
  42. Eurotas
    Eurotas Member
    Edmonton
    Too late, getting machined right now as we speak lol.
  43. Eurotas
    Eurotas Member
    Edmonton
    Well I figure that if I were to use that tank, I'd have to cut it up and make it fit to the frame. I'm honestly thinking of just taking the bike to a metal fab guy, and having them custom make me a tank that will fit perfectly instead of just trying to find one that will fit "ok" if you know what I mean? Unless someone here has a better idea?
    Chance likes this.
  44. k-moe
    Taking 2mm off of the diameter? The race will fail when you least expect it.
    Taking 2mm off of the height? The bearings won't fit correctly, and will eventually fail in a bad way.
    Roller bearings really need the full support of the race, as it was engineered. There is some room for machining, but 2mm is a lot of material to remove.
  45. Eurotas
    Eurotas Member
    Edmonton
    Sorry I should've clarified. The machinist is taking off approx 2mm of width, and about 3mm in height. It'll be fine, there's plenty of meat left over. How does a race "fail", other than being neglected without any oil or grease and it grenades itself? I'm a heavy duty mechanic, and i've seen tons of bearings over my career, and it takes quite a substantial amount of abuse for a tapered roller bearing to fail.
  46. k-moe
    If the race wall has enough thickenss then it will be fine. In my experience most roller bearing races for motorcycles don't have much wall thickness (particularly when the bearing is replacing a ball bearing setup), and that can lead to uneven loading as the race distorts. One thing that can kill a modified roller bearing is lack of full contact for the roller. A rige can form along the edge of the roller that contacts the cut-down race. So long as the rollers get full contact along the bearing race then it'll be fine.
    I tend to err on the cautious side where modifications to the headstock and bearings are concerned. You've got the part in hand, and I do not, so your judgment is likely more sound than mine.
  47. Eurotas
    Eurotas Member
    Edmonton
    Yeah, there's a tad more than 1/16" of meat in the neck after it gets machined, so I'm not worried. I just liked the idea of a tapered roller bearing because I can actually get parts, vs using the stock ball bearing set up, plus there was even more hassle if I just went with the stock ones. I looked up the tapered roller bearing kit that all balls sells for my bike, but that wouldn't have worked either because the ID is still 25mm, and the stem I'm using on my springer is 1" which is slightly bigger. Plus the height of their bearings were something crazy like 15mm, and the set I have the height is slightly over 10mm. I think it'll be gravy and fit like a glove once I get the frame back next week. On to my next hurdle is that damn spoke wheel that I want...
  48. Eurotas
    Eurotas Member
    Edmonton
    Just took this at the machine shop!
  49. Eurotas
    Eurotas Member
    Edmonton
    Little further away
  50. k-moe
    Looking good.
    Eurotas likes this.
