Look what came with some soft bags I bought...
Discussion in 'Hangout Lounge' started by skiprrdog, May 28, 2016.
  1. skiprrdog
    skiprrdog Active Member
    Tucson, AZ
    I really wanted the soft sided luggage he had with the bike, but he would not separate it out... so...
    Only had a Honda once, in high school, so this ought to be interesting. Carbs already rebuilt, just waiting on some new carb fuel pipes, and then go out and *romp* on it some :) hon6.jpg
    Alan63 and Stumplifter like this.
  2. Toomanybikes
    Tsawwassen bc
    As long as the cams are good should be plenty fast
    Sold those new back in the day v65 motor had about 125 hp
  3. k-moe
    The cam problem was solved early on. Getting the carbs out for servicing on the other hand.....
    Be very thankful that job was already done.
  4. skiprrdog
    Tucson, AZ
    The carbs.. *OMG*... unfortunately I took them out for servicing. Prior to the Honda, the 'worst ever' award went to a 1980 KZ550 I had; the Honda is the new champ. Not looking forward to putting them back in :|
  5. Chance
    Chance Member
    Rockland, Ontario, Canada
    Nice looking bike, I think I see where the carbs go.... :rolleyes:
  6. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    they suck pretty hard. but if you google there are a couple methods that might work for you. at least better than just trying to wiggle them in.
    last set i did, the normal stuff didnt work and spent hours on it. got mad, got a 3in ratchet strap and force them in the boots that way. desperation for sure but it did work and it didnt brake anything
  7. Toomanybikes
    Tsawwassen bc
    As with xj's nice soft and new intake manifolds are the key
