oil leak
Discussion in 'XJ Technical Chat' started by roalmc77, May 16, 2016.
  1. roalmc77
    roalmc77 New Member
    I parked the bike late last October in my garage after another successful riding season. I am in my garage every day. In mid November I went out to my garage and my bike(82 Yamaha maxim xj650) leaked oil all over the garage floor, not a small leak by any means. I have been trying since then to find a mechanic since my old mechanic no longer works on bikes (got a real job I guess???). I have still been unable to find a mechanic that will look at it. I am to the point where im thinking of trying to figure it out myself. I am not sure where its leaking from or anything yet. I am good at following directions but not a mechanic by any means. My mechanicish achievements are changing an alternator on a car and cleaning a carb on a push mower. Both thanks to youtube and diagrams on autozone website lol. Is this something I should be attempting on my own? I am assuming its a seal or a gasket somewhere. oil seemed to be coming from just forward of the center kickstand. Thanks for reading and for responding, I have already missed too much of this riding season.
  2. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    Hi! First thing to do is to band your knees and have a look where it comes from, maby you have to clean up a little and fill some more oil if level is low,then take it from there. Maby it's just a leaking drainplug or levelsensor.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Maybe you left the petcock on prime and gas filled the crankcase and overflowed all over the floor. See if all the gas is gone.
  4. Big swede
    Gothenburg,Sweden
    +1
  5. Jetfixer
    Agree +2 remove your oil filler cap smell if oil smell ok gas? check sight gauge with bike on center stand. If oil is covering window you will need to drain oil, change oil filter. Refill with clean oil , before you run bike , rebuild the petcock ( it is cheap around 25$ from xj4ever) drain tank down , remove 2 screws holding petcock there are links on this site on rebuilding .
  6. roalmc77
    roalmc77 New Member
    I believe it's straight oil, wasn't on prime, peacock area looks clean, I took pics oil seems to be mostly coming from right behind the side stand.
  7. mlew
    Kind of hard to pinpoint an oil leak on a dirty engine. Wash and clean the engine, get all the oil off. Then you can tell where it is coming from. There are so many possibilities as to where it is leaking. Cam chain tensioner , valve covers and side covers are the most likely.
  8. roalmc77
    roalmc77 New Member
    Ok will do just drained rest of oil was only like a coffee cup full. Gonna clean it and put some more oil thru it seems if it becomes more obvious where oil is coming from
  9. mlew
    Your bike has 2.5 liters of oil in it. So you are saying that 2 liters of oil leaked on the floor and there was only a little left in the bike? That's not good. I would look closely at the drain plug and oil level sensor, maybe even shifter cover gasket or shifter seal.
  10. XJ550H
    maybe drop a quart of oil in it and see where it is leaking, sounds like it poured out quickly
  11. roalmc77
    roalmc77 New Member
    I drained it refilled it ran it shifted into first rode it around the garage in first. Not seeing a leak. Gonna give it a few
    Crimson9mm likes this.
  12. roalmc77
    roalmc77 New Member
    Auto zone here has all motorcycle oil 2 bucks off per quart :) saved 6 bucks.
  13. roalmc77
    roalmc77 New Member
    That's where it's leaking
  14. roalmc77
    roalmc77 New Member
    That might just be me putting in a tad to much oil
  15. k-moe
    That looks like a pic of the airbox, and the breather hose.
    Take a pic of the sightglass with the bike on the center stand.
    Crankcase oil volume is 2600 cc + a little for the filter. The oil level should never be above the top line on the sight glass.
    Does the oil smell at all of gasoline?
  16. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Agreed but the leak doesn't look like it's coming from the breather. Pull the filter and see what's in the bottom of the air box.
    Gary H.
  17. Crimson9mm
    Crimson9mm New Member
    Tonawanda ny
    mine appears to have a leak in the same location...just picked it up today and he said he fired it up after winter and it was empty? not totally sure of the guys knowledge... but I attaced a pic of the area he said it was leaking from.
  18. Crimson9mm
    Tonawanda ny
    let me know if this sounds similar and how just changing the oil worked out. would love to not have to bring mine into the shop.
  19. k-moe
    Remove the oil fill plug and have a sniff. Oil can't leak from the breather/ airbox area unless it is overfiled, or the float needlse aren't seating and allow gas to enter the crankcase.
  20. Big swede
    Gothenburg,Sweden
    Maybe someone put a k&n filter in it and misunderstood how to oil it...;)
  21. Crimson9mm
    Tonawanda ny
    would that also lead to loss of oil? it looks damn near empty....and i dont smell any gas...
  22. MN-Maxims
    Saint Paul, MN
    Is it possible that engine has so much blow by it pumping a bunch of oil into the air box and when the bike sits it drains out onto the floor?
    Sounds crazy but how would all that oil get up into the air box?
  23. k-moe
    That would be a lot of blow-by. I suppose that if the breather baffle had been removed at some point, more oil mist would make its way out of the crankcase.
  24. k-moe
    Is the bike on the sidestand? It needs to be on the center stand to check the oil level.
  25. Crimson9mm
    Tonawanda ny
    it sounds exactly like the origional poster said..should i drain it, fill it up and run it a bit and see? mine sat over winter and dont know when it dropped the oil.. PO is a bit of an airhead so who knows. it also smells a bit of gas...
  26. Crimson9mm
    Tonawanda ny
    hoping to hear from the first poster about his bike... if i need to do a full carb rebuild i will have an 82 xj750j for sale...
  27. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    If the problem is leaking petcock and leaking float needles, the petcock will not be dirty. The leak will be internal.
  28. XJ550H
    if your sump is empty why would you think you would smell gas?
    have you looked at the motor oil pan?
    oil filter housing can leak a smear of gasket sealer rtv works well.
    oil drain plug can leak should have a crush washer.
    oil level sensor o ring.
    shifter seal.
    sprocket seal (chain drive)
    tach housing on motor.
    bad valve seals
    many things can cause oil use
    most drips (usage) will happen only when motor is running
    the real question is if you are that low on oil WHY is your OIL LIGHT not ON??
    check bulb check sensor.
  29. Crimson9mm
    Tonawanda ny
    mine I just got, just picked up battery today. hasnt been even attempted at being turned on since it dropped oil 1.5 years ago. also when PO parked it tank was full, now no gas, and sump smells slightly of gas....maybe gas thinned out oil and it leaked after the fact? bought a new petcock with an off option. once that comes ill change the oil and fill her up and see what happens.
  30. Crimson9mm
    Tonawanda ny
    also wondering if the float needles are stuck if i get it running and run some seafoam if they might free up..PO had no problems for the 2 years he rode before parking. and would turning the petcock on and off be enough for me to get it at least around town for now?
  31. DrewUth
    DrewUth Active Member
    South Jersey
    @Crimson9mm start your own thread, stop hyjacking this one. Its difficult enough to help one person with one bike solve their issue, but to have someone else chiming in muddles the entire process. I understand that the issue is similar, but you should start a separate thread on it.
  32. JPaganel
    Minneapolis
    Starting threads is free... :D
  33. DrewUth
    South Jersey
    Apparently one of the only things on this forum that is free.
  34. hogfiddles
    Just about everything on here is free. ALL the info is free------
    Stephen Downey, rocs82650 and k-moe like this.
  35. Crimson9mm
    Tonawanda ny
    sorry. his issue just matched mine exactly and was hoping to hear back from the OP about if just changing the oil and running it cleared it up or not. he hasnt givin an update since the 16th. also...hog, where abouts in CNY are you? i live in buffalo and am from just outside utica.
  36. XJ550H
    info and advice is always free.
    and the choice to take it is also free.
    other than premium membership I do not know of anything this site sells.
  37. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    However, not taking the advice without first putting some serious consideration into it can cost plenty.
    Crimson9mm and DrewUth like this.
  38. hogfiddles
    Crimson.....check your inbox
  39. XJ550H
