Gas tank screw size Seca 750 gas tank
Discussion in 'XJ Technical Chat' started by silverdollar, Jun 1, 2016.
  1. silverdollar
    silverdollar Member
    Chesapeake, VA
    Hello,
    I just purchase a gas cap for my gas tank from Fleabay and it did not come with the screw to attach it to the gas tank. Btw the gas tank is a Seca 750.
    Thank you
  2. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    It's M6.
    silverdollar likes this.
  3. silverdollar
    silverdollar Member
    Chesapeake, VA
    Thanks brother
  4. XJ550H
    M6-1
    3.6 ft lbs torque
    just adding the pitch
  5. silverdollar
    silverdollar Member
    Chesapeake, VA
    M6 it is, thanks!
  6. k-moe
    Use a medium-strength threadlock or never-seize on the threads so you can get it back out later. Also be careful to not drop it into the tank.
  7. silverdollar
    silverdollar Member
    Chesapeake, VA
    I will be careful not to drop the screw in the tank and will use a medium thread-lock like lock-tight
  8. Big swede
    Gothenburg,Sweden
    Yes, that's a regular M6. Is it hard to get metric screws in the US, have seen quite a few threads about it?
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    My local Ace Hardware usually has the metric thread screws/bolts I need. They even had appropriate metric hex head, stainless steel bolts to replace the Philips screws on my YICS covers.
  10. Big swede
    Gothenburg,Sweden
    Not too hard then, was just qurious, if you don't ask you'll never know...
  11. XJ550H
    not hard to get it is that we lable sae differently
    1/4-20-1-1/2 = 1/4 inch diameter 20 threads per inch 1=1/2 inch long.
    metric M6-1 x16 woild be 6 mm dia 1 thread per MM 16 mm long
    metric states threads per mm sae stated threads per inch
    my best source for quality and price is home depot you can order what is not in stock from your computer and have it sent to store or your house.
    our automobiles have metric bolts in them.
  12. Big swede
    Gothenburg,Sweden
    I come across sae screws from time to time on some american equipment as i work as a mechanic, it messes up as we don't normally use sae wrenches. It's not hard to get though.
  13. Polock
    Actually metric is measured from the top of one thread to the next.
    A 1 pitch is 1 mm , a .8 pitch is .8 mm
  14. k-moe
    I was "lucky" enough to start turning wrenches in the era when all U.S. built vehicles had a mix of Metric and SAE fasteners. I swear that requirement was lobbied for by tool manufacturers.
    Stumplifter likes this.
  15. Big swede
    Gothenburg,Sweden
    Volvo did the same in the 60's to mid 70's, wasn't fun at all....
  16. Polock
    11 mm wrench fits a 7/16 hex pretty good. 14 mm sort of fits a 1/2 inch hex.
    my tool box is a mess so all the metric stuff is painted green
  17. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    My teachers told me in grade school that when I grew up that we would be using the metric system . . . . 52 revolutions around the sun and I guess I'm not grown up yet. :confused:
    I digress, the OP presented another classic example as why saving a couple $$ on eBay just doesn't pay in the end.
    XJ4Ever is the prefered source for my motorcycle parts.
  18. Big swede
    Gothenburg,Sweden
    silverdollar and XJ550H like this.
  19. XJ550H
    This is all you need for metric sizes....:rolleyes:
    I find that metric wrenches work well for sae fasteners
    Big swede likes this.
  20. Big swede
    Gothenburg,Sweden
    Yes it is, works almost everytime....:)
  21. silverdollar
    silverdollar Member
    Chesapeake, VA
    For all my metric screw I go to Lowe's home improvement store. They have an array of screws in metric.
