identifying my maxim
Discussion in 'XJ Technical Chat' started by MichaelDD, Jun 9, 2016.
  1. MichaelDD
    MichaelDD Member
    milwaukee, wi
    New to the club here...first bike and I'm trying to identify it. The title says 82' Yamaha. The only thing I know is that it's a maxim, but I have no idea if it's a 550,650,750, how can I tell? Serial and VIN lookup doesn't give me anything (unless someone knows of a good site). 6 gears that much I know (from reading it on the side of the bike)
    Thanks!
    -md
    6 gears and a chain it is a 550
    does your vin start JYA5K500 thats a maxim XJ 550
    best vin
    TECH TOPIC: Model ID and VIN's
    MichaelDD likes this.
  3. MichaelDD
    MichaelDD Member
    milwaukee, wi
    Thanks for the quick reply and information! Yep that's what mine starts with
  4. XJ550H
    do you have a factory service manual? want one?
  5. k-moe
    Another way to tell is to look at the base of the cylinders between the middle two exhaust headers. The engine size is cast into the barrels there.
    Though the 6-speed is a dead giveaway.
  6. MichaelDD
    MichaelDD Member
    milwaukee, wi
    I do have a paper one yes (The guy I bought it from said it was HIS first bike and wasn't sure if the manual was for that bike, but you cleared that up) Things would be easier if I had a PDF of this one that I can search by keyword through :)
  7. MichaelDD
    MichaelDD Member
    milwaukee, wi
    @k-moe thanks, I'll check that out tomorrow!
  8. XJ550H
    check your in box i posted a link to down load it should contain 2 manuals manual 2 has the maxim supplement and a carb rebuild book for mikuni carbs it is suzuki but it is the same carb 98%
    the manuals are seca xj550 with a maxim supplement
  9. XJ550H
  10. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    Welcome to the forum, MichaelDD. As you have already seen, there is a wealth of information here.
