Signals not flashing; horn not working when stopped
Discussion in 'XJ Technical Chat' started by Alain, Jun 1, 2016.
  1. Alain
    Alain Member
    My turn signals don't flash and my horns don't work when I'm stopped at the lights. I'm trying to do my motorcycle exam and last time, he did not 'approve' of this and I'm trying to fix this before going for my exam.
    Now I noticed that it'll flash and the horn will work after 1500 RPM. Do I simply have to change the signal relay - but the horn not working indicates that it might not be isolated to signals only? Perhaps the regulator/rectifier? I talked to my motorcycle shop and they said that the signals should blink.
    The only thing I changed was upgraded the front headlight so I'm wondering if there's too much voltage draw.
    Simiar thread: http://www.xjbikes.com/forums/threads/turn-signal-problems.73794/#post-481705
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    What is the battery voltage at ~2k RPM? Should be about 14.5 volts.
    It's possible that the replacement headlight draws too many amps. There's not many "free" amps on these bikes to begin with. Did the horn and signals work before?
  3. k-moe
    Sounds like a low-voltage situation at idle. You can bump the idle speed up to 1500 RPM to get you through the test. The likely source of the undervolt problem is worn alternator brushes. Pull the alternator cover (big round one directly under the carbs on the left side of the engine. three screws), and look at the brush length. There is a wear indicator n the brushes You should also clean the copper traces on the alternator rotor with a hard pencil eraser.
    It could also be that the new headlight is drawing too much current as Jayrdoh suggested.
  4. XJ550H
    after you fix the voltage problem
    you may want to consider changing your tail lights to led bulbs as well as the plate bulb, always on and will save you some amps.
    what kind of head light did you change to and from?
    I got my plate light bulb from superbright part number 67-W15:Natural White $6.95
    went to wall mart for the tail/brake light
  5. Alain
    Alain Member
    I've cleaned and confirmed brushes are still good on alternator. i've also cleaned the copper traces on the alternator rotor with a hard pencil eraser.
    I upgraded to a 'Candlepower Round Headlight' described as '7LAMP w/h4 quartz bulb'.
    I'm assuming there's no harm in riding around with 1500RPM idle while I'm doing the test. That's a good idea.
  6. waldreps
    waldreps Active Member
    Henning, MN
    Are any modifications required to use LED plate and tail light bulbs? I've read about people having trouble with getting LED's to work and needing to use resistors and such....or is that only with other lights on the bike?
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    LED's are direct swap for brake/tail, plate, and some indicator lights. You can purchase replacement LED bulb assemblies that will install just like an incandescent bulb.
    Resistors are needed in turn signal applications for some bikes (XJ's yes) as the flasher needs the correct amperage "load" to function properly.
    waldreps likes this.
  8. k-moe
    There are other ways to use LED signal lamps than to resort to load resistors (which defeat the point of reducing amperage draw).
    XJ550H likes this.
  9. XJ550H
    I use a H4 bulb it is not a problem
    you can do the test with out riding around
    clean your grounds at battery motor frame and coils
    this link discribes what you will be testing for it is near the bottom of the page
  10. Alain
    Alain Member
    I cleaned the copper connectors on the signal relay and it's a no go. the funny thing is, one of the tests that I do is when I just turn the bike ON, w/o starting the engine (therefore, no headlights, no tach/speedometer lights), neither the horn works (it slightly squeeks) or the lights blink.
    there was once a time where it would work. Perhaps the voltage on the battery is not high enough. I've had my batteries tested by a motorcycle shop and they said it was fine (for starting the motor).
    *** Do you think changing the REGULATOR would help? *** The thing is the REGULATOR changes AC to DC, but when the motorcycle is not started, it's all DC going to the signals and horns. I'm thinking that the initial voltage of the battery needs to be higher.
  11. k-moe
    A shop that does not know how to test a voltage regulator, but advises trying to change it out for a new one, is a shop to be avoided.
    Besides, regulators typically fail in a way that causes the output voltage to be too high.
    Test your alternator coils (I'm assuming the shop didn't)
    Scroll down to the last post: http://xjbikes.com/forums/threads/the-ultimate-relay-switch-sensor-and-diodes-guide.27543/
    There are other tests for the regulator, but I don't have them handy. The main thing to look for is proper outout voltage at the given RPM.
    jayrodoh likes this.
  12. Alain
    Alain Member
    Thank you K-moe on the advice on regular and voltage being too high! Mine is fine. NOw I don't have to look at it. Saved me a lot of $$.
    Now do you think changing my battery would help this? my battery is 12.8V at rest.... but it seems like my lights/horn need 14.4volts or more to start working, i.e. after 2000+ rpm. I've cleaned
  13. DrewUth
    DrewUth Active Member
    South Jersey
    Here's an idea- use some test leads and connect the horn directly to a battery. Does it work? That will save a lot of wondering.
  14. k-moe
    I suspect that you have voltage drop due to corrosion, or a short somewhere, otherwise everything would be working at idle.
  15. XJ550H
    is this your headlight?
    CandlePower 702212 H4 Headlamps
    12Volt - 7in. Round12V quartz halogen lights manufactured by Candlepower come complete with H-4 P43T 60/55W bulbs
    Twice the illumination of standard sealed beam
    DOT compliant
    http://www.ebay.com/itm/702212-CAND...ash=item25ba2fc14a:g:8lYAAOSwJMhXDpQ1&vxp=mtr
    haynes book spec you have a 81 650 max
    candlepower bulb is pulling 1 (14 volt) to 1.25 (12 volt)more amps on your low beam
  16. jayrodoh
    jayrodoh YimYam
    Cleveland
    On my Maxim, the ground for the entire wiring harness is a ring terminal that uses the bolt for the ignition coils to connect to ground. When I first put my bike back together, this connection was not good and nothing worked properly. If you have the same setup, I would pop the tank off and check this.
    XJ550H likes this.
  17. Alain
    Alain Member
    Thanks for tip!.... err... do you have any diagram. Am I just looking to see if a ring terminal is attached to the ignition coils and perhaps clean it up a bit...
  18. jayrodoh
    jayrodoh YimYam
    Cleveland
    No diagram but I do have a grainy picture from tear down that shows it.
    Alain likes this.
  19. Alain
    Alain Member
  20. XJ550H
    disconnect your headlight and see if every thing starts working.
    k-moe and DrewUth like this.
  21. Alain
    Alain Member
    I just did that. when I disconnected the headlight, the lights are blinking after 2000RPM. So it's not the headlight. is it possible that my signal relay has too much resistance? I tested it last night and the lights blink at 14V after 2000RPM.
  22. XJ550H
  23. XJ550H
    open and clean contacts at this point you should be cleaning any connector you remove
    electrical spray and dielectric grease.
    have you cleaned the grounds, at motor and frame from battery as well as the battery connection?
    clean ground at coils, and ground at pickup coils.
    start cleaning the bulb sockets and connectors.
    what voltage are you getting at the battery at idle and when lights come on ?
    check volts at flasher connectors. and horn.
  24. XJ550H
    this is the test for flasher relay. I have a 94 ohm reading on my flasher problem is that it is a coil in parrell with a 150 ohm resistor
    you have to isolate the contacts to get a true reading of the coil the coil is heavey wire so it is doubtful it has failed
    more likely the resistor or cap has failed (timing circuit)
    coil is 246 ohms you have to slide an insulator between the contacts
    resistor is 150 ohms, capacitor is 1200uf electrolitic
    just to be sure the flasher is 2x the size of the other relays
  25. k-moe
    ^ What he said (about deoxidizing the wiring connectors). You likely have plenty of voltage; it's just not all getting to where it's needed. Think of corrosion as being like holes in a garden hose.
  26. XJ550H
    have you ohmed out the alternator? what were your results?
    what are your battery voltages at idle and 2k rpm?
    did you clean all of the grounds as suggested, including ground under cover where pick up ccoils are?
    do you have glass fuses or have you upgraded to blades?
    can you answer in detail please it would help a lot.
  27. Alain
    Alain Member
    I saw this picture on my Haynes manual as well. But wondering, do I turn ON bike, disconnect the started relay, use voltmeter:
    1) connect 1 tester lead to BR, (brown?) cable and the other to ground
    2) connect 1 tester lead to Br/wh, (brown/white?) cable and the other to ground
    3) where is this?
    4) What is Ch and or Dg?
  28. XJ550H
    yes tur on key
    Br is brown
    Br/wh is brown with white stripe
    ground can be battery or frame bare metal, test ground connection back to battery positive looking for 12 volts
    Ch is chocolet
    Dg is dark green
    you should leave flasher connected and check wire at back of connector
  29. Alain
    Alain Member
    Alternator:
    * field coil windings: 5.7ohms
    * stator (3 white wires): 0.8, 0.9, 0.9 ohms
    Battery Voltages:
    OFF: 13.12 (thought just pulled out of charger)
    ON: 11.79 to 12.5 (the voltage is dropping... so I kept measuring until it dropped to the lowest) - also note that motorcycle started instantly so I don't have starter issues
    1,000RPM (idle): signal lights ON, no flashing, horn works @ 13.3v
    1,500 RPM: signal lights ON, flashing, horn works @ 14.36v - 13.96v
    2,000 RPM: signals flashing, horn works @ 14.6v
    I noticed these characteristics:
    13.3v - lights ON, no flash
    13.8v - lights ON, SLOW flashing
    140-14.3 - lights ON, flashing
    I cleaned the grounds with a dremel tool brush on the ground cover as you suggested
    Still on glass fuses.
  30. XJ550H
    what voltage do you have after the glass fuse?
    go buy a fuse holder put clips on the ends and see if your results change, there are better ones than the one pictured.
    clip it across your signal fuse where the wires are crimped to the clips
    Lightcs1776 likes this.
  31. XJ550H
    you measurements are out of spec this could be your problem check them again.
    Alternator:
    Checking Alternator Stators:
    Measure the resistance across each pair (white1 to white2, white1 to white3, and white2 to white3) of the three white wires (white1, white2, and white3) at the connector; the specifications should be:
    0.46 ohms +/- 10% for all XJ650, all XJ700, all XJ750, and XJ900RK models.
    Checking Alternator Rotors:
    Measure the resistance across the two lead wires (usually brown and green) at the connector; the specifications should be:.
    4.0 ohms +/- 10% for all XJ650, all XJ700, all XJ750, XJ900RK, and XJ1100 models.
    Note that worn, dirty, or damaged alternator brushes can affect these readings, as can "dirty" copper commutator rings on the rotor face (where the brushes contact the rotor):
  32. Alain
    Alain Member
    [QUOTE="do you have glass fuses or have you upgraded to blades?[/QUOTE]
    My motorcycle shop said that my fusebox was 'melting' into the plastic and recommended I change it. Should I upgrade to 'blade fuses' and new fusebox?
  33. Alain
    Alain Member
    test
  34. Alain
    Alain Member
    My motorcycle shop said stator is on the way out. Now if both are out of spec, which is the one I should change first? I'm thinking stator (is this the wound copper thing where you can take an eraser and clean it) might be easier to change first no?
    The rotor is a pain in the ass to remove and requires two people.
  35. XJ550H
    I would revisit brushes for length and check the springs, make sure brushes float properly would be easier to replace brushes then re test ohms
    both at same time put in gear and foot on the brake ( tighten the adjuster first). one man operation.
    yes up grade you can go blade and box or inline fuse holders as I pictured. both will cost the same, your choice.
    I would do this first
  36. XJ550H
    do not take tis the wrong way but the info you just shared with us would have been VERY HELPFUL if you stated it in the first post of this thread.
    melting fuse box.
    bad charging system parts....
    you are getting volts but no amps
    recheck brushes. can you borrow another meter to redo the test.
    does your headlight dim way out? battery keep going dead?
    alternator should have affected all lights
    I still would do fuse box first.
    Alain likes this.
  37. Alain
    Alain Member
    Thanks! I went downstairs just now and noticed that my horn is working but the lights do not flash when the motorcycle is in ON position (but engine not started).
  38. Alain
    Alain Member
    This is a pic of my fusebox. don't see any 'melting' but i'll change it.
    Also for Chacel to see when replacing with ATC fusebox.
  39. XJ550H
    that is not a stock fuse holder. but good news is you should be able to just plug in the new box.
    try changing the signal fuse or swap it with headlight fuse see if the problem moves with the fuse.
    or swap the wires for head light to signal fuse see if the problem moves with the wires
    or plug a 10 amp blade fuse into the quick disconnects of your signal wires
  40. cgutz
    cgutz Well-Known Member
    SE South Dakota
    If you've checked everything else above, I had problems with turn signals not flashing at idle. They did flash when rpms were above idle. Problem was two fold:
    1) weak battery
    2) 23w instead of 27w bulbs in the turn signal (this fixed the problem for good)
    Alain likes this.
  41. Alain
    Alain Member
    Hmm... I know for sure I changed my left (shifter side) bulbs to to GE Nighthawks 1156NH. IF I have issues, would one side being on 27W tell me enough? I mean, the left side doesn't affect the right side right?
    I've had one instances where a defective lightbulb can cause one side to stop flashing. One side was only ON, and the other side was flashing. So I found it was one defective lightbulb.
    Link: https://www.amazon.ca/GE-1156NH-Nighthawk-Automotive-Replacement/dp/B001FJNP5W
  42. Rooster53
    North, FL
    If you measured at the connector, that is better than most indicating brushes and field coil are likely OK
    Touch your meter leads together, subtract that number from the above reading to get closer to the true resistance of the stator.
    Your charging system is working perfectly.
    Definitely need the 27 watt bulbs to work as designed as cgutz suggested.
    Those spade terminals on the fuse box don't look very good, do you feel any excessive heat from them? I can't tell but the one with the red insulation sleeving (signal fuse) doesn't even appear to be crimped. They all appear corroded, and I would never trust that simple smash crimp on an outdoor vehicle. They often loosen up, and giving them a slight tug you can feel the wire move within the terminal.
  43. Polock
    are there voltages you're taking at the battery or at the turn signal socket and horn?
  44. Alain
    Alain Member
    I now know my stock relay fu257cd is bad. I happened upon a relay novita LL552 and my signals blink right away with just the motorcycle ON. But the aftermarket relay doesn't hand the grommet to mount to frame and disables auto cancel.
    What is the aftermarket alternative that has this grommet?
    Also can you list the led equivalent too? Might be cheaper to buy led flasher and change to LED bulbs than to buy oem flasher relay.
    The novita site said that I can use a LED really but it just won't blink fasthe if one bulb is out.
  45. k-moe
    Have you opened your stock relay? The two things that can kill one are corrosion on the points (clean them), and a bad capacitor (replace it).
  46. Alain
    Alain Member
    Oh shit, you can fix that thing!??!?! ! I saw that I might be able to open it but didnt' dare. I'll try that tonight
  47. Alain
    Alain Member
    I noticed that the OEM flasher relay points are labeled (B,C,L). I saw an aftermarket LED compatible relay, Novita EP34, that's labeled (B,E,L) and it didn't flash at all.
    I do know that the Novita EP34 is a LED one, but I read that it's supposed to work - just doesn't blink fast when a bulb is out.
    Is the C and E interchangeable? Where
    B, X - Battery input
    C - ?
    E - gRound
    L - Load
    I managed to get it work using a Novita LL552 (X,L) where the X is battery input. Whe
    EP34 link: http://www.novitatech.com/?q=aftermarket/products/electronic-flashers/ep34
    Flasher reference guide: http://novitatech.com/?q=aftermarket/products/flasher-quick-reference
    Novita LL552: http://novitatech.com/?q=aftermarket/products/electro-mechanical-flashers/ll552
  48. Alain
    Alain Member
  49. XJ550H
    flasher connects to fuse, canceler unit, and turn switch (bulbs)
  50. Alain
    Alain Member
    If anyone is interested, two Novita flasher relays can work but they only have two terminal. Note that you will lose auto cancel.
    Incandescent bulb: Novita LL552
    LED bulb: Novita EP37 (LED will work with incandescent but you will not get the fast flash to indicate a burnt bulb)
