Wanted wideband
Discussion in 'For Sale, Trade/Swap, Wanted' started by darren ditmar, Jun 12, 2016.
  1. darren ditmar
    darren ditmar Member
    eugene oregon
    im looking for a cheap wideband so i can tune my bikes carbs anyone have one laying around?
  2. k-moe
    Gunson Colortune. Cheap, effective, and won't require welding in bungs.
  3. darren ditmar
    eugene oregon
    i cant find any in the usa do you know if they have any here or is it mail order only?
  4. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    Len (Chacal) has both the Gunson Colortune and the Morgan Carbtune. Start a conversation with him if you're interested.
  5. chacal
    In stock!
    HCP95B Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 12mm plugs. NOTE: NGK plugs that begin with the letter "D" are 12mm, and are used on all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ700-X, XJ750-X, and XJ900 S/SH models.
  6. darren ditmar
    eugene oregon
    im needing a 10mm
  7. Lightcs1776
    Upstate NY
    I'm sure Len will reply, but here is the 10mm from his catalog:
    HCP95A Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 10mm spark plugs. NOTE: NGK plugs that begin with the letter "C" are 10mm, and are used on all 1992-98 XJ600 Seca II models.
  8. darren ditmar
    eugene oregon
    ya its for another bike but i figured i would ask yo guys. the bike calls for a NGK CR9E
  9. darren ditmar
    eugene oregon
    so i was reading the thing on there about the color tune and it says that its only for idle? a wideband does idle and running though right?
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    Colortune is used for pilot mixture. You can't analyze your bike off idle unless its under load, so the colortune is not applicable off idle unless you could somehow watch it while driving. Regardless you can only run it a few minutes anyway.
    Wideband will give you the AF ratio at any throttle but unless you can log it along with other data such as throttle position/slide position and RPM its's going to be useless. Plug chops are the way to go. Its a little time consuming and you need a stretch of long preferably private road but it can be fun.
  11. darren ditmar
    eugene oregon
    ok ya becuase im stroking my motor out and it willget another 60ccs so im guessing thats going to mess with the fuel air mix
  12. hogfiddles
    Uh....yeah---- you're gonna mess with everything. It's almost like putting on pods......only worse
  13. XJ550H
  14. darren ditmar
    eugene oregon
    so i looked it up so you can make them using apoxy? is that correct?
    and yes i would guess its as bad as messing with pods but im also changing the velocity stacks by making them shorter so im really going to be in for a fun time
  15. k-moe
    Just do one thing at a time, and take copious notes.
    A Colortune will tell if you are close off-idle without load so you don't have to spend as much time with plug chops.
  16. XJ550H
    yes but do not use 5 minute epoxy . the longer cure the stronger.
    I used a plastic screw cap on the end to retain the pour.
    i would recomend a face shield when viewing the plug.
    darren ditmar likes this.
  17. darren ditmar
    eugene oregon
    i was hoping not to have to buy a lot of jets over and over again to get it to run right so i thought i would just do it all at once
  18. k-moe
    [QUOTE="XJ550H, post: 521715, member: 16564"
    i would recomend a face shield when viewing the plug.[/QUOTE]
    +1 Polycarbonate, and thick.
  19. darren ditmar
    eugene oregon
    what about my helmet i have a rf1200 you think that would work?
  20. jayrodoh
    jayrodoh YimYam
    Cleveland
    If you do buy the colortune, make sure you buy new through a reputable seller like chacal or keep an eye on what you are bidding on. There are two models, the older one has some flaws that are corrected with the newer one. I thought I got a heck of a deal on mine until I had issues with the spark jumping outside and found out there was an older one. I was able to fix but it reduced the area of the window I can view. Doh!
