Fuel milage
Discussion in 'XJ Technical Chat' started by Craig B, Jun 16, 2016.
  1. Craig B
    Craig B Active Member
    Ontario, Canada
    I am sure this answer lies somewhere within this forum but I cannot find it. I am currently getting approximately 265 km to a tank of fuel. That is from Full to the top of my Reserve. Does that sound right? Seems to me I should be getting more. Thanks
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    That (if my conversion is correct) is about 160 miles to the tank.
    That sounds good to me, but different XJ's have different size tanks.
    Which bike are you asking about?
  3. waldreps
    waldreps Active Member
    Henning, MN
    I'm still tuning my carbs that I just rebuilt so hopefully mileage will improve but I get about 85 or 90 miles and then I have to switch to reserve. I've never run it empty so I have no idea how many miles I get on an entire tank. This is on my 82 XJ650 Maxim. Welcome to the forum Craig B...put your bike info in your signature, that'll save you some questions.
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    On my XJ550 Maxim I too switch to reserve about 85-90 miles depending on city/highway mix of driving. Calculate your actual gas mileage. Mine is between 38-44 mpg depending on driving conditions. I've had the bike since new, and this was about the same mpg as in its youth.
  5. XJ550H
    his avatar shows dual disc rectanguar head light my guess is it is a 750
  6. XJ550H
    on my 550 I switch at 125 miles 50 mpg every time i fill the tank but my not to much city driving around here
    typical ride is at 60 mph
  7. Craig B
    Ontario, Canada
    You hit it right on the head.. Updated my signature line. My bike is an 1982 750.
  8. Craig B
    Ontario, Canada
    Thanks for all the replies. Seems like my milage is OK after all.
  9. cgutz
    SE South Dakota
    Probably 90% of my driving is less than 30 mph, town driving.
    About once a tankful I take it out on the road and crank it up for about 10-15 miles, but other than that, no road trips.
    Now that my bike is back "in shape," I may try a long distance trip sometime to see what a whole tankful would get at highway speeds.
    FYI - Our speed limit is 65mph on back roads and 80mph on the freeway.
  10. waldreps
    Henning, MN
    I have an app that I use called Fillup that helps me track my mileage in all my vehicles. I use it every time I fill up. I have a mix of city/highway driving and get anywhere between 30-38 mpg right now. Of course, with my rebuilt carbs, I seem to like to let it rev to 9000 rpms now. :D Once I get used to the new found power and get it dialed in right, I'm sure my mileage will improve.
  11. Craig B
    Ontario, Canada
    [QUOTE="Of course, with my rebuilt carbs, I seem to like to let it rev to 9000 rpms now. :D Once I get used to the new found power and get it dialed in right, I'm sure my mileage will improve.[/QUOTE]
    Holy crap. 9000 RPM? If I go past 5000 RPM I think I am pushing it too hard, lol.
  12. XJ550H
    and there is still more left to use........................5000 rpm is where the fun starts
  13. waldreps
    Henning, MN
    Yep, before my carb rebuild, it didn't want to pull very good at all above 6000 rpm but now it screams up there.
  14. TheCrazyGnat
    Central PA
    I have found the exact opposite to be true. When I, like Craig B, didn't feel comfortable taking it past 5k, I was getting north of 45 mpg , once I started to get comfortable with what the bike could do, it dropped off pretty quickly!
  15. waldreps
    Henning, MN
    What I meant was when the new found power isn't so new and feels more normal, I'll probably go back to riding like I used to and not going above 6000 rpm very much. Then my mileage should improve. At least, that's what I keep telling myself.
  16. TheCrazyGnat
    Central PA
    Ha ha, I was (sort of) joking. I guess I just never got back to that point enough that my mpgs recovered.
  17. waldreps
    Henning, MN
    That may happen to me as well...lol.
  18. k-moe
    For comparison purposes I hit reserve on my Seca 750 at around 120-130 miles (depending on the wind mainly), and run out entirely after another 20-30 miles.
    WInd. Wind is the key. Ride with/like the wind......
    Stumplifter likes this.
  19. k-moe
    Ya. Motorcycles will do that. Even the fanciest of sportsbikes have a coefficient of drag that is not dissimilar to that of an upright sheet of plywood.
    TheCrazyGnat likes this.
  20. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  21. k-moe
    Good link. Note that they were testing bikes where riders hug the bodywork. Motorcycles with a more-standard riding position (an no fairing) have horrible coefficients of drag (see the lnked table here).
    I would also direct the curious to http://craigvetter.com
    His work (and the work of those following him) has proven the degree to which aerodynamics can increase fuel efficiency of motorcycles.
    Fun fact (unrelated to Vetter's work): With the correct body, a 23HP (measured at the crank) 2-stroke engine can propel a person to over 150 MPH.
    Compromises....it's always about compromises.
  22. MattiThundrrr
    I like the part about "styling aerodynamics" where it looks aerodynamic, although it isn't. Crazy. Why not just make it actually aerodynamic?
    Also, in the table, it shows that a supersonic fighter has a higher drag coefficient than a subsonic transport aircraft. Am I reading that wrong? It seems counter intuitive!
  23. dkavanagh
    Rochester, NY
    Is spark advance a thing? Does the TCI just take care of this?
  24. k-moe
    All of aerodynamics is counterintuitive.
    One of the main reasons for not making everything as aerodynamic as possible is that everything would end up looking almost exactly the same.
  25. k-moe
    Yes, the TCI manages spark advance.
    dkavanagh likes this.
