Blinkers
Discussion in 'XJ Technical Chat' started by Faster, Jun 20, 2016.
  1. Faster
    Faster Member
    Pasco wa
    Well im working on wiring. My blinkers come on left side no blink right side has no power would it be blinker relay ? And douse bike have to be running for them to work Blink. left side has no power though
  2. k-moe
    It could be the relay, or it could be the bulbs are burnt out (it could be other things too, like unplugged or broken wires, or a bad turn signal switch).
    The relay is under the fuel tank (remove tank for access). The cover pops off so the relay points can be cleaned.
    Jetfixer likes this.
  3. Faster
    Faster Member
    Pasco wa
    Thanks again I realy appreciate all the help going out to garage
  4. Jetfixer
    ^^+1 k moe is the man:D agree with him 101%
    jmilliken and Faster like this.
  5. Faster
    Faster Member
    Pasco wa
    Well took relay apart cleaned pionts. Took blinker switch apart and cleaned everything in it with light sand paper all screws out took everything aprt lightly sanded. Still no power to left blinkers right side has power. But when I turn switch to right nothing no power to back or front blinker wires
  6. k-moe
    When you had the switch apart did you look for bad solder joints, or loose wires there?
    The turn signals all plug into the main harness just a few inches after the pigtails reach the frame. Have a look and see if they are plugged in. If they are then unplug them and clean the contacts.
    Jetfixer and Faster like this.
  7. Faster
    Faster Member
    Pasco wa
    Yep broken solder fixing tomorrow. Yaaaaay one more step done
