Used / Spare XJ650 Motor Worth Getting for $300?
Discussion in 'XJ Technical Chat' started by 3BadBirds, Jun 21, 2016.
  1. 3BadBirds
    3BadBirds Member
    North East USA
    I recently came across someone selling a xj650j motor locally. The motor looked pretty complete but upon closer inspection it appeared as if there was some oil in the carbs. The owner thinks there was about 30k on the clock before the rest of the bike met its demise so I'm assuming this blow-by is wear related (piston ring, valve, etc.).
    I'm sure I could talk the owner down a bit but do you think its best to pass on this motor based on the problems I have already noticed? I thought it would be nice to keep a spare handy but my current ride is fine and I really don't need any extra clutter.
    Thx
  2. tcoop
    tcoop Active Member
    South Weber, Utah
    Unless you need parts from it or your engine is about to die, I would pass. If you keep your engine in good condition and maintained you will most likely never need to replace it.
    rocs82650 likes this.
  3. Jetfixer
    I say go for it if you can get it for 250$ Having a spare engine is good as you could rebuild it slowly and have it ready to swap at some point.
  4. k-moe
    Don't assume that oil in the carbs is from blowby. A smart person fogs everything with oil to prevent corrosion.
    Do a compression test. If it's low, then pass, or lowball him to $50. Rebuilds aren't cheap to do. Most of the oversize ring and piston sizes are NLA except to have them made. There are ways around that problem, but why go there unless you have to.
    Jetfixer and jmilliken like this.
  5. XJ550H
    it has the carbs on it those can be sold for 150$ so it is a good deal.
    shipping on used motors is costly, bird in hand.
    you can polish all the covers and swap them onto you motor
    even have the heads redone for future use, does it have the starter too?
    ohm out the pickups if in spec another useable part
    check to see if he has and will include the TCI
    it is a silver mine in spare parts
    check ebay and cl as well as our swap trade for prices
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Buy it!
    Jetfixer likes this.
  7. Saltydog
    Saltydog Member
    Eastern NC
    you can never have too many bikes or spare parts...but you need to buy them at a good price...if the carbs look good I would offer $100.
  8. jmilliken
    Dillsburg, PA
    So, the question we all want to know is...
    "Did you buy it?"
