Wanted: pic of side stand
Discussion in 'Hangout Lounge' started by saftie, Jun 28, 2016.
  1. saftie
    New York, NY
    Hi,
    Could anyone post a pic of the side/kick stand of their 81 xj550?
    I assume other bikes will be the same.
    I am trying to figure out the spring and apparently there is another part involved but I don't recall the setup.
    The spring, the one I believe is my stand spring, alone appears to be too short.
    there are 2 springs and a plate
    one spring goes inside the other
    saftie likes this.
  3. saftie
    New York, NY
    Yes, that's what I see in exploded views but I don't remember taking it apart like that.
    actually, took me a bit but i found an image. close up would be great though
  4. saftie
    New York, NY
    and thanks for the two spring setup tip. now i finally know where the second spring is from :)
  5. XJ550H
    spare parts after reassembly can be annoying
    ecologito likes this.
  6. saftie
    New York, NY
    I used to think that I am out-smarting the engineers when I managed to build something with less parts. Now I like my life and want to hold on to it for a bit longer.
  7. XJ550H
    I have no idea why it has 2 springs, but I am sure there is a valid reason.
  8. saftie
    New York, NY
    Maybe when they designed it, the engineer was in the same situation. Forgot to put one spring somewhere else on the bike and didn't want to leave any spare parts. Lol
    XJ550H likes this.
  9. k-moe
    The second spring is there in case the main spring breaks (really).
    You wouldn't want to suddenly find that your stand is deploying mid-corner.
    XJ550H likes this.
  10. hogfiddles
    If one breaks, you'll be glad there's still another one
    k-moe and XJ550H like this.
  11. XJ550H
    nothing like redundancy to save your butt
  12. saftie
    New York, NY
    Installed it just now.
    Thanks again
  13. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    That little plate is what activates the safety switch, mucho important. My Maxim had been "modified" by a PO. Took off 3 times with side stand down. Chacal fixed me up with the plate and the proper spring before I killed myself.
  14. saftie
    New York, NY
    I love this forum
