Vibrations
Discussion in 'XJ Technical Chat' started by Scorpion1016, Jul 11, 2016.
  1. Scorpion1016
    Scorpion1016 Member
    Hi everyone my xj750 has a harsh vibration above 5000 RPM I have adjusted the valves and the carburetors are synced and cleaned I think the issue is in the drive shaft any ideas are appreciated
  2. DrewUth
    DrewUth Active Member
    South Jersey
    Vibration when stationary, while riding, or both?
  3. Jetfixer
    Have you ever rode a Harley? they VIBRATE all the time... My 750 Seca has a vibration around 5000 rpm I just go faster . personally I would not be worried unless you can't hold onto the handle bars or your berries feel numb .
    Nuch and DrewUth like this.
  4. mc1oo1
    mc1oo1 Member
    LB,Ca
    Harleys are named paint shakers for a reason.
    Jetfixer likes this.
  5. Scorpion1016
    Scorpion1016 Member
    It happens while riding. It is enough to vibrate the mirrors. Just wanted to make sure it wasn't a serious problem
  6. TheCrazyGnat
    Central PA
    That is completely normal. If you take it up to around 6k does it go away?
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
  8. k-moe
    The mirrors should not be blurry.
  9. mc1oo1
    mc1oo1 Member
    LB,Ca
    He should just clean the mirros
    *DRUMROLL*
  10. DrewUth
    South Jersey
    We need more info. But, in the absence of that...are all your motor mount bolts present and tight? Wheels/tires balanced- check for cupping on the tire tread? Pull the rubber boot back at the swingarm/driveshaft/engine/frame junction- does the u-joint look ok? Any play in it?
  11. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    LOL
  12. OldFleetGuy
    OldFleetGuy Member
    Eastern North Carolina
    My 650Maxim has the "buzz" too - most pronounced at 5K - 5.5K. This may help reduce your handlebar vibration and is cheap. I assume your handlebar is hollow and has no internal wiring. Go to your local home improvement store and get a couple of regular 'caulk size" tubes of silicone ( and a dispenser if you don't have one). Remove the bar grips, and pump the handlebar completely full of the stuff. Wipe off the extra. The next day, the ends will be dry but what's inside will remain viscous for a long time. It acts like a dampener. Hope this helps.
    DrewUth and k-moe like this.
