Adding running lights to your turn signals
Discussion in 'XJ Technical Chat' started by Greenhorn, Jul 16, 2016.
  1. Greenhorn
    Greenhorn Member
    Riverveiw Florida
    I recently was wondering how I could use my front turn signals as running lights for more visabuilty out on the road day and night on my 82' 1100 maxim . After looking at the stuff on u-tube and looking at my manual I decided to tear Into It to my supprize It wasn't that hard after all . The previous owner had the wire from the signal, black with a white stripe (correct me if I'm wrong ) Unhooked and taped up the only thing was the male ends were gone grrrrr. , anyway you run the black and white striped wire to the double female plug that has a blue wire on It and viola ! You now have running lights and turn signals . It was the same thing for the left side also . The most time consuming thing was soldering new male plugs on and taking out the butt connectors the previous owner had installed and hard wiring them and of course taking off the after market fairing and dual head light that's on this thing . I hope this thread helps someone else out there !
  2. Jetfixer
    Yes I did this to mine as the replament turn signals had 3 wires dual filiment buld...stock as in original turn signals have only 2 wires singal filiment bulb.
  3. k-moe
    Your 1100 would have had running lights to begin with; the OP mucked that up. The other machines need different signal lights as Jetfixer mentioned.
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1 for the 1100's. Chacal sells a three wire set up that will work with the existing signals on the '82 650 (the blue wire connector is in the bucket but not connected to anything).
    Gary H.
  5. Greenhorn
    Greenhorn Member
    Riverveiw Florida
    I also found a red wire that has power all the time(with switch on or off) Anybody got a clue what that is for ? I just taped it up to avoid a short in the future .
  6. rocs82650
    Middle Tennessee
    Idk about the 1100 but my 650 also has that wire which I believe is power to a possible optional factory component (the schematics show it not connected to anything). I've never checked to see if it is hot with the switch off. I probably need to do that tho.
    Gary H.
  7. Yardawg
    Yardawg Active Member
    Hatch NM
    Where is the "switch" located?
  8. Yardawg
    Hatch NM
    Oops my bad. I assume now you mean the key switch?
  9. Greenhorn
    Greenhorn Member
    Riverveiw Florida
    By switch I meant the ignition switch , Its got power on or off .
  10. Greenhorn
    Greenhorn Member
    Riverveiw Florida
    I guess you could run a power option like a cigarette lighter to it so you could use it when the option is engaged ?
  11. k-moe
    I think that red wire is for a clock.
  12. rocs82650
    Middle Tennessee
    I tested the red wire on my 650 a few minutes ago. It's what Greenhorn said.
    Gary H.
  13. Greenhorn
    Greenhorn Member
    Riverveiw Florida
    Thanks for info !!!
