Insane XJ550 Carbs-- Chacal got BLING!!
Discussion in 'Hangout Lounge' started by hogfiddles, Jul 19, 2016.
  1. hogfiddles
    For your viewing pleasure--Len (xj4ever) has everything you need to restore your carbs. Here's a taste for you.
    But first, the "Before" pics:
    SO---the moment you've been waiting for--- the OMG moment:
  2. hogfiddles
    The BLING
    So, as I said earlier---ALL the new stuff is from Len. This includes not only some inner parts, but also everything you see:
    -Replated rails
    -New bolts, screws and attaching hardware
    -Replated brackets
    -Replated enricher hardware
    -New bowl screws
    -New fuel T
    -New sync screws and springs
    -New Carb diaphragm
    Etc.... and it's all the correct plating and color, too. About the only thing that could make it better yet would be to media-blast the carb bodies........ Which will get done on another upcoming rack---- TBD.
    The owner of this rack will be notified of this forum shortly..... He hasn't seen it yet :)
    If you want these parts for your rack, Len is the guy to talk with!
    Thank you Len!!
    Dave Fox
  3. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Very very nice!!!
    So the throttle cable holder and the choke cable holder... They come from chacal?
  4. Xjrider92117
    San Jose Ca
    Also just curious do the carbs have a the heat shield? Or whatever you wanna call it on the bottom?
  5. hogfiddles
    I'm working on loading more pics but my phone isn't cooperating--
    ALL the new parts are from Len. When I get the pics finally to load, I'll describe everything there.
    The heat shield---
    1. Is not there
    2. Did not come to me with the rack
    3. Is not necessary/useful
    4. Does nothing but cause trouble because once you install it:
    -you can't do your wet float setting
    -you nullify any thread lock you out on if you remove it
    -you alter the carb alignment and sync settings as soon as you remove it.
    Why? Because all the screws that hold it on are the same screws that hold the bottom rail and idle speed screw in place.
    Dave
  6. Xjrider92117
    San Jose Ca
    So do you do you toss them when you get them if they come?
  7. hogfiddles
    Nope... If one is on a rack, I talk with the owner. Invariably, it gets sent back along with the rack, but separate. It's theirs. If I get parts racks or racks to rebuild, they stay on the rack til breakdown, then stay separate but with the rack. Misc parts racks are separated out, and I do have a few extra heat shields in case some one needs one.
  8. hogfiddles
    more pics added above--- check them out!!!
  9. Richard Balboni
    Richard Balboni Member
    Malott WA
    Oh my....... I almost feel bad putting those on my bike without sanding and powdercoating everything first... Those are truly stunning. Len, Dave, I can't express how excited this makes me! I'll be in touch with both of you soon!
    Xjrider92117 likes this.
  10. hogfiddles
    Yeah.... You'll need to do your whole bike now--- otherwise your carbs alone will make the rest of the bike look rough!! Lol
  11. jayrodoh
    jayrodoh YimYam
    Cleveland
    Wow, they look great!
  12. Toomanybikes
    Tsawwassen bc
    They are pretty nice
    You could go nuts and do them in 24K
  13. TheCrazyGnat
    Central PA
    Do you do the replating yourself, hogfiddles?
  14. hogfiddles
    No, it is all from Len At xj4ever. Reread my first post, and my second post where I described everything…
  15. TheCrazyGnat
    Central PA
    Sorry, me reading comprehension skills is no goods.
  16. hogfiddles
    Maybe all the Bling from Len blinded you
  17. TheCrazyGnat
    Central PA
    And here I thought it was science all along...
  18. hogfiddles
    But I don't think HE blinded you........
  19. hogfiddles
    AH! Finally got the bottom of the rack's pic to load. Go check it out!
    Dave
  20. Toomanybikes
    Tsawwassen bc
    Dave just a question . Is the throttle cable holder bent or is it just me ?
  21. hogfiddles
    Nope, not bent. camera lens distortion?I think you're probably looking at the pic from the airbox side.... If you look carefully, you'll see the diagonal is actually a reflection.
  22. Toomanybikes
    Tsawwassen bc
    Looking at pic 2 looking straight down at it .almost looks like it has been pushed down
  23. hogfiddles
    Not so far as I can tell, but I'll look at it before it goes out, and adjust if needed. i still think it is coloration and reflection/light deflection
