New rider
Discussion in 'Hangout Lounge' started by dc383, Sep 16, 2007.
  1. dc383
    dc383 New Member
    Davis, CA
    Just bought a 82 xj550 seca. good bike, the only problem is an oil leak right at the oil filter pod thing. i got a new oil filter an gasket and hope to fix that.
    took her out for a jaunt around town. my first time on a motorcycle turned started with a lap around the block and then i was gone for an hour.
    anyoen know what that oil leak might be all about? thanks - greg
  2. oby_2
    oby_2 Member
    Sydney, Australia
    I'll be the first to say welcome, and add the usual proviso - the more information the better. I will guess when you say Oil Filter Pod Thing you are referring to the oil filter at the front of the bike?
    I'd say your first move is the right one - replace the oil, the filter and fit your new gasket. You should be able to check the integrity of the cover at that time. I have an XJ900 with a 4 to 1 exhaust, so I have to remove my exhaust system to do so, but it's a simple job.
    When you have a spare $10 I'd recommend you then fork out for the XJ-CD that floats around here. Packed with great info.
    Enjoy and congrats....
  3. dc383
    dc383 New Member
    Davis, CA
    you are exactly right, only i have the 4-2 stocker so there is space for me to get to it. ill let you know how it goes.
    XJ-CD? im guessing that is a program on a cd.... i am a genious!!!!
  4. kickstand
    kickstand Member
    North Western Pa
    There are 2 gaskets when you remove the filter houseing the big one and theres a small one on the filter bolt change both!! Clean and check the houseing for crakes or bamage sence it is derectly behing the front wheel road dabree can kick up and damage it. I had the happen before.
  5. dc383
    dc383 New Member
    Davis, CA
    roger that.... thanks for the info
  6. Robert
    Welcome DC (again, see other posts), be advised that the Fram oil filter kit comes with the required new o-rings (2), available at most automotive supply stores (Kragens can order them, about a day or so to deliver at $6 a pop). Back when I was in Davis (1984), they could have called the place Sleepy Hollow, has it changed much?
