Short, clear, attractive windshield options Seca 750
Discussion in 'XJ Technical Chat' started by stv1991, Jul 20, 2016.
  1. stv1991
    stv1991 Member
    What, if any, options do I have for putting some sort of aftermarket short, clear windshield on my 1981 Seca 750? This is not for the factory fairing but an aftermarket windshield kit. Preferably something that would look good over the rectangular headlight.
    Thank you guys in advance...
  2. k-moe
    There are several options, all require removing the foam covers from the bars, or cutting them to fit the windscreen brackets to the bars, or replacing the bars with soemthing more comfortable.
    I have a Slip Streamer Spitfire with a shop-made extension (the only way I could eliminate helmet buffeting when riding into a headwind; pics in my gallery). There are several other aftermarket options. Hit Amazon or Ebay and search for motorcycle windscreen so you can window shop.
  3. luvmy40
    luvmy40 Member
    Y-Town, OH
    I ran a Hell Fire from Slip Streamer on my Seca. I had changed out the stock bars for drags with 3" risers. My son went back to the stock bars sans covers and the Spit Fire screen when I gave him the Seca. I now have a Spit Fire on my Maxim with the square bar adapters. I'd be willing to bet you could use the square bar adapters on the Seca and keep the bar covers. Both the Seca and the Maxim have the same mirrors.
  4. k-moe
    The bar covers are urathane foam. Square adapters will just crush the foam and make the windscreen flop around.
    Oh nevemind, you're talking about the adapters the fit under the mirror stalks.
  5. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Slip Streamer website has a lot of options, and a great spreadsheet showing compatibility with vintage Yamaha and other brand bikes.
    I've had a windshield similar to the original Slip Streamer (http://slipstreamer.com/motorcycle/slipstreamer-the-original/) that I bought with the Maxim new in 1985. I take it off in really hot weather, and use it in spring/fall and for extended road trips. Mine is some generic brand with no markings. It attaches like the one I referenced except the lower brackets attach to the headlight side bolts rather than fork tubes.
    I like it because it keeps bugs off, makes highway driving more comfortable, is very stable at high speeds (it feels more stable with it on than without it), and keep my helmet from buffeting.
    The cons are that you get hotter on a hot day, especially driving around town. I also notice more "engine" smell on my clothes as the wind tends to go below the windshield, over the motor and up to the body, also making it hotter.
    It only takes about 5 minutes to remove or put on, as I keep the lower brackets attached to the bike all the time.
  6. k-moe
    Ahhh.... hotter on a hot day can be solved (it helps reduce buffeting too).
    Snap Vents
    I have one on my windscreen, dead center about 3" up from the bottom of the screen.
    Easy to find on Ebay or Amazon.
  7. Polock
    Furman likes this.
  8. stv1991
    stv1991 Member
    Any options as far as not damaging the foam handlebar pads?
  9. k-moe
    The adapters from Slip Streamer for square bars mount between the mirror stems and the switchgear, so the bars are not part of the equation. Another option is to swap bars for something more comfortable. The stock bars are a bit narrow for American shoulder widths.
    As mentioned there are windscreens that mount to the headlight ears, or to the forks, instead of the bars. I can't give a name of specific windscreen that does that though.
  10. a100man
    a100man Well-Known Member
    Bedford, UK
  11. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
  12. ElkHavenSeca
    Sedro woolley wa
    my wind screen
  13. k-moe
    Yes, the hard to find factory fairing. Perfect fit.
  14. ElkHavenSeca
    Sedro woolley wa
    Did anyone see my post and pic of a good fairing option?
    IMG_7872.JPG IMG_7872.JPG IMG_7872.JPG IMG_7872.JPG IMG_7872.JPG IMG_7872.JPG
    Andrew Nichols likes this.
  15. ElkHavenSeca
    Sedro woolley wa
    I have a few of these fairings . The wind screen part is a little more difficult to find
  16. k-moe
    Just that last one had pics, lots of the same one.
  17. ElkHavenSeca
    Sedro woolley wa
    I have 7 of these fairings in a range of need total resto to perfect and a brand new plastic screen . my wife who has 6 saddles says im a hoarder of fairings
  18. stv1991
    stv1991 Member
    Wanna sell one with the windshield?
  19. ElkHavenSeca
    Sedro woolley wa
    I might sell one of the fairings without the shield . I think the parts guy here sells the wind screen part of it. Its not a factory one but its pretty close
  20. stv1991
    stv1991 Member
    Any 1981 red ones?
  21. ElkHavenSeca
    Sedro woolley wa
    I have a red one but its a little sun faded and has a small crack
  22. k-moe
    The fairing mounts to all years of 750 Seca, and did not come out until '82 anyway.
  23. ElkHavenSeca
    Sedro woolley wa
    I bought my 1981 XJ750RH Seca brand new in Black and it had the sport fairing on it when i got it
  24. k-moe
    Good to know. I've never seen an '81 with the sport fairing.
  25. ElkHavenSeca
    Sedro woolley wa
    Look in my garage
  26. stv1991
    stv1991 Member
    I bought the square bar adapters, they fit perfectly in my mirror mounts. Now I'll see if I can mount a windshield
  27. ElkHavenSeca
    Sedro woolley wa
    Stumplifter and TheCrazyGnat like this.
