HSC32 82 xj750 carb body questions
Discussion in 'XJ Technical Chat' started by VTGanja420, Jul 25, 2016.
  1. VTGanja420
    VTGanja420 Member
    VT
    so after melting the float pin tower trying to repair it, it left me with 2 options ( 3 but thats a new bike and i wanna avoid it now that i gotthe problem honed in) wither manufacture a new piece and pin it, or replace the body, but! this is where im confused. ive seen a few diagrams that look like the individual carbs come apart? is this possible/true? or do i gotta look for the whole quad bar?
  2. VTGanja420
    VTGanja420 Member
    VT
    XJ650 Maxim, Midnight Maxim, XJ650RJ Seca (non-turbo), XJ650 Euro all use HSC32 carbs (various versions)
    XJ750 all USA 1981-83 models use HSC32 version 5G200 (Seca) and 15R00 (Maxim and Midnight Maxim)
    XJ750 all Canadian 1981-83 models use HSC32 version 5H200 (Seca) and 15T00 (Maxim and Midnight Maxim)
    XJ750 UK/Europe 11M models, XJ750 Police models 24L and 37H use HSC32 version 5N100
    XJ750 all USA 1981-83 models use HSC32 version 5G200 (Seca) - i believe this is the model ( i dont know how to tell them apart tbh, if anyone knows how ill be alot more specific :) )
  3. k-moe
    The carbs are held together by mounting brackets. They come apart from the rack for servicing. You'll only need to replace the one, but make not of which one it is. #1 and #4 are unique, #2 and #3 are interchangeable with each other.
    You can use carb bodies (HSC32) from any '81-'83 XJ650 or XJ750, though the 650 bodies will need the jets and needle from your carb.
    Jetfixer and VTGanja420 like this.
  4. k-moe
    post up pics of the damage. It may still be reparable.
  5. VTGanja420
    VTGanja420 Member
    VT
    lol you dont wanna see it xD the post is now aluminum slag and the seat where it broke is disfigured pretty bad :/ But!! it is the 2/3 carb that broke, 1 and 4 are still gorgeous
  6. k-moe
  7. VTGanja420
    VTGanja420 Member
    VT
  8. VTGanja420
    VTGanja420 Member
    VT
    sec, gotta upload it to my photobucket
  9. VTGanja420
    VTGanja420 Member
    VT
    the idea is to put it on the standing mill and hone er square and make a post to pin in place, but if i can just replace it, ill try to avoid that headache
  10. TheCrazyGnat
    Central PA
    Damn, dude. What did that pillar say about your mama?
  11. VTGanja420
    VTGanja420 Member
    VT
    lol, u dont wanna know :p
    TheCrazyGnat likes this.
  12. VTGanja420
    VTGanja420 Member
    VT
    like, it started taking np, then once we got the filler rod to start beading it just melted to slag @,@
  13. k-moe
    That's what aluminum does without having proper heat control. That job calles for TIG, not Torch.
    You can try this: http://www.yamaha-triples.org/workshop/Mikuni_MKII_Post_Repair.pdf but you'll probalby have to make a through hole to have enough threads for the bolt to grab. Shouldn't be a problem if you use a sealant. Otherwise get a replacement carb body.
    VTGanja420 likes this.
  14. MiGhost
    MiGhost Well-Known Member
    hogfiddles and VTGanja420 like this.
  15. VTGanja420
    VTGanja420 Member
    VT
    i posted 1 link to a ebay carb that might fit a few replies up, but i also noticed a 06 gsxr thats in my finance range @,@. im torn, if i cant find a replacement that i can garentee will fit i cant see putting myself through another wheeless week for a 50$ gamble :/
    oh also, it was tig not torch :/
  16. VTGanja420
    VTGanja420 Member
    VT
    im going to sleep on it and see if the guy locally gets back to me on a gsxr600 i noticed while searching for another replacement ( noticed a nice xj650 for 1500 aswell). gotta soul search, but i thank you for answering my inquiry just the same :)
  17. k-moe
    The gixer will need work too, and cause more traffic tickets.
  18. Polock
    even if you got it welded it would have broken again when the mill hit it
  19. k-moe
    He hasn't got enough of a stub left to make a dovetail. Yours was the first repair I thought of @Polock.
  20. hogfiddles
    Yup, that body would work just fine, as MiGhost said....... And do the seals as he said as well
  21. Jetfixer
    I bought a whole rack for my 750 a few months ago for 65.00 just missing diaphrams. My #1 throat was cracked P.O. did it. Now I have spare parts!!!
  22. VTGanja420
    VTGanja420 Member
    VT
    we manufactured an aluminum post that we pinned in, got it fired up ( still in parts, got a new bike in the process for a steal) but havent really played with it since. once i get a few more min free ill post up what we did :)
  23. VTGanja420
    VTGanja420 Member
    VT
    and sadly the first day with my new gs500f i got a speeding ticket @.@ ( R.I.P. spotless reccord) but i still enjoy the bike :p
  24. k-moe
  25. Rebem
    Rebem Member
    Perth, Western Australia
    Not sure if this will help, of even if it will work because I haven't fired mine up yet, but here is my pillar fix. I manufactured a new pillar and plate from 20x20 aluminium extrusion. I use the float seat bolt as the retaining mechanism and dropped the alu washer. Here are a couple of pics. The final design has a bend at the top to help with the limiter tab, not a hook like you see in the photos.
    k-moe and TheCrazyGnat like this.
  26. chacal
    Very creative.
  27. k-moe
    Nicely done. I like how you used the other float pillar as a register to maintain a parallel assembly.
