How the hell do I Pop start My maxim
Discussion in 'Hangout Lounge' started by Gabitronics, Aug 7, 2016.
  1. Gabitronics
    Gabitronics Member
    Puerto Rico
    I've tried putting it in second gear but it won't let me it goes back to neutral, tried it in First. And nah it doesn't work. What Youtube Magic is at work that make it look so easy.
    does it let you put it in third?
    sounds like you have a shifter problem, weak or broke springs, possibly a broken chain guide (hope not)
    what kind of maxim you talking about?
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Agreed, sounds like something else is going on, when my battery was heading south I was able to do the 'crab walk' and pop the clutch in 1st gear and start it.
    When was the last time it started/ ran?
  4. TheCrazyGnat
    Central PA
    What seems to be happening in first that is preventing it from starting the bike? Does it not turn over, does it start and immediately die? Something else? I am not questioning your intelligence here, but is the kill switch on?
  5. Gabitronics
    Gabitronics Member
    Puerto Rico
    I'll admit, one time I did it once with the kill switch on. I was starting to think the bike had something that wouldn't allow me to put it in second to pop start it. It's an xj650 Maxim by the way. I run as frequently as I can, about four times a week. It does have starter clutch problem, that "rattle-can of rocks sound"; that's why I'm trying to add pop starting the bike to my repertoire. Thanks to your support by the way. The bike just doesn't seem to turn over, I even did it on a hill once, swayed back, got some speed, released the clutch, hit the starter, and nothing, just a screeching halt.
  6. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Try 2nd or 3rd gear.
  7. TheCrazyGnat
    Central PA
    ^ what he said. If it gives you a hard time ststaying in gear, try to rock the bike forward a little bit to see if it catches. I personally wouldn't bother with trying to hit the starter, but I was having starter clutch issues last year and had to remove my starter motor completely. I spent most of last riding season pop starting my bike, ha ha.
  8. k-moe
    I think you really need to do the guide-ectomy. The bike should not be coming to a screeching halt on a downhill in any gear.
  9. dkavanagh
    Rochester, NY
    Is the kickstand down?
  10. XJ550H
  11. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    What they ^ said and...
    Bump start your bike:
    Bike in neutral (green light showing).
    Kickstand up.
    Kill switch to run.
    Pull the clutch all the way in and hold it.
    Roll the bike to build speed.
    When you have a good roll going punch the shifter into first gear and blip the throttle.
    Your bike should start.
    Important: The clutch lever should be held all the way in at all times during the process. The bike will "jump" momentarily when it starts. Don't get excited and let out the clutch lever.
    Gary H.
  12. k-moe
    I feather the clutch a bit after shifting into first. Makes the engine spin more better.
    rocs82650 likes this.
  13. rocs82650
    Middle Tennessee
    So do i. I actually feather the clutch and roll the throttle but because he's new to doing it I don't want the bike to take off without him.
    Gary H.
  14. mlew
    What about fixing the starter so you don't have to push start?
  15. rocs82650
    Middle Tennessee
    Or jumping the solenoid post to verify it's not the problem.
    Gary H.
  16. Gabitronics
    Gabitronics Member
    Puerto Rico
    Will try, I'll let you know how it works out.
  17. k-moe
  18. rocs82650
    Middle Tennessee
    Even if it starts he should rebuild the starter. Less worries later.
    Gary H.
