Need help 82xj550
Discussion in 'XJ Technical Chat' started by CruzNCycles, Sep 3, 2016.
  1. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    I've been working on my girlfriend's 82 xj550
    It starts sometimes
    It has spark only when pressing the stater button and releasing it not during the press
    It starts up sometimes and runs amazing but then it'll cut out and not wanna start for a while it's hit or miss
    I have a xj1100 tdi which doesn't have the terminal for the kickstand relay
    I don't see why it would start sometimes
    The coils are getting power
    When it sparks it doesn't stop like without touching anything it'll spark over and over continuously in this state the bike turns on when the button is pressed
    I just need help she's really hyped to ride and my 750chop is too long tall and heavy for her
  2. hogfiddles
    Sounds like a weak battery
  3. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    Elaborate
    The battery is new but it may not be the stock battery
  4. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    It's fully charged you thinking it doesn't have enough cca's?
  5. XJ550H
    when you have it running check voltage
    when starting check voltage if it drops below 10 (9.5 )volts it will not start.
    get the correct battery
    ohm out your ignition system and test the charging system.
    specs and trouble shooting in this link
    are you running the XJ 1100 TCI on a 550?
    unplug the sidestand relay to eliminate it as the problem
    do you have a service manual?
    Stumplifter likes this.
  6. XJ550H
    should be 12N-12A-4A/12V 12AH
    what do you have for a battery?
  7. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    I am running the xj1100 tdi
    I will unplug the relay and check again
    Charging system is good
    I will ohm out the ignition and check the battery voltage when starting too
    I will get back to you with the results
    Also gonna pick up the correct battery if need be
    Thanks for the advice! I really appreciate it!
  8. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    I do have a manual been digging thru the diagram and harness for any sort of issues i.e. loose dirty broken connections
    Its just weird some days it'll turn on all day no problem others nothing but when I turn the key off bang a huge backfire
  9. chacal
    I think this could be part of the problem. If I recall correctly the XJ1100 some a type of pressure sensor device (connected by a vac hose to the #2 carb body) that is used to partially control the TCI......
    XJ550H likes this.
  10. XJ550H
    you should at least borrow a tci unit for a 550 to see if the problem goes away.
    then if the problem goes away buy a 550 tci and sell the 1100 tci
    I can send you one to try out, but it will require a deposit plus shipping if you are interested start a conversation with me.
  11. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    Kinda like the xs1100? That makes sense I've been thinking that for while my 750 did this and it ended up being a soaking wet tdi then I ran the xj1100 tdi on it and boom it was fine. The voltage during cranking doesn't drop below 11v stays around 11.31v. I'm testing the wiring now.
  12. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    This thing has a mind of its own it's starting fine now after a bit of wire reconnecting
    But it did cut off randomly once
    I'm really starting to lean towards the tdi being fritzy
  13. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    Y
    You weren't kidding anything under 10v and it's crap haha thanks for the help it's actually made a huge difference
    The bikes running on all 4 got a little bog n pop at 25rpms to 35 rpms but otherwise all good now to tune the carbs I paid 300 bucks to get tuned note to self just do it yourself. My dad always said you can do most things three times before you spend the amount of money it would cost to get it done and in the end learning is better than spending
  14. CruzNCycles
    CruzNCycles Member
    Daytona Beach Fl
    Back to the carbs any advice before I pull put the sync out?
