Oil Leak Please Help
Discussion in 'XJ Technical Chat' started by Schafeman, Sep 24, 2007.
  1. Schafeman
    Schafeman New Member
    Twin Cities, MN
    I've put countless hours into fixing up my poor XJ550. Everything is running/driving top-notch HOWEVER there is one issue I can not figure out. The bike has a difficult to find oil leak. It only seems to leak when i'm out driving, when the bike is idling I don't see any leakage. It must be leaking quite a bit because when I come to a stop there is a cloud of oil-smoke burning on the exhaust. I attached a picture with the area it appears to be leaking from, however, I don't see any gaskets or anything in that area. Just those rubber fin seperators. Thanks for ANY help so I can finish this bike!
    YES I know I have a cracked header, that will be fixed soon...
      File size:
      36.2 KB
      3,087
  2. MiCarl
    Probably the cam cover gasket. Likely running down from this area:
      File size:
      48.9 KB
      3,064
  3. Schafeman
    Twin Cities, MN
    I thought that too, but it seems to be 'bubbling' up from the circled area. I checked the cam cover gasket and didn't noticed any leaking oil in that part of the engine. I can replace it if nessecary but i'd hate to throw more money into this thing if I don't need to.
  4. PghXJ
    PghXJ Member
    Pittsburgh PA
    only way oil can get there is from the valve cover gasket mentioned by MiCarl.
  5. RickCoMatic
    Here's a thought.
    It's not an Oil Leak. It's an exhaust leak.
    If you are burning Regular with Ethanol added ... a by-product is water.
    Usually goes right out the back after being turned into steam in the collector.
    Sometimes, if the Mixture is too Rich ... the exhaust will drip out of the drain holes.
    That broken Header Collar is a shortcut to the atmosphere.
    Lines-up pretty close to where you drew the circle; too!
    If you can hear that broken Collar ... Pop, Pop, Poppidy, Pop, Poppin' ...
    I'd put my money on that being "The Leak"
  6. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    An old yamaha mechanic taught me a trick. Clean the hell out of the area and then spray it with athlete's foot spray and you can see where it's coming from.
  7. Polock
    home made Magnaflux.............i like it
  8. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    Great tip, these old mechanics are worth knowing!
  9. Schafeman
    Twin Cities, MN
    It's definitely a cloud of oil-smoke that is dripping/burning on the headers though so I doubt its exhaust/steam. If its not too expensive I might just replace the cam gasket anyways just to be sure. I'll check into it.
  10. RickCoMatic
    Replacing the Cam Cover Gasket and getting a good Exhaust Pipe Collar on there should straighten you right out.
    Any other kind of leak up in that area would lead to a performance issue and your running good ... right?
  11. MiCarl
    Not sure if this is likely (or even possible), shot fork seal throwing oil that blows onto it?
  12. RickCoMatic
    Possible?
    Yes!
    But, that would have to be one seriously bad leaking fork seal. Close to no seal.
    Let's do C-S-I XJ.
    Look on the inside of that #-1 Pipe ... is there a trail?
    That would boil and stink; too. So there wouldn't be too long a trail ... just build-up that you could wipe-off with paper towel.
    Wipe that #-1 Header under the Collar and lets see how bad it's leaking.
  13. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    I'm guessing that blind plug right behind the rubber spacers has developed a leak. It seals the end of the cam oil feed gallery .
  14. Schafeman
    Twin Cities, MN
    I just had the fork seals replaced and they are not leaking. I did see that plug behind the spacers but didn't see any oil leaking from that either. Also the cam gasket is $70! Will need to wait before I can get one.
  15. PghXJ
    PghXJ Member
    Pittsburgh PA
    $70?? I call BS on who quoted you that.
    They are about $38.
    OLDBIKEBARN
  16. Schafeman
    Twin Cities, MN
    Bikebandit quoted me on that. I've bought a lot of parts from them, so maybe i've been paying too much? Haven't bought from OBB yet, i'll check them out.
  17. RickCoMatic
    70-Bucks ... whoa!
    That's highway robbery.
  18. Robert
    $70 from the dealer is about right but less expensive units can be had from a variety of sources (Shameless Plug: including our own Chacal!). I'll echo PghXJ, $35 is about right for an aftermarket unit.
