What Size Heli-Coil?
Discussion in 'XJ Technical Chat' started by patmac6075, Sep 9, 2016.
  1. patmac6075
    patmac6075 Active Member
    MKE
    Adjusting the valves on an '82 XJ750 Maxim, as I'm removing the valve cover bolts two of them come out completely stripped and full of aluminum.
    First question is, can/should I use a heli-coil......Second is, what size should I buy?
    Although all of the bolts were grossly over torqued, only two of the outside (larger) bolts were stripped.
    Any help is always appreciated.
    Pat
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I used heli-coil. It work out great and was pretty easy. I believe I used a M6x1.0 with a 1/4 inch drill bit. But I have a 550. I don't know if it's the same for your bike.
  3. Polock
    your 750 does use 6X1 threads
  4. patmac6075
    MKE
