Why me!?
Discussion in 'XJ Technical Chat' started by Anthony14, Sep 29, 2007.
  1. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Ok, so I take the bike in for the second time to get it certified. I was told that I needed some reflectors and to fix the master brake cylinder. So I did that and all worked great.
    So, I take it in, drop it off and then get a call...
    Your indicator lights, rear lights, neutral light, oil light do not work.... Wtf?
    So, how do all of these things go from working to not working in a flash? All 2 fuses are good and I did a quick sweep of the wires and they all appeared to be good, but will do another sweep tomorrow. Any ideas on what to check on? Relays?
  2. flashsnapshot
    flashsnapshot Member
    eastern carolinas
    I had a similar problem with my inspection. It turned out the Fuse holders were not holding the fuses tight enough. I just squeezed them with some pliers and put the fuses back in and the problem was gone. Hope it's that easy for you.
  3. kontiki
    kontiki Member
    Columbia, SC
    Man... what is it with all these "inspections" in differentent places? Sheesh... sounds like government run amok.
    Glad I live in Georgia.
  4. olebiker
    olebiker Member
    Kingston ON Canada
    The OP is in Ontario Canada. We have to have any car or bike inspected to register them.
  5. ziggy
    ziggy Member
    Florida
    inspections? thats garbage man, glad i dont have those, id be giged for an a** load of problems.
    but to the problem, ive had a problem like that as well. my dashboard lights all got shot. i think the backlight lit up but that was it. but im pretty sure my directionals actually did work. after a few days like that i hit a bump and all my indicator lights lit back up. speaking of which my tach still doesnt work, but id make sure its all connected tightly.
  6. olebiker
    olebiker Member
    Kingston ON Canada
    If you hit a bump and things started to work that is a sure sign that you have a loose wire somewhere.
  7. Anthony14
    Anthony14 Member
    Ok I found it, a bloody fuse, can't believe I missed it and now I have to get it back to the place wed. or Sat.
    Oh well, hopefully I can be riding soon.
  8. worm
    worm Member
    Attleboro, Massachusetts
    Never rely on visual inspection of your fuses! A $10 continuity tester/multimeter will save you a lifetime of aggrivation!!!!!
    Good luck w/ the insp.
  9. PghXJ
    PghXJ Member
    Pittsburgh PA
    do you have blade fuses yet, or still the old glass type?? I would suggest a fuse box swap is in order if you still have the original fuse block.
  10. Anthony14
    Anthony14 Member
    Ya, I am in the process of switching them all to the new mini ones.
  11. Anthony14
    Anthony14 Member
    Update: I got even more great news, my M1 expires Nov. 2 and I wont be able to renew it (the way it is down here), the thing is, is that no one if offering M1 exit tests/M2 tests, so how the hell am I suppose to upgrade?!?!
    Sorry for the rant.
  12. Hired_Goon
    Hired_Goon Member
    Oz
    Now this statement scares me.
    The purpose of inspections (at least here in Australia) is to ensure vehicles are roadworthy and safe to use. Not only for you, but for others on the road.
    Are you saying that you are using your bike on the road in a less than roadworthy state??? Putting yourself(Yes, your choice) but more importantly, other motorists and pedestrians at risk????
    Inspections here are only to make sure the basic things are within spec. Eg Brakes work, lights work and tires have enough tread on them.
    The sad part is that here in Australia, inspections only happen on first registration so you can drive it for fifty years so long as the registration doesn't lapse. I'm a big fan of the syatem in place when I lived in New Zealand. All vehicles older than 5 years(I think) have to be inspected by a licenced person every six months. PITA, but it keeps some trash off the road.
  13. chilidog
    chilidog Member
    tampa, FLA!!!....365days of riding/year
    about inspections, I live in FL same as Ziggy and I do see where hes coming from cuz inspections are a hassle (i remember all the interesting tricks we used in MA) but I also see so many unsafe vehicles driving around too, we had an inspection in FL a while back and to be honest I wouldn't mind having it back, I cant list the number of times ive looked at the car next to me and though $h!t i gotta get some distance between me an that POS cuz if that guy couldnt spend more than $300 on his whole car there isnt any chance he's got insurance.... and im no tree hugger but when you see a car chugging along belching crap out the rear it makes you think too :cry: ...
    of course that inspection shouldn't apply to MCs we should get a pass!! :lol: :lol:
  14. Robert
    We don't have inspections here (CA) save for returning a salvaged title back to the road. Not a real problem, brakes and lights. It's easy enough but I totally agree one should not ride (or drive for that matter) anything that may put others at risk. I would go for the annual requirement here if it weren't such an infringment on freedoms (Heaven knows there are too many now, getting worse every day). We do have an 2 year smog requirement but it is just too long apart to be much good. Of course I'll rant about how much I hate having to go through it every time but I know it is for the greater good and air quality. Additionally, if the smogging official finds any leaks or unsafe conditions, he/she can fail the vehicle until the condition is corrected (most don't look that hard). Far too many vehicles on our freeways each day that are an accident looking for someone to hurt. Not to mention the noxious exhaust from a vehicle in poor/neglected tune.
  15. TaZMaNiaK
    TaZMaNiaK Member
    NJ
    Wow I guess living in Jersey my whole life, I just accepted inspections as just something else that I have to do every year. Renew my insurance, renew my registration, go get inspected. (Hell, the inspections are only every 2 years now!) Renew my license every 4 years. No skin off my ass... They just do a safety inspection on bikes, they don't do a smog test. Tires, lights, horn, mufflers, etc. But with how tight the smog test is here for cars, I cant understand how some of them are on the road. (We have the second strictest smog standards besides Cali, and we could make yours look tame in a few years if people get their way!)
